To wash the engine or not? - Diesel Forum - TheDieselStop.com
Old 11-13-2009, 04:47 PM   #1 (permalink)
jHanratt's Avatar
I would like to shampoo the engine compartment on my 7.3 idi. I have done this to numerous other vehicles without any issue but I read that you can damage the injection pump on the IDI. It also has a banks sidewinder if that makes any difference. I plan to use a can of engine shampoo on the engine then wash with a hose and sprayer.
The problem is that it has 17 years of accumulated oil, antifreeze and grease on the engine and compartment and it smells when it's hot. This is a motorhome so diesel engine smells are not welcome inside.
Do you think it would be safe to clean it? What do I need to protect?
1992 Ford F-350 Dually 4X4 28' Motorhome 7.3L idi, Banks sidewinder waste gate turbo, Monster exhaust, E4OD with BanksTrans command 100,000 kilometers.
jHanratt is offline
Old 11-13-2009, 05:04 PM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (109)
Wash only a cool engine but most of us know that anyway....be sure the STEEL water drain on the valley pan is clear...... it is a 1/2 square hole behind the intake, with a turbo not sure how you would see it. Do not remove the STEEL plug just ensure the water will flow out and down the rear of the engine.
You could cover the GP controller or at least ensure it is blown clean/dry after. Try not to disturb the return lines between the injectors too much. DO NOT get any amount of water in the intake for sure turbo or non turbo......
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 11-13-2009, 05:10 PM   #3 (permalink)
chuckster57's Avatar
Originally Posted by cdnsarguy View Post
with a turbo not sure how you would see it.......
I used a mirror when I was looking for a different thread, and I used a piece length of speaker wire to test for blockage. I would NOT use any high pressure wands either. Castrol make a product called "super Clean" that will eat just about anything and it rinses clean with out any pressure.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is online now
Old 11-13-2009, 06:23 PM   #4 (permalink)
NH2112's Avatar
Send a message via MSN to NH2112 Send a message via Yahoo to NH2112
I've pressure washed hundreds and hundreds of engines, both gas and diesel, without any ill effects other than the occasional wet distributor - and I'm talking about using an industrial 3000psi washer, not the wimpy homeowner ones. Avoid spraying directly on electronics, avoid getting too much water in the air cleaner (squeeze the water drain before starting), and know that you might get belt slippage & clutch chatter for a few minutes after washing. Other than that, go to town on it. Give everything a once-over afterward to ensure no connectors were damaged or blown off by the water.
Phil
1988 F350, NA 7.3l, 5-speed, crew cab, 4.10 SRW. Miles: over 450K. Being taken off the road within the next month or so to deal with advanced rust. May just do a resto/rebuild to better my bodywork & paint skills.
NH2112 is offline
Old 11-13-2009, 08:28 PM   #5 (permalink)
Snotzalot's Avatar
A hot IP and cold pressure washer will give you the opportunity to learn how to replace an IP.
Regards,
Paul - Pocono Mtns. USA
02 E350 15 Passenger, 52,000 Miles
'90 E350 7.3L Ex-Ambulance High Top 400K Miles, No Turbo, Stock Stock stock, No ELC! (Extended Life Coolant) & 10 Oz. Bars Stop Leak, Retired 11/8/2011 with blown trans.
7.3L Alternator Belt Idler Photos
Snotzalot is online now
Old 11-13-2009, 09:18 PM   #6 (permalink)
rotaryboots's Avatar
Send a message via MSN to rotaryboots
I pressure washed my engine the day I bought it and cleaned it up so that it looks all clean again. Just made sure that I covered the more sensative parts of the engine and made sure the engine was cold and then dry before I fired it again.
'90 7.3 IDI F350 4x4 Custom, ext cab, E4OD w/ tow package, 4.10 Dana LSD rear, 94' ATS turbo kit w/ 99' PSD wastegated charger set at ~20psi max, copper firering head, studs, turbo IDI block, mild head work, Delta Cam, Moose pump, turbo injectors, 6.0 PSD intercooler, propane injection, 3in exhaust. Almost 300 and 500. (added 2 more flats than previously) 296hp, 487tq (6/4/11)
'03 7.3ltr Powerstroke F350 4x4 4dr. SCT Livewire, ATS exhaust, rebuilt HD trans, 6.0 trans cooler, fuel mods, AFE intake, Garrett gtp38r ball bearing turbo; glad its not a troublesome 6.0
rotaryboots is offline
Old 11-13-2009, 09:19 PM   #7 (permalink)
NH2112's Avatar
Not really, thousands of humvees with thousands of the same DB2 pump the IH diesels use have forded thousands of cold streams, rivers, or even washrack pits over the injector pump without damaging the pump. It's only a little less of a wives' tale than the one about batteries discharging when set on concrete.
Phil
NH2112 is offline
Old 11-13-2009, 09:41 PM   #8 (permalink)
Snotzalot's Avatar
I personally have seen damage to 7.3 IP's from pressure washing. If you wish to pressure wash go right ahead.
Regards,
Old 11-26-2009, 09:46 PM   #9 (permalink)
hey he is right i done the same dam thing we let it warm up a little bit say 5 min and thin use a water hose we use gunk engine bright you dont have to let it warm up and its best not to and use a parts cleaning brush that helps alot
oldschool2 is offline
