Old 05-03-2005, 09:42 PM   #1 (permalink)
Wastegate Adjusting?????????????
Ok, i want to bring to truck to around 12 psi so when i burn the nitrous. Now i tried to adjust the wastegate but just couldnt figure it out. What do you do exactly cause tommorrow i am going to get up and install my holley red top and the nitrous and i would like to adjust the watsegate while I am at it.Cause right now i ran it up to about 90mph and the exhaust temp stayed below 900 degrees and i was almost right on 15psi and i even have an intercooler. Thast i want to bring it down.
thanks [img]/ubbthreads/images/graemlins/shrug.gif[/img]
1993 Ford F-350 IDI Diesel Crew Cab LWB Banks Sidewinder, Dual side exit 5" Exhaust, Soft Bed Cover, 2WD, Ranch Hand Front and Rear Bumpers, Boostlevel=14psi, 5speed trans, 2800 watt sound system, RedTop Holley FuelPump, 181,000 miles
250HP and 550 Torque @Wheels (w/o NOS)
http://community.webshots.com/user/coolmann64
2003 Excursion Limited powerstroke, bd-power 80hp chip, single ATS exhaust, air intake and tv/dvd
TrbdF450Beast is offline
Old 05-03-2005, 10:14 PM   #2 (permalink)
My Photos: (13)
Re: Wastegate Adjusting?????????????
You can adjust the wastegate by making the WG longer, just turb the little turnbuckle out and it will make it longer and kick in faster. If I were you, I would try to adjust your gate with your foot. If you really don't like to watch the guages, go ahead, but you are missing out on all that cool air your intercooler is providing. You have a sweet set up with the intercooler, you should be shooting for 15psi to take adavantage of the cooler. But 12psi is safe. Sorry, I have to hold back, I realize not everyone wants to make the trucks run at max power.. Sorry, yeah, back it down and you will alot of happy care free miles. Scotty
Semper Fi
Scott Beretz
2006 Dodge Megacab 4x4, Cummins, 6 Speed, Airbags, Quadzilla Commander, XZillaraider 2, 285/75R17 Toyo OC AT's
Pulls a: 3814SS Keystone Raptor Toyhauler w/Quads
beretzs is offline
Old 05-04-2005, 09:15 AM   #3 (permalink)
There are two dimples on the part that is treaded onto the rod. These are stake marks to set the length. Take a drill bit a little larger than the marks and drill them until you reach the threads. This will unlock the the setup. Get a 1/4-28 nut to lock the unit in place and adjust away.
Jim. My Second 94 F250 XLT,4X4,Ext. Cab,7.3 I.D.I Factory Turbo, 4.10 Limited Slip, E4OD, K&N, Pyro, Boost and Tranny temp Gauges,Tekonsha Defender Tranny Cooler,B&M Shift +,Home Grown Glow Plug Saver and Headlight "Bright Box", Banks Stinger Exhaust, Powershot 2000 LPG, Cooper 33's on Aluminum rims, DeLorme GPS on the Laptop.
maddenji is offline
Old 05-04-2005, 09:32 AM   #4 (permalink)
Ok I am like you i want the most power. But i also dont want to be pikcing up pieces on the side of the road if im going to be spraying NOS. I mean if it comes down to it i can just back off the throttle just a hiar and control ir depending on all the readings on the gauges. Well, Im going to install the Holle red top for fuel purpose since i turned it up (if it needs it yet) then im going to finish the install of the NOS system and i will let yall know how everything is going and wether or not i need to get that address for ken who sells hea studs(hehehehee),
again thanks ....TTYL
Old 05-04-2005, 11:00 AM   #5 (permalink)
My Photos: (13)
The hardest part about having all the power is not abusing the engine. As long as you are driving sanely and not punishing the truck, day in and day out, your truck should hold 15psi pretty easy. Just use the guages, that is what they are there for. Drive by your pyro and boost guage and you will be fine. Scotty
Semper Fi
Scott Beretz
beretzs is offline
Old 05-04-2005, 11:47 AM   #6 (permalink)
Thanks....Ill keep that in mind.
