Water Injection - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 05-12-2006, 09:41 PM Thread Starter
Water Injection
I was on the DPS site and looking at stuff. How does water/alcohol injection work, as far as making a difference? Anybody else have this installed? How about the Banks Stinger exhaust? does it sound good? Thanks
1994 F-250 XLT Off Road 7.3L IDI Factory Turbo 5 spd Man. 410 gearing. Pump turned all the way up, 14 PSI Boost, 1250 degrees MAX. ATS Outlet/Downpipe upgrade with 4" system. 86,xxx miles.
Is Now CUMMINS Powered. '01 24v with HT Turbo, Injectors, TST Competition and Edge EZ, with FASS.
TurboIHPower is offline
post #2 of 5 (permalink) Old 05-13-2006, 10:47 AM
rawpower's Avatar
Re: Water Injection
I have neither, but I've read my share...
The water injection does help power-wise, but is more for trailers and stuff to keep egt's down lower. Propane may be a better option, which can also lower EGT's if used right.
As far as the exhaust, If you still have the stock system, anything will be better than that. The stock downpipe is a huge POS. The stinger system will be very good on the EGT's, dropping them at least 100. Also, You might consider not using the muffler it comes with, even though it is suppposed to be a "high flow" muffler, nothing is as high flow as a muffler-delete. I don't run anything but an ATS downpipe actually... Tried putting on a 3" straight pipe, EGT's jumped another 100... Took it off.
This is cool----> ♣="╛┐∞3& amp;#9488;╕∙s█ħ&am p;#9562;{░ WOW, I'm entertained...
1993 Ford F350 7.3L Turbo Diesel ZF S5-42, Divorced TS NP205, OEM locker/welded 2.5 ton Rockwells, 46" Michelin XML's, and some stuff too.
rawpower is offline
post #3 of 5 (permalink) Old 06-27-2006, 05:14 AM
Re: Water Injection
Has anybody made their own water injection system for their IDI ? Any links on a homebre system suitabel for the IDI are appreaciated. -Thanks
1994 F250 7.3 IDI E4OD
rkpatt is offline
post #4 of 5 (permalink) Old 06-27-2006, 07:55 AM
My Photos: (5)
Re: Water Injection
Sent ya a pm with plans...
Travis
Will Work For Diesel Fuel.
argve is offline
post #5 of 5 (permalink) Old 06-27-2006, 12:50 PM
tld
Re: Water Injection
Water injection is more for truck pullin than anything , it does make more power but mainly used to keep the heat down.
1985 f350 crew cab dually with 1991 401 ford diesel midrange eaton 5spd trans
tld is offline
