Old 03-05-2007, 01:05 AM   #1 (permalink)
water in oil after I put new heads on
I bout a 92 ford F-350 4X4 with a blown head gasket well to make along story short I had to find two new heads I had the ratator presuer check and flow tested I pulled the oil cooler put new orings in it and check it for leaks all looks good. well not so Idrove it today about 10 miles and when I got back I checked the oil it is over full and it looks like it has water in it. What do I do next
Justin_berhardt is offline
Old 03-05-2007, 01:29 AM   #2 (permalink)
Re: water in oil after I put new heads on
I don't know what all you went through with the heads, but did you at any point do a compression test? It might be in order now. It seems that cavitation is often misdiagnosed as blown head gaskets.
'91 F250 4x4 SC, ATS 093, ZF-5, GV OD, 4:10's, 3" in, 3" out, AEM Dryflow, 33"s
skimballc is offline
Old 03-05-2007, 10:00 AM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Give us a rundown of what else you took off and reinstalled other than the heads/rad. Is that the radiator you had pressure tested, how did you check the oil cooler internally for leaks.
Proud Canadian BOOB man too!!
cdnsarguy is online now
Old 03-05-2007, 10:15 AM   #4 (permalink)
I did both heads they had cracks I took the oil cooler to a ratator shop along whit the ratator to get cleaned and check. the truck runs good no smoke and a lot of power.
Old 03-05-2007, 10:53 AM   #5 (permalink)
cdnsarguy's Avatar
My Photos: (66)
I would contact the shop that worked on the cooler and find out exactly how they did the cooler......... I will be talking this up at the shop this morning.
Old 03-05-2007, 11:35 PM   #6 (permalink)
well tonight I messed with it I tock the ratator cap off put it back on stared the truck let it run for 30 to 45 sec shut it off and there is alot of presser I think the block is cracked.
Old 03-06-2007, 12:18 AM   #7 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Are you thinking cavitation possibly.......
http://www.thedieselstop.com/content...on%20Diagnosis
Back at the beginning you stated your oil was overfull, how low was the coolant then. Did you drain the water/coolant from the pan yet.
You could have nicked an oring too, where did you look for leaks and what proceedure did you use to replace the orings.....
Old 03-06-2007, 12:35 AM   #8 (permalink)
I used a press to install the orings the coolent was 1 1/2 gallons low I think I will Pull the heads off and drop in a short block
Old 03-06-2007, 05:32 AM   #9 (permalink)
My Photos: (16)
It'd be prudent to pull the oil cooler, and pressure check it, first.
'93 F250 SCab XLT, 4X2- 7.3/ZF5/4.10 Banks Wastegated Turbo, Enviro-assult tube
'85 F250 Reg Cab XL, 4X2-6.9/C6/3.54 Racor, Holley Red, Auto Jet 3" out, Air Ride Rear
'93 F150 Reg Cab XLT, 4X4-5.0/AOD/3.55 Pacesetter dual out, Timbren Rear
Some pix/ The fleet
Zrob is offline
Old 03-07-2007, 09:44 AM   #10 (permalink)
A lot of presser inthe ratator it could not be the oil cooler.
