I'm getting ready to install a water temp. gauge. What do you all think is the max. water temp. I should let it get to. Want to get a gauge with the right graduation's. Thanks Wayne
93, F350,7.3, crewcab, 5 speed, 4X4, 4:10 gears, hypermax turbo(now working 5/20/05), 3.5" exhaust no muffler,Soup Bowl removed. "Brownie" (named by my 2 yr. old niece and nephew) came to live with us on 9/30/04. New Radiator 09/06.7 new beru's 12/30/06
Thanks Travis, I'm going to try to put my gauge in tommorow. If it is not raining. Wayne
Travis got it correct. When you run these motors hot (244 deg) you rist cracking heads and pushing out coolant or head gaskets. Try to maintain temps below 225 just to be kind to your motor.
