Old 07-06-2005, 01:41 PM   #1 (permalink)
Well, I got my work/hunting/fishing Truck!
Howdy all,
Just picked up a '93 F250 ext cab, long bed, factory turbo, manual tranny and 4:10 rear - runs good/fair - need some maintenance. Gonna change all the fluids and filters.
only problem - the steer wheel is all messed up - the guy that owned it used it to pull himself into the truck - it drives, but scares the heck out of ya!!! So, do I need to replace the whole steering column? Should I go to a body shop?
oh, can I put a Tymar intake on this year of truck?
Thanks all -
Alex
_______________________________________
Bubba Truck: '93 F250 4x4,Ext Cab, long bed, 7.3 IDI w/factory turbo, 5 Speed w/ Lux SMF & 4:10 rear
2002 F350 Crew cab, Long Bed Dually! 4x4, 7.3 w/intercooler, Bolt Action 6 (manual tranny), 4.10 rear. Autometer Boost & Pyro on A-pillar :
Sold:
'96 F250 PSD Ext Cab, Long Bed, E40D 4x4, 4:10 Diff
'90 F250 IDI Ext Cab, Long Bed, E40D, 3:55 Diff
CircleA is offline
Old 07-06-2005, 01:50 PM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: Well, I got my work/hunting/fishing Truck!
That is a common problem and I believe the best would be the wrecker for a good replacement.
Proud Canadian BOOB man too!!
cdnsarguy is online now
Old 07-07-2005, 01:41 AM   #3 (permalink)
what is the steering wheel doing? and also ive never heard of this intake what is it?
-Jeremy Roooster!
American by birth, Southern by the grace of God!
1991 F250 7.3l 200XXX extended cab long bed. 3.55's REDNECKED OUT!! 295/75/16 Bfg All Terrains 16 in billet rims. New front brake pads and rotors, rear shoes, glow plug controller, glow plugs, return line kit duralast batteries, mitubishi off set gear redution starter, altenator, valve cover seals, holley red pump,new injector pump, soon to be new injectors, new vacum pump. Removed soup bowl and drilled holes in air intake.
http://community.webshots.com/user/r0oster06
R0oster06 is offline
Old 07-07-2005, 09:55 AM   #4 (permalink)
If the tilt wheel is loose, You can pull the wheel and the turn signal switch. Then I believe that you will find 4 bolts that bolt the wheel onto the pivot assembly. Rempve them one at a time, locktight them and tighten them down. See if that fixes it.
Good luck
1990 F-350 Dually 4X4 CC Rebuilt Turbo and NEW 7.3L DAS engine, rebuilt rear diff, Reman E4OD Stage 1 injectors Stage 1 pump Baumann recal kit and TDC for E4OD dead trans again...
2004 F-350 4X4 CC 6.0 PSD
2004 Wilderness 320dbhs TT
DSBlack is offline
Old 07-07-2005, 12:35 PM   #5 (permalink)
I guess the steering wheel problem is common when folks use the wheel as a handle to pull them selfs into the truck. I have the bushing that the guy who owned the truck said it needed. It doesn't look like it will be a tough job to repair. Only problem, if i screw it up, it will be hard to get the truck to a repair shop!!!!
Alex
Sold:
CircleA is offline
Old 07-07-2005, 12:47 PM   #6 (permalink)
My Photos: (5)
He must of been a big old guy!!
My shop teacher is 525lbs. and has a 03 F350PSD CrewCab. And he pulls on the steering wheel to get up in that big ole FX4. But he still climbs ladders.
I never thought using a steering wheel to get in. I always hopped my big ole 6'3 255 frame up in the truck with out grabbing any thing.
I'd pull the steering wheel and see what's messed up.
DT
Pre-Vet/Agri Major/minor at APSU..ya i'm a freshman, so what!!!!
1982 International 1954 DTA466 240hp work
2002 F350 PSD 6spd supercab xlt
1985 F250 4X4 6.9IDI 4SPD w/ Granny 4.10gears 1ton rear 4" lift 33"MTR's. my first truck bought her when i was 14. restored frame off. originally red now deep wedgewood blue. longbed reg cab.
1993 Craftsman 2.9ltr 5spd in progress
dt466man22 is offline
Old 07-07-2005, 01:02 PM   #7 (permalink)
[img]/ubbthreads/images/graemlins/biggrin.gif[/img] dt do you sit and watch this extrememly large man climb in his truck everyday or what? j/k but wow 525 is a very big number i wouldnt joke around in his class...back on topic my truck is equipped with a tilt wheel and has about an inch of play up and down its horrible, so re-tightening bolts may be a fix? thanks
1989 F-250: supercab, long bed, 4x4, 5 speed,3.55's up front and rear, turned up pump,Pyro ofcourse!, custom stack, homemade lpg fumigation, more too come...At CSU, the black beauty is for sale...
nickbf2504x4 is offline
