Old 02-27-2006, 09:07 PM   #1 (permalink)
well it running now''''BUT
frist i would like to thank Pete and everyone else that has help me with this truck getting it back up. well the new cam is in have all back toghter it started after 6 trys of bleeding off the air but its alive [img]/ubbthreads/images/graemlins/phoney.gif[/img] but now it sounds like i have a dead hole i am getting a puffing sound it may be a bad injector i hope it is blowing some black smoke when i get on it but stops after a sec or 2 and i do have a leak in fuel line somewere have small puddle under the truck but for setting for over a year in nevada i know i am going to have to replace some lines and o rings. so if there is anymore advice on what i should look at for the miss or if i should try to adjust the pump or what else i should do i would be thank full this is my frist diesel and boy am i getting to know it well [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
thanks John
1990 F250 4x4 Xcab long wheel 7.3L 123,000 miles
jhcfun is offline
Old 02-27-2006, 10:17 PM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: well it running now''''BUT
If you can isolate the puff to one cylinder, you may want to remove the valve cover and inspect the rocker/assy for bent push rod. Did you adjust the timing at all.....black usually means too far advanced. Have you got clean fuel and filter with a healthy dose of additives. When engine is just started cold, remove the timing advance wire, listen and watch for smoke, tell us results.
Proud Canadian BOOB man too!!
cdnsarguy is online now
Old 02-28-2006, 02:03 PM   #3 (permalink)
Find and fix the source of the puddle and try cracking the injector lines open to see if the miss goes away.
Allen
93 F250, regular cab, 4x4, 7.3 NA, ZF5, 3.55, 209k miles, came home 2/28/06, soon to be turbo.
92 250, regular cab, 4x4, 7.3 NA, E4OD, 3.55, 316k miles, came home 8/28/04, aluminium 16x7 wheels, 285/75/16 Sport King AT.
89 250, extended cab, 4x4, 7.3, ATS wastegated, 5" straight pipe, hand shaker, 4.10, slightly toasted, waiting for a new cab and front end, came home 12/24/04
aaklingler is offline
Old 02-28-2006, 07:08 PM   #4 (permalink)
I wouldn't say I had a miss till teh fuel leak was fixed adn the truck ahd been driven gentlya few miles to purge all teh air out. AFter that, if youc an isolate a dead cylinder, first swap that injector to one you know is firing and see if the miss stays with teh piston or follows teh injector. Now you can isolate a miss this way...crack the injector line about 45* or slightly more with the engine running at idle. You should notice a significant RPM drop at every cylinder, which should be approximately the same. If one cylinder's fuel is taken away and it makes no difference...it has a dead injector or bigger internal problems. If fixing teh leaks and teh injectors doesn't work, pull the valve cover and check out the suspect cylinder. Borken valve srings, bent push rods, and dropped valves were not uncommon with 7.3s due to insufficient oil changes or lack of lubrication due to positive valve seal design. Have a great day.
J.D.
J.D.'s Fords: 1986 F-250 6.9 diesel Solid State Glow Plug System 3.55 gears C-6 2WD 178,960 miles.... it still runs pretty good!
Wishlist H-max turbo, T19 tranny,
1989 Ford Ranger ga$$er, non runner, soon to be donated or scrapped!
jdkline is offline
Old 02-28-2006, 09:20 PM   #5 (permalink)
ok i removed the timeing advance wire and could tell no differenc in it was getting some wite some today, did find leak it was the line from filter to pump did run a little better after that and have not put new filter on yet both tanks have fuel in them but did put a half of gal of lucas in each tank and will try checking for miss the way yall told me and let yall know thanks for all the help
jhcfun is offline
Old 03-03-2006, 09:57 PM   #6 (permalink)
ok i checked all the injector and could not find dead one all coused power to drop have new fuel in it now starting to run a little better but still have that puffing sound and blowing black when i get on it going to try and turn down the pump in the moring and see if that help now that i have it at the house
jhcfun is offline
Old 03-03-2006, 10:08 PM   #7 (permalink)
also befor i do this let me ask i turn the screw to the driver side to turn it down right thanks john
jhcfun is offline
Old 03-04-2006, 12:01 AM   #8 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Visit ziggster's page.......http://www.members.shaw.ca/k2pilot/ he has the directions.
Old 03-04-2006, 12:16 AM   #9 (permalink)
thanks i think i can do it lol dont think i can hurt it anymore
jhcfun is offline
Old 03-04-2006, 02:11 AM   #10 (permalink)
greetings have you set the timing static at 0 and does the truck rattle very loud
is there a elect timing advance wire i haven't ever seen 1
you can also test the timing advance of the pump by excellerate the motor to around 1400 and with a long screwdriver mechanically push in the lever on the drivers side of the pump that is the timing advance unit it should change if it does not you got a problem in the pump
if it does it took you 2sec
also make sure you get the spring back in the lever if it falls out
a dab of grease will hold it in place until you get back on the sping and throttle lever
MINE 95 f350,cc,4x4,7.3psd,e40d,3" to 4"down pipe ,5" straight exhaust,afe stg 2 intake,byron eddins elect fuel system,cobalt oil,boost,pyro,trans temp gauges,bpd stg1 injectors, 17deg hpop and 96 resavoir mod, 3.55 gears rear Limited slip , rear air ride suspension ,front add a leafs ,crank case vent mod,hughes cast trans pan,sonnax valve and superior steel accum valves, tony wildman 4 pos. chip, ported turbo and modded pedestal, 6.0 ic with custom 3" intakes and pipe, custom byron eddins 4 line oilsystem with no check valves in hpop ,119,000mi and counting
HERS 95,f350,cc,4x4,7.3 psd,e40d,3" dp,4" exhaust with donaldson muffler,k&n in factory cleaner,tymar hpx,fpr shimmed,fuel heater removed,flapper removed from turbo and modified pedesta, tony wildman 4 pos chip,150000 mi and counting
boys
96 f350 cc/4x4 centurion, 7.3psd, 4" lift , e40d, fuel heater removed,fpr shimmed,ccmod, 150000 and counting
glassbed is offline
Old 03-04-2006, 02:30 AM   #11 (permalink)
tks for info turner i can try that i got this trk last year and it looks as they doctered to sell i get put new cam in and set all the marks but befor it droke down last year it was blowing black real bad and had no power on the hills that is why i think they have set the pump up hi on it it start real easy not a lot of rattle only a puffing sound like hitting on dead hole but when i checked it looks as if it is fireing on all 8 but will try like you said only take a few sec to see thanks john
jhcfun is offline
Old 03-18-2006, 03:18 AM   #12 (permalink)
just a update got all toghter run a little ruff useing a lot of fuel thank it may be time for new pump but from what i have read on here 132000 miles on it sould replace but other than that it runs good passed smog with no smoke now the next thing i need to do is have tran checked it dose not want to go into overdrive at high speeds but shifts fine in town may be something easy i hope but thanks for all the help john
jhcfun is offline
Old 03-18-2006, 07:53 PM   #13 (permalink)
Have you checked your fipl? Have you changed your fluid and filter lately? Does your speedo and tach work flawlessly?
Allen
Old 03-18-2006, 11:22 PM   #14 (permalink)
cdnsarguy's Avatar
My Photos: (66)
You say trans does not go into OD at high speeds, have you tried gently applying the brakes while driving to see if the RPMs go up 200-300 rpm indicating the OD is unlocked when brakes applied as required.
Old 03-19-2006, 02:45 AM   #15 (permalink)
ok i am a dummy what is fipl??? tack and speed work i was going to take it in to have fluid and filter changed but was told that if i was haveing troulple with tran that would make it worse ?? wanted to ask here frist to see if that ture or not and pete no i will try that and post ,,, on freeway at 65 to 70 it is tacking at 2500 to 3000 when i let off the fuel it will shift or feels like it after a few sec thanks john
jhcfun is offline
