What batteries are best for the 7.3? - Diesel Forum - TheDieselStop.com
post #1 of 31 (permalink) Old 11-21-2009, 11:19 AM Thread Starter
I took Big Ugly for a spin around the block and couldn't get it to start after I stopped for some game day essentials (Go Blue!). I knew the batteries were getting weak but this shows they have to be replaced before the winter really starts. I usually get Craftsman Die Hards for my cars. Is there any brand that works better for these trucks? What type should I use, just in case the battery guys aren't sure what should be used on this dinosaur?
PS- We got the truck to start again when my father tried hooking up our travel battery and and his Honda Civic to the left battery at the same time. It was a great day for the little Honda, starting a 7.3 diesel off of it's mighty 1.7 gasser.
My beasts:
1989 F350 XL Jasper 7.3 IDI non-turbo. Auto, RWD, dually, 12ft box, ugly as hell! We call it Big Ugly.
1999 F250 XL 5.4 Triton. Auto, 4x4, my "pretty" truck.
JH3Rob is offline
post #2 of 31 (permalink) Old 11-21-2009, 12:22 PM
chuckster57's Avatar
I have two Costco batteries in my truck. Important thing to remember is 850 CCA min. and clean the cable ends.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #3 of 31 (permalink) Old 11-21-2009, 04:00 PM Thread Starter
Thanks Chuck, I'll keep that in mind.
My beasts:
JH3Rob is offline
post #4 of 31 (permalink) Old 11-21-2009, 04:23 PM
I just bought another set Motorcraft brand at the Stealership.
3 year free replacement warranty with your original receipt. I got a free pair on my first purchase (2 1/2 years into it), then 2 years after that, my free set went down with the alternator failure last month.
I just threw down real $$ for a new set, I think my discounted battery price was $97 each. I got a discount just by telling a long winded story about the batteries failing on the return side of a camping trip and not being able to find my receipt. Receipt would have only shown that I bought them 4.5 years ago
--Hugh
91' F-250, 2WD, 7.3 L, 4.10, 5 speed, single cab, 175,000 miles.
Santa Cruz, CA
waterdude007 is offline
post #5 of 31 (permalink) Old 11-21-2009, 04:26 PM
trampsdieseltruck's Avatar
My Photos: (33)
I bought a pair of 1000ca at Tractor Supply on sale,they came with a 2 year full replacement
1992 f250 7.3 nonturbo,4x4 360,000km,auto tranny
trampsdieseltruck is offline
post #6 of 31 (permalink) Old 11-22-2009, 12:28 AM
My Photos: (10)
I did the Costco thing too. I would do a general internet search on batteries and then decide from there (cost). Someone correct me if I'm wrong, but I think I remember hearing that there are really only like three different battery manufacturers out there, and they manufacture all of the batteries under different labels.
92 F350 XLT Crewcab dually, 225K miles ATS turbo, 4 inch exhaust, fresh IP & new matched BB injectors, Holly Red pump, K&N, E40D, 2 aux coolers, A-pillar guages, 410 limited-slip rear, Rancho 9000s, towing package, full running boards, mud flaps, 94' Ford (Alcoa) aluminum wheels, Predator camper shell, 600 watts of Sony/Boston Acoustics! Complete engine rebuild at 176k miles. Ford reman E4OD at 204k miles.
2001 Komfort 26FS
Fozz is offline
post #7 of 31 (permalink) Old 11-22-2009, 11:39 AM
My truck requires "Group 65" batteries.
'93 F-250 IDI, 4x4, K&N, no soup bowl, stock, with 265,XXX miles 5 speed, 3.55, kind of new LUK clutch, runs great, starts great, it is great. The truck is getting old.
BuilderBob is offline
post #8 of 31 (permalink) Old 11-22-2009, 11:51 AM
I have heard the same thing, something about the handling of the lead. The P.O. put costco batteries in about 1 month before I bought it. That was about 20 months ago.
Train Horns:
post #9 of 31 (permalink) Old 11-22-2009, 12:16 PM
If it a group 65, and has atleast 825 CCA or better, it pretty much will work just fine. I run a couple newer gold tops from Autozone, and have in other trucks. They treat me fine, and come with a 3 year replacement warranty. That being said, I also use costco batteries, or any other battery for that matter. It's been a long time since I have gotten a bad one from a big box store or major auto parts store, they are all pretty good now.
1992 F350 Crew Cab 4x4 7.3l IDI E4OD No Turbo
1993 F350 Crew Cab 4x4 7.3l IDI E4OD No Turbo
1990 F250 Super Cab 2x4 7.3l IDI E4OD Utility bed
1987 E250 Quadravan 4x4 6.9 IDI C6 Banks Turbo, Gearvendor, and U.S. Gear Exhaust Brake
DragRag is offline
post #10 of 31 (permalink) Old 11-23-2009, 02:12 AM
Sometimes we have to do things to keep running....
...but the guy I buy my starters from swears the worst thing for our starters is low voltage....
1993 F350 XLT Crew Cab 4x4 factory turbo diesel, 5-spd, 4.10s w/towing package, bench seats (fits family), white paint, sprayed bedliner, "Rackit" lumber rack.
This was exactly the truck I was looking for...
now 327,000 miles & 8 yrs (bought with factory remanufactured engine @ 119K miles)
14.5 mpg @ 65 mph cruise control & AC
Casually looking for a good used (secondary) overdrive....
Real trucks don't have spark plugs!
-Guy-
Escondido, CA
GuyW is offline
post #11 of 31 (permalink) Old 11-23-2009, 07:08 AM
NH2112's Avatar
Send a message via MSN to NH2112 Send a message via Yahoo to NH2112
Volts go low, amps go high, amps mean heat, heat kills starters.
Phil
Check my lists of common part numbers in my photos! Updated often!
1991 F350 Lariat XLT, 7.3l, 5-speed, crew cab, SRW, 3.55, 2WD.
1990 Jeep Wrangler Sahara, in the process of a major overhaul/upgrade. OM617 on the horizon! Front & rear Dana 44s from a Wagoneer till I get some 1-ton axles built & narrowed, and eventually a front shackle reversal. Diesel YJ, bay-BEE, and not a cookie-cutter 4BT conversion!
NH2112 is offline
post #12 of 31 (permalink) Old 11-23-2009, 07:17 AM
fddriver2's Avatar
Me too, group 65 fitment 4, 1000 amps, 850 CCA. 3 year replacement, 100 month prorated, $72 after core return.
I have a philosophy? Who knew. Ok, where's the beer?
2002 F-250 XLT CC SB\HPX\ITP prepump mod\Harpoon\DI 65psi fuel shim\4" SS turbo back Magnaflow\Fumoto\FTVB\Edge Evolution2\Zoodad\2008 Diff cover\V-10 Transmission cooler
fddriver2 is offline
post #13 of 31 (permalink) Old 11-23-2009, 07:36 PM
StrokerSmoker7.3's Avatar
What were they a piece? On the original subject, I've had nothing but excellent performance from Interstate. They seem to last a long time and run strong
1989 F-250 4X4 C-6 7.3 IDI, 4.10 SRW, Cobra 148GTL, 4ft bed mounted whips, 12" Powerbass sub, 600W Powerbass amp, Sony Headunit, GPC override(thanks M.L.S.C), Factory Ford aluminum rims from OBS PSD, 4" exhaust, no soupbowl, B&M shift kit
1997 F-350 4X4 E4OD 7.3 Powerstroke, 3.55 SRW. 3"DP to 4" exhaust, TS performance 6pos. chip, Quadzilla Recon XGT, DIY Tymar style intake, Atwood fiberglass cap
StrokerSmoker7.3 is offline
post #14 of 31 (permalink) Old 11-25-2009, 10:52 PM
i have optima deep cycles on mine
1991 F350 7.3 idi, 5 speed, 4x4, SRW, 180000, reg cab, banks turbo kit, rebuilt injection pump, 6 inch turnout stacks ...
deere55 is offline
post #15 of 31 (permalink) Old 11-26-2009, 08:59 AM
Optimas are great batteries. but the biggest downfall is their price. Very expensive compared to a Costco or the like.
