Old 03-21-2005, 11:43 PM   #1 (permalink)
What to do about front springs sagging?
I was under my truck installing my new superwhamdiddly battery cable and noticed that at rest, my springs were about an inch and a half from the bump stops. I quick search on here showed several threads about that but I couldnt draw any conclusions about what to do. Should I get an addaleaf, new springs, springs from a different year, the snow plow leaf option or have mine rearched? I think I can run 35" tires with a little bumper shimming and some better springs, the back seems to have enough clearance already.
89 250, 4x4 chromespoke wheels, 270000k, 4.10 gears with rear LS. stock everything else. Its loud, and smokes, but its paid for!
sawyer89 is offline
Old 03-21-2005, 11:49 PM   #2 (permalink)
Posts: n/a
Re: What to do about front springs sagging?
In all seriousness, to cure the sagging requires new extra heavy duty springs. Yes, you can put addaleaves in to raise the front back up, but the don't move the spring away from the bumpstop, so that doesn't help you out. Also, getting used springs from a different truck means you're getting used ones that are starting to sag also. It all depends on how much money you want to spend, how long you'll keep the truck, and if you want to clear big tires without a lift.
Old 03-22-2005, 07:06 AM   #3 (permalink)
how much are springs?
American by birth, Southern by the grace of God!
1991 F250 7.3l 200XXX extended cab long bed. 3.55's REDNECKED OUT!! 295/75/16 Bfg All Terrains 16 in billet rims. New front brake pads and rotors, rear shoes, glow plug controller, glow plugs, return line kit duralast batteries, mitubishi off set gear redution starter, altenator, valve cover seals, holley red pump,new injector pump, soon to be new injectors, new vacum pump. Removed soup bowl and drilled holes in air intake.
http://community.webshots.com/user/r0oster06
R0oster06 is offline
Old 03-22-2005, 08:53 AM   #4 (permalink)
sawyer89...I have a brand new set of front springs that I bought from ESPO springs for my 93 F250 4X4. However, I sold the truck before putting the springs on. Paid $270 plus $65 shipping. Will take $200. They came with bushings in both spring ends. Still have the shipping wrapping on them. Spring Code 9A. I live in Hiddenite, NC. This is 60 miles north of Charlotte and 20 miles West of Statesville.
2001 F350 4X4, SC, Lariat, DRW, JEG'S 4" all the way including downpipe. Chrome 5" tip. Tymar Air Intake, Ungraded turbo wheel, Go Industries Mud Flaps with anti-sail bars, Putco Boss Running boards & Box boards, Putco Polished Grill Insert, Weathertec Rain Deflectors, Lund Bug Shield, Delta Deep Well Tool Box, Bed Liner & Bed Mat. Tough Country 2" lift front, blocks rear, Rancho RSX Shocks, Superchips Tuned, Di Pricol Gauges in underdash pod. 1989 F350 4X2 STOCK 7.3, Jasper E4OD, 10' electric dump, 5th wheel hitch, rear hitch, underbody toolbox, simulators, K&N, Flowmaster. Formally a paramedic unit in adjoining county.
dmachine is offline
Old 03-22-2005, 10:36 AM   #5 (permalink)
let me get back to you on that.
sawyer89 is offline
Old 03-22-2005, 12:03 PM   #6 (permalink)
since he was first if he passes up on your offer illl gladly take them off of your hand
-jeremy roooster!
Old 03-22-2005, 03:23 PM   #7 (permalink)
Firestone air bags get the springs off the bump stop and are adjustable. Mine leveled the front end and provide a nice ride. About $225.. [img]/ubbthreads/images/graemlins/grin.gif[/img]
.02
93f250 XLT 7.3 IDI Turbo,zf,4x4,182k,e-cab,LB, front airbags, no muffler.'06 KTM450SMR,'04 BMW R1150GS, '99 TLR1000,'95 KX500 and more pedal and motor bikes
moburki is offline
Old 03-22-2005, 10:08 PM   #8 (permalink)
Ill pass on the springs, the airbags sound pretty good. Im still debating a lift kit.
sawyer89 is offline
Old 03-22-2005, 10:23 PM   #9 (permalink)
dmachine...how do you like those springs from ESPO? I just visited their website. Seems like the only place on the web that really has a complete listing of trucks and leaf springs....particularly for our trucks. Did you get the OEM or poly bushings?
Bob E.
93 F-250 4x4, EOD4, Optima Red Tops(group 34/78), ATS turbo mod, custom grill guard, custom headache rack and bed rails.
safetybob is offline
Old 03-23-2005, 06:36 PM   #10 (permalink)
Bob E.
Bob...I did not install the springs cause I sold the truck before I got them installed. They came with OEM bushings in spring ends. I was pretty impressed with ESPO. Like you say, they seem to have a lotta stuff for our trucks.
dmachine is offline
Old 03-27-2005, 11:55 AM   #11 (permalink)
The Firestone air bags might be just what I need for my 1989 F350 bucket truck. It bottoms out everytime I hit a bump in the road.
Would someone help me with these questions?
1. Where do I get them? There are no Firestone dealer in our town.
2. How easy/difficult is it to install them? Do I need special
tools?
3. Does the air bags have to be replaced when they get old and elastic material starts cracking? For the money, will the steel leaves outlast the air bags?
rrzrr is offline
Old 03-27-2005, 12:23 PM   #12 (permalink)
Can't help with 1 and 2, but having driven trucks with air ride for several years I might shed some light on #3. Usually air bags are made out of rubber and last quite awhile. On something like your truck where they are assisting the stock leafs, I wouldn't be surprised if they outlast the truck. On big trucks the usual repairs aren't to the bags themselves, but to the hardware that attaches to them. The fittings going into the bags, the valve that regulates the height, the plastic hoses...etc.
One thing to watch out for. If you do install them and raise the front end back to stock height, get your alignment done. If it has been aligned while in the process of sagging, then you raise it back up, it will be off.
By the way...where are you? If you're in the northwest, Les Schwab tires advertises a air bag kit that may work for you...
My pics...
Sorry to all the loyal 7.3 guys, but I traded my '91 7.3 in on a 2002 F250 Ex cab V10 4x4. SCT Xcalibrator2 with tunes by Powerplay Performance. 285/75/16 Toyo M/T's. Took a long time to get used to the ping-pop of a cooling catalytic converter...LOL.
'85 Bronco swapped up to a 302 4bbl from the 300 I6, NP435 4spd, NP208, 32x11.50x15 Radial RVT's, Soon to be 6.9 turbo powered.
86 F350 Cab&Chassis with a dump bed. 2wd 6.9 and 4 spd tranny. No mods to engine.
2000 Volvo 660 N14 Cummins, 500hp 1650 ft lbs, Autoshift tranny 10spd.
What part of "SHALL NOT INFRINGE" do you NOT understand?
aceohearts is offline
Old 03-27-2005, 06:15 PM   #13 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Visit the Ride Rite web page tells you everything.
Proud Canadian BOOB man too!!
cdnsarguy is online now
Old 03-28-2005, 04:18 PM   #14 (permalink)
Installation is easy, technically. It does require you to drill four 1/2 inch holes in youre frame, thats the hardest part. With my 1/2 inch drive Makita, it took me about 40 minutes for the first two, and 30 minutes for the second two (got my elbow feed and speed down). I'm running about 60 psi in them right now, and I immediately felt a ride quality change for the better, little or no bottoming.
moburki is offline
