Old 06-01-2005, 11:51 PM   #1 (permalink)
What the Frick!! why is my pm temp so hot all the time
hey all again, just to recap, I know I should put it in my signature, but anyway, 1992 7.3, with ats turbo, and 3" exhaust, and a 5 speed and 4.11 gears, I live in colorado so anywhere i go there are hills, now for the scenario
take off from a light, get on the truck pretty hard, black smoke at first(normal I assume) but I can only achieve 8 psi no matter how hard i try, and this doesn't happen till like 2500 rpm or more, in fact at 2000 rpm, I get no boost, even when cruising and I jump on the gas at 2000 I get no boost, all that happens is more black smoke and my pm shoots through the roof, unloaded in town, I can hit 1000-1100 if I want, and I am not even really going all that fast, I feel as if the turbo isn't really working all that well
scenario 2) total maybe 5000 extra #'s slight hill maybe 5% or so, and in order to keep a steady speed of 40 or 65 or whatever you obviously need to give a little more gas, now once again the pm shoots up there in about no time and I have to back of the gas, thus slowing me down and thus defeating the purpose of a turbo diesel
to sum it up, pm are really high I think, maybe this is normal, but it seems that is the last concern of other people, and low boost I think again, not sure this is the only idi I have ever been in, maybe this is normal, if so, i am very un satisfied with the ole idi setup
is all the black smoke extra fuel, I mean is the pump turned up too much or something or what is the deal?
tanks in advance
Dustin
1992 f-250, 7.3 litre with ats turbo upgrade and 3" exhaust. 5 speed manual tranny, 4.11 rear end, thats all I know right now (sold)
1996 Ford Bronco Eddie Bauer with a stock 96 powerstroke, e40d with shift kit and "HD" torque converter, 3" LIFT, 35 BFG MUDS
chinaman is offline
Old 06-01-2005, 11:57 PM   #2 (permalink)
rawpower's Avatar
Re: What the Frick!! why is my pm temp so hot all the time
Black smoke is unburned fuel. You should have a little bit when you lay down hard on it...
Yeah, Ive always heard the complaints of not getting good enough boost soon enough...
If you tow often, i really dont know what to do. If not, Id turn it up to 12 psi max.
someone else will be of better help
1993 Ford F350 7.3L Turbo Diesel ZF S5-42, Divorced TS NP205, OEM locker/welded 2.5 ton Rockwells, 46" Michelin XML's, and some stuff too.
http://www.supermotors.org/users/RAW_POWER
rawpower is offline
Old 06-02-2005, 10:59 AM   #3 (permalink)
Sounds like your turbo's wastegate is stuck open, or possibly a bad turbo.
Your problem isn't the fuel, but that the turbo isn't boosting, so that you are in effect overfueling since you don't have the extra air.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 06-02-2005, 01:28 PM   #4 (permalink)
How long has it been since you changed or cleaned the air filter?
icanfixall is offline
Old 06-02-2005, 02:51 PM   #5 (permalink)
My Photos: (23)
How do you know your boost gauge is accurate? Maybe the line is cracked.
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, DPS Injectors, Hypermax Turbo, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
