what kind of antifreeze? - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 09-11-2008, 12:53 PM Thread Starter
hey guys what kind of antifreeze can i use with suplimental additive that wont hurt anything?
thanks,
jimmy
PS i normally always get my antifreeze from wallmart. please let me know
1994 extcab f-250 7.3 factory turbo into 6 inch turnout stacks. fuel turned up and stage 1 injectors.
1993 f-250 5.9 cummins installed now in it with zf 5 speed
1990 f-350 4x4 4 speed tranny, meyers 8 foot plow, alluminum dump bed. non turbo 7.3 all stock.
94extcabf250diesel is offline
post #2 of 9 (permalink) Old 09-11-2008, 01:10 PM
jstrauss's Avatar
I bought Fleet Charge brand at Tractor Supply and it already had the Pencool SCA in it.
1991 F150 SC 4x4 7.5L/ZF5
1991 SAE Bronco 7.3L IDI NA/ZF5
1974 F350 Tow Truck 360/T18
2005 Escape 2.3L/CD4E
jstrauss is offline
post #3 of 9 (permalink) Old 09-11-2008, 01:16 PM
Snotzalot's Avatar
My Photos: (5)
Any low silicate "green" colored antifreeze. If the jug says "Cat" Diesel Rated etc, it's fine to use. (Cat means Caterpillar Engine, etc)
Regards,
Paul - Pocono Mtns. USA
02 E350 15 Passenger Cream Puff, 92,000 Miles, 5.4L Gasser
'90 E350 7.3L Ex-Ambulance High Top 420K Miles, No Turbo, Stock Stock stock, No ELC! (Extended Life Coolant) & 10 Oz. Bars Stop Leak. 10 wonderful cool years using Freeze12 without any AC system modifications. Retired with blown trans.
Snotzalot is offline
post #4 of 9 (permalink) Old 09-11-2008, 04:01 PM
hesutton's Avatar
My Photos: (30)
Plus 2 on the low silicate ethylene glycol (green) coolant. Don't forget the DCA-4. To know how much and how to check the level CLICK HERE!
Heath
1986 F250HD 4x4 7.3L IDI '95 PSD front clip, '97 bed, T19, D60/10.25 with 3.55's. Rebuilt from the frame up. Banks Turbo, DPS IP & Stage 1's, Isspro TTM, Banks Exhaust, Boost gauge, Pyrometer, Precharged Coolant Filter,
. 16.5 x 37 x 12.5 Goodyear Wrangler's, Air Horns. 6in lift, Fresh Paint, On-board Air. Revamped Interior. Rhino Liner.
1983 F250 4x4 5.0L with C6. 340,000+ miles.
hesutton is offline
post #5 of 9 (permalink) Old 09-11-2008, 05:56 PM
hello all im new here but i have a 93 7.3 non turbo and i just got done puttin a new thermostat..waterpump..belt and idler ...and i put a used clutch fan..but my question is the temp gauge fluxuates up and down like pretty quickly and at idle with the air on it overheats...but when i put the radiator back in i just put water becouse all my antifreeze is at a buddys house and its really warm here now.....what do i need for antifreeze i didnt know they took a spacial antifreeze ....thanks alot
Kyle
newhavenmotorsports is offline
post #6 of 9 (permalink) Old 09-11-2008, 11:29 PM
Cjhstang's Avatar
is your rad full? if it doesn't have enough fluid in it the thermostat might be hitting air pockets messing with the reading. do a search for sca's on this site. it will tell you all about antifreeze requirements for these engines to prevent cavitation...
F-350 4x4 1990
-'94 overhauled 5.9 Cummins
P7100 Injection Pump w/ 4kgsk, 60lb valve springs, Hamilton performance cam, HX40 turbo, ARP head studs, New marine pistons and injectors, FASS system lift pump
-Homemade oem & engine harness with Dual electric fans
-'92 interior; '86 front clip; '04 Hydroboosted front and rear disc brake system; Slew of autometer gauges; dual 4.25" Stacks
-Rebuilt and upgraded my E4OD - billet input shaft and T.C. Remote mount Derale dual layer trans cooler; Baumann Trans Controller and Harness
-3" Body Lift, Cut-Out Bushwacker Fender Flares with 16x10 Eagle Alloy 186 on 33's
All done in the driveway and basement...
Cjhstang is offline
post #7 of 9 (permalink) Old 09-12-2008, 05:52 AM
Snotzalot's Avatar
My Photos: (5)
This engine can be a bit of trouble to bleed properly, I use a T in one of my heater lines to help bleed.. Any engine needs antifreeze to help keep it from boiling over, antifreeze raises the boiling point. Also, all diesels and especially the 7.3 needs SCA's to prevent cavitation.
Regards,
post #8 of 9 (permalink) Old 09-12-2008, 07:31 AM
Ok Thanks guys i forgot to mention in my previous post that ive been reading this post for awhile...around here where i live these truck are given a bad name i guess i could say ...but this thing is a pretty neat peice i drive the balls off of it and have had it for 2 years its got 252k miles and if it aint pulling a 20ft trailor loaded to the gills..its gitting drove thru watever it finds and i never really take it easy on it and when i seen this web site i got a chubby...haha but thanks for the info i think my problem is air in the system.. but im getting the anti freeze today ..i work at a coal mine and they use some weird anti freeze in tha rides and they said its made for diesels so im sure its cool but thanks
Kyle
post #9 of 9 (permalink) Old 09-13-2008, 12:15 AM
JASTECH's Avatar
My Photos: (16)
I hope this will help somebody?
Until recently, the color of the most commonly used antifreezes for both light duty
and heavy-duty engine cooling systems was predominately green. Its change
interval is normally about every two years or 30,000 miles (50,000 km) of use.
Then, long life (LLC) / extended life (ELC) coolant / antifreeze was introduced in
an effort to reduce maintenance costs, downtime and environmental disposal
costs and issues. With the introduction of this totally new concept, antifreeze
manufacturers wanted to differentiate this new product from existing antifreezes.
To accomplish this, they introduced different colored dyes for their LLC / ELC
products. Orange and red dyes were used first; now it appears there may be
virtually no limit to the different dye colors that may be used.
The purpose of this bulletin is to describe the dye colors currently available, the
chemical technologies being used and which vehicle manufacturers are using
which technology based on the information that is readily available at the time
this bulletin was published. The member companies of the FMC are confident
this issue is not static and new technologies and dye colors will continue to be
introduced in the future.
Antifreeze is used in cooling systems to both lower the freeze point of water and
raise its boiling point. It is also used as a carrier for different types of additives
such as sodium silicate to protect aluminum from corrosion, anti-foaming agents
and other corrosion inhibitors. Although straight antifreeze actually freezes and
boils quicker than tap water, when mixed with water in the proper proportions (a
50% / 50% mix is ideal) in a cooling system, it greatly increases the cooling
system's ability to perform its designed function of removing heat from critical
engine parts and to enhance the service life of the various cooling system
components.
Inorganic Acid Technology (IAT) is the chemical composition for the traditional
antifreezes that are green in color. An IAT can be used with either ethylene glycol
(EG) or propylene glycol (PG). The normal IAT service life is two years or 30,000
miles (50,000 km).
Organic Acid Technology (OAT) was the first LLC / ELC introduced in North
America in 1994. OAT antifreeze had been widely used in Europe before its
introduction in North America. OAT can be either EG or PG but is mostly EG
based. Its first dye colors were orange and red. These dye colors are still used by
General Motors and Caterpillar. Green, pink and blue have been added to the list
April 2005
Page 2 of 2
of available OAT antifreezes. It is recommended that OAT not be mixed with any
other antifreeze technology. The normal OAT antifreeze service life is 5 years or
150,000 miles (250,000 km).
Hybrid Organic Acid Technology (HOAT) is a combination of IAT and OAT with
nitrites added. This makes HOAT suitable for use in both light duty and heavy
duty systems. Currently, two manufacturers are using HOAT for their vehicles.
Daimler/Chrysler's version is dyed orange and contains 10% recycled antifreeze.
Ford Motor Company’s version is dyed yellow and does not contain any recycled
antifreeze. Both of these HOAT antifreezes use the marketing designator of GO-
5. They are compatible with each other but mixing them with IAT or OAT is not
recommended. The normal HOAT antifreeze service life is 5 years or 150,000
miles (250,000 km).
Nitrated Organic Acid Technology (NOAT) is an OAT with nitrates added. This
makes NOAT also suitable for use in both light duty and heavy duty systems.
NOAT and HOAT are very similar in performance characteristics. Currently, no
OEM vehicle manufacturer is using NOAT. The normal NOAT service life is 5
years or 150,000 miles (250,000 km).
Since antifreeze is clear when it is manufactured, and water is clear, dye is used
to color the antifreeze for identification and marketing purposes. The color of
antifreeze is no longer an accurate indicator as to whether it is an IAT, OAT,
HOAT or NOAT formulation. Further, some antifreeze manufacturers market a
“universal” antifreeze they say is compatible with all OAT, HOAT and NOAT
formulations. These "universal" formulas are not for use with IAT and they will not
convert an IAT to an LLC/ELC antifreeze. Mixing IAT with OAT, HOAT or NOAT
antifreezes will not damage your vehicle’s cooling system; however the mixture
will negate the long life/extended life attributes of these formulations.
In conclusion, there are currently two oranges, two reds, green, dark green,
yellow, blue, blue-green, clear and pink dye colors available. With this variety of
dye colors and more to come, the service technician’s ability to properly service
and maintain light duty and heavy duty cooling systems properly will be greatly
challenged. It is imperative the technician be fully aware of what the vehicle
manufacturers' requirements for antifreeze are and those recommendations be
carefully followed. For further information regarding cooling system maintenance,
refer to TSB's 88-1R3, 89-1R2, 97-2 and 02-1.
For additional information, contact:
Filter Manufacturers Council
P.O. Box 13966
Research Triangle Park, NC 27709-3966
Phone: 919/406-8817 Fax: 919/406-1306
Filter Manufacturers Council - Home
Administered by Motor & Equipment Manufacturers
1988 F350 7.3L Diesel Crew Cab 5spd, 200k+ miles
1980's F250 Cab w/doors, Dash, New Pw/Brk Booster,
sanded and primered Grey [B]For Sale BO
1973 International Scout II
Chevy 350 30over, 4-Bolt main, SS Valves, MSD Ignition, Comp 9000 Dist, Edelbrock Manifold/
Carb,
4" Suspension & 3" Body Lift, Dana Front/Rear/TC, TH400 w/Stage 2 kit, 33x12.5x15 BigO Mud tires.
1973 Jeep CJ5 (Project)
JASTECH is offline
