Old 04-27-2005, 08:19 PM   #1 (permalink)
What To And Not To Insulate (under the hood), That Is The Question!
Brothers,
As I look at the pictures posted by many, I see different insulation methods under the hood. I see a lot of added insulation on "stuff". What things should be insulated? What things like to be hot (probably nothing)? What things like to be cold (yes, I know intake air)?
Thanks,
John
P.S. "Got Boost?"
89, F-250 XLT Lariat 4x4, 7.3L w/96 Banks Sidewinder, 4.10 LS ZF 5 spd., RDT, 202K miles, LT235/85R16 Duler A/T "REVO"s, "She's leaking everywhere!".
J Haggerty is offline
Old 04-27-2005, 09:55 PM   #2 (permalink)
My Photos: (24)
Re: What To And Not To Insulate (under the hood), That Is The Question!
the big guys will direct you the right direction, bt i would protect hoses and cables from anything hot like the manifold heads etc. plus you dont want hoses rubbing agains nothing.
my 2c, exekiel
- 12/92 f350 jasper 7.3L 17k Torito
- Home made exekiel propane system, sweet
- Home made ram-air system
- 4.10 open, DRW
- zf5 trans (dextron and militec); 12" luk solid fly wheel and clutch set.
- exekiel coolant filter system (Fleet-guard filter and dca)
- ip runing with stanadyne every tank and Mels timed.
- Agnem manual tranns starting system :-)
- Hypermax turbocharger system YES Finally. Turned up a la Travis.
crew cab/ wood interiors/ 800w cd player. Sweet ;-)
2 new diamond headlights
4 100w flash lights and 2 withe fog lights
more pics
BOOB Man
soon..
- paint job.
exekiel69 is offline
Old 04-28-2005, 09:29 AM   #3 (permalink)
Some folks put a lot of insulation in there because they don't like the noise of the engine. I don't see a need for much insulation from a functional standpoint. I took the blanket off the inside of my hood cause it was torn and sagging and would get caught in the fan. It was a real PITA.
Perry
1992 F350 Crew Cab, 7.3l IDI, LWB, 4x4, E40D trans, 170,000 miles so far.
http://www.pbase.com/drz400/truck
perryg114 is offline
Old 04-28-2005, 10:44 AM   #4 (permalink)
My Photos: (23)
John, what is prompting your question? I've used starter insulation over my glow plug and throttle cables/wires under the turbo to protect them from the heat. Otherwise, no hood blanket and everything is nude.
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, DPS Injectors, Hypermax Turbo, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
Old 04-30-2005, 07:13 AM   #5 (permalink)
Mel,
Just looking at pictures and seeing guys doing different stuff with insulation. Is any or it of any real value?
John
P.S.- Sitting here Sat. A.M. and it's looking too wet for a visit to Gettysburg. What I really wanted to do was look under everyones hood. Looks too wet to "hang out under the hood". Plan B = replacement power steering pump, after all "She Leaks Everywhere".
Old 04-30-2005, 03:51 PM   #6 (permalink)
jdc753's Avatar
My Photos: (31)
Send a message via AIM to jdc753
I would think all electronics and wires and hoses should be insulated from the heat of the manifolds and stuff. But also I would think about trying to insulated the manifolds and exhaust flow to the turbo so that the heat inside the pipes is as hot as it can be and that way it should flow faster and add more power to the turbo. Also try and keep the intake side of the turbo insulated away from the heated side so that the intake charge is as cold and as dense as can be. I have thought about trying to make an open element system but with a heat shield around it like how you see on the cold air kits and stuff. Maybe use some of the manifold wrap stuff or get them ceramic coated or something so that the heat stays where it belongs in the pipes where it can do some good and not outside of the pipes where it can cause some damage. Oh yea and I am all for ditching the sound deadening on the hood, gotta have that diesel clatter [img]/ubbthreads/images/graemlins/smile.gif[/img] and the turbo whistle [img]/ubbthreads/images/graemlins/cool.gif[/img] just my 2 cents
86 Ford F250 4x4 with 4in Rough Country lift and poly bushings all around converted from 351W to 6.9L Diesel (rolling chassis at the moment)
05 F350
jdc753 is offline
