Re: What temp does the cold start solenoid activate?
It's warmer than 44 degrees. Mine kicks on when the truck has been sitting all day in 90 degree heat.
--motor/trans sold--
2000 VW Jetta TDI = 48+mpg
1997 Dodge 3500: 2WD Cab & Chassis, 12V Cummins, 47RE Automatic, Dana 80, 194,000mi. Parting out.
1989 12V VE Cummins out of Chevy C60? at the machine shop...going into the Ford.
For some reason, 112 deg f stands out in my head, I believe it kicks in below that and kicks out at 112....then again, maybe I'm going crazy [img]/forums/images/%%GRAEMLIN_URL%%/crazy.gif[/img]
------Robert
'92 F-350 7.3 5 spd, Crew Cab dually,ATS turbo, 4" Exhaust, Air seat, Western Hauler bed. My Gallery
The Engine Temperature Switch provides voltage to the Cold Timing Advance Solenoid and the Cold Idle Solenoid. When the engine temperature is below 112°F (44°C), the Engine Temperature Switch is closed. When the Ignition Switch is turned to START or RUN, the solenoids are energized, advancing injection pump timing and engine idle, allowing the engine to run more smoothly when cold. When the engine temperature reaches 112°F (44°C), the Engine Temperature Switch opens. This deenergizes the solenoids, returning the timing and idle to normal.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: PPrash</div><div class="ubbcode-body">Ah, good catch. I did not note the F/ C part. That makes sense. Also, does the fast idle solenoid energize with the A/C on like some engines do? </div></div>
No. The idle kick up is used on gassers with fairly low torque to keep the motor from dying with the extra load of the compressor.
im gonna say it right now, this is off topic,
but i think it is hilarious if your engine cant keep an ac compressor running unless it is running at a fast idle.
kevin
(mine) 94 7.3 IDI non-turbo XL 350 super cab long bed
autojet y pipe and a used p-stroke exhaust on the end of it 24xxxx miles, amsoil bypass, coolant filter
(dads) 02 350 7.3 powerstroke crew cab 4x4 ESOF
mods: itp in tank/prepump, 4 inch exhaust, ats housing, western diesel gauges, 6.0 transmission cooler, 6.0 Banks "technicooler" intercooler 150 bucks , coolant filter, "OEIS", b&w 5th wheel companion
18xxxx miles my gallery
WHY THE HELL SHOULD I HAVE TO PUSH 1 FOR ENGLISH? H O N D A - How Odd No Damn Acceleration
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">but i think it is hilarious if your engine cant keep an ac compressor running unless it is running at a fast idle.
</div></div>
If the engine is cold then consider the oil is cold and if fast idle is not used the engine has a hard time keeping itself going in most cases...... The A/C will kick in if the defrost is selected in the winter/cold just for lubrication of the system...
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: cdnsarguy</div><div class="ubbcode-body"> The A/C will kick in if the defrost is selected in the winter/cold just for lubrication of the system... </div></div> It must not be humid when it's cold where you are. Here the humidity is quite high making all the windows fog until the engine is warm enough to cook it off unless the A/C compressor engages.
