Now that I am done painting the truck parts are going back on including the emblems, what can be used to stick the 250XLT and turbodiesel tags back on the fenders?
Thanks,
-Rob
'94 F250 XLT 7.3L. Turbo Diesel 4X4 "OFF ROAD" package, X-Cab, 4.10 grears, Now a 5 speed, original IP, just did injectors,"Wallace mod" 3.5" turbo outlet housing and 3.5" DP and straight piped exhaust, 113K on the clock. Repainted it black. Ispro pyro and boost gauges, turned up pump.
Double side tape trimmed out neat with a razor blade will work but it takes a while to do it. There is some other stuff that is in strips that sticks on the emblem then the backing peels off and it makes the emblem sticky on the backside. It works real good but I can't remember the name of it other than it's made by 3M. Go to your local auto paint store and they should have something that will work.
SOLD....1994 Reg. cab F350 4x4, 7.3 turbo, E4od, 3.55 gears, DPS turbo cal pump, homemade 3-3.5 downpipe, 4 inch psd exhaust, 285/75 BFG's on factory wheels, isspro egt,boost,trans temp pillar mounted gauges
SOLD.... 2003 F 250 Reg Cab FX4,6.0 psd, torqshift auto, K&N intake, 4 inch exhaust, 315/75 tires on factory wheels
In my business we use a 3M tape called VHB, Very High Bond. It is two sided and a lot thinner than the double faced foam tape you see at Office Depot. I have to order it though a supplier. I'd hit the body shop supply store if I were in your shoes.
Thanks for the imput, I'll take a trip to the auto/paint store and maybe the hardware store.
Thanks,
-Rob
I too stand behind 3M yellow W/s Adhesive in a tube. Here in cold, well salted streets of Canada I have used it for 20 years without fail. [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Bob
My Pictures
1984 Bronco II 4x4 day to day driver : Winter
2005 Explorer Sportrac 4x4 day to day driver : Summer
1991 F350 / Crew cab , Engine 7.3,E4OD tranny. No Turbo but has propane and pyro gauge. The truck is American, complete with a Miles per Hour speedo. Digital trans. temp gauge and voltmeter. Front Captain seats. Control switches for DRL's , Fog lites, High speed idle, Engine kill and scene lites. On board " York " compressed air, Air horns and built in hose reel behind the rear seat. Power bar distribution box from a 1999 Ford Explorer . Checker plate running boards and Frieghtliner mud flaps. LED turn signals in the factory mirrors. DC to AC inverter to run the coffee maker <img src="/ubbthreads/images/graemlins/smile.gif" alt="" /> Soon to be updated with more toys as time & $$$ permit. <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
The glue that is used to glue windsheilds in works great, just need to use a primer on the badge and also on the paint. That stuff is tough, I just used it to glue the F550 badge on a 2000 I just finished putting back together........... Jim
<font color="blue">[b]93-F250 (Super Duty), Extended cab, Long Bed, XLT, Gray & Black, 7.3L, New Injector Pump, New Injectors 4X4, ZF5 5 speed trany, 4.10 gears Limted Slip.</font>
When the gasser was painted (if you can call it that) years ago, the badges I got from Ford had the factory addhesive material on the back. Just peel off and apply the badge. I guess the newer badges don't come with this adhesive eh? On the badges I has made for the project truck also came with an adhesive backing. Might want to give Steve at Billet Bages an email. I bet he can sell you some adhesive backing for your badges.
Heath
__________________ 1986 F250HD 4x4 7.3L IDI '95 PSD front clip, '97 bed, T19, D60/10.25 with 3.55's. Rebuilt from the frame up. Banks Turbo, DPS IP & Stage 1's, Isspro TTM, Banks Exhaust, Boost gauge, Pyrometer, Precharged Coolant Filter, Holley Red Pump. 16.5 x 37 x 12.5 Goodyear Wrangler's, Air Horns. 6in lift, Fresh Paint, On-board Air. Revamped Interior. Rhino Liner.
