If I am pulling a load with my truck, no turbo , up an incline and the truck slows down to 30 mph but my egt's are under 1000 what it the worst that can happen besides a bunch of pissed off people behind me ?? Would the truck actually stall or something assuming the engine and powertrain don't give out first. Or could it chugg-a-long for miles ?? If I had all the time in the world to get there would I be doing the truck any harm ??
Bob
My Pictures
1984 Bronco II 4x4 day to day driver : Winter
2005 Explorer Sportrac 4x4 day to day driver : Summer
1991 F350 / Crew cab , Engine 7.3,E4OD tranny. No Turbo but has propane and pyro gauge. The truck is American, complete with a Miles per Hour speedo. Digital trans. temp gauge and voltmeter. Front Captain seats. Control switches for DRL's , Fog lites, High speed idle, Engine kill and scene lites. On board " York " compressed air, Air horns and built in hose reel behind the rear seat. Power bar distribution box from a 1999 Ford Explorer . Checker plate running boards and Frieghtliner mud flaps. LED turn signals in the factory mirrors. DC to AC inverter to run the coffee maker <img src="/ubbthreads/images/graemlins/smile.gif" alt="" /> Soon to be updated with more toys as time & $$$ permit. <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Take O/D off when towing ANYTHING heavy. Keep the RPM's up around 2600 or so to prevent overheating. Keep it from lugging! Manually put it in 2nd or 1st if it lugs too much.
You dont wanna experience what happens when you max out your temp gauge. When i first got mine, didnt know squat about towing and neither did brother who was driving...we had a 7000# backhoe on the back on flat ground drove it like normal, black smoke billowing getting the trailer black and goin along "seemingly" fine. Dont remember what RPM's were..they were LOW though being as i turn 1500 at 55-60(we were going 45 or so. He asked if "this" was a problem...I looked over and temp gauge was pegged. Pulled over for 5 mins let it cool. Damage was already done..trans got a little hot from hot coolant and the front pump seal killed itself. Tranny fluid pouring on ground quickly and rentalmart people got mad at me for using offroad diesel because i asked for a wrench to tighten an injector line.LOL! No other damage besides a half full overflow reservoir. Took a lot of work to fix, through.
Thanks for your experience, I am just trying to decide if I should Turbo this truck before Turbo units are hard to get. I pull heavy once or twice a year. Maybe in the future I'll take the plunge and by a newer truck for towing but currently I luv this truck as is.
Bob
My Pictures
Before my '85 was turboed I'ld be loaded heavy creeping up the hills at 20-30 mph for many miles. Geared down to keep the rpm up of course. As long as all your temps and pressures stay in safe ranges it will pull like that all day long.
Used to pull a '50 3 car wedge up Donner with out a Turbo, glad those days are long gone.
Keith
2000 F350 Cab/Chassis CrewCab 4x4 DRW 7.3/auto "Hamilton Custom Cruiser Conversion" WesternHauler Bed 50gal TFI transfer tank 4" turbo back Exh. DIY intake w/Napa 6637
'88 F350 CrewCab SRW 4x4 7.3/C6/4.10LS Banks non-wastegated turbo NAPA 6637 airfilter 4" lift Airlift rear airbags 107k miles
'86 F250 ext cab. 4x4 6.9/C6/3.55 arrowcraft dually conversion 45gal aft tank ?53k miles
'85 F350 Cab/Chassis DRW 55" Schwalbe Sleeper 7.3/T-19, 4.10, Banks Sidewinder wastegated Turbo Holley red tweaked inj.pump 6.2 governor and STACKS! The old 6.9 gave up after 445k miles.Stacked before stacks were cool since 5/85 **SOLD** My Pics
'86 F350 Crewcab Dually 6.9/C-6/4.10 LS Racor seperator. 233k miles **SOLD**
'89 F350 Crewcab SRW 4x4 7.3/zf5/4.10LS 193k miles**SOLD**
Just remember to use your four way flashers below the minimum speed if it's required in your area. In the US, it's usually, 45mph on the interstates. I don't know if they have that requirement up there
-----Robert
'92 F-350 7.3 5 spd, Crew Cab dually,ATS turbo, 4" Exhaust, Air seat, Western Hauler bed. My Gallery
As long as you downshift to keep the RPM's up you are OK. You definitely don't want to do 30 mph in direct gear with the pedal on the floor.
does this mean that thoes of us with a c6 should switch from D to 2nd to keep the rpms up? why is that? and how does one instal a rpm gauge? well it know how to mound the gauge its self, where do the wires attatch?
work truck - 86 Ford F250 with 6.9L Navistar IDI non-turbo diesel 4x4 dana 60 rear, dana 44 front, with 3.54s, C-6 with cooler, manual walbro frb-13 fuel pump, manual motor craft ZD-9 glow plugs, K&N air filter with homemade cold air intake and no soup bowl! napa heavy duty tractor truck batterys, homemade waist oils "conversion" burns everything also runing on B100. working on full work truck set up...
cruzin' car - 94 subaru justy 2 door hatchback 1.2L gas 5 speed everything works!
When I ran the E4OD I never had any trouble with it trying to pull to high of a gear. It would kick down when under a load, if anything it would stay in first our second when I would have liked second or third. As for water temps, the stock idiot gauge doesn't tell you much. If you are going to be pulling much look into an aftermarket temp gauge. On mine one letter on the gauge, right of R to left of A of NORMAL accounts for the movement from 175*-212*.
The turbo will help your milage and speed however as for the life of your motor as long as you take it easy you should be fine either way
-Brian
1990 F-350 REG CAB LONG BED, 7.3 IDI, '95 ZF-5, LUK CLUTCH W/ SINGLE MASS FLYWHEEL, 87 BW 1356 T-case, FOUR GAUGE PILLAR MOUNT W/ AUTOMETER BOOST, PYRO, OIL PRESSURE AND WATER TEMP, BANKS SIDEWINDER WASTEGATED TURBO, EAGLE 16.5" WHEELS, 4 INCH SUPERLIFT, 35/12.5/16.5 BFG Muds, Eaton Rear End (7/05), Blown Motor (9/05), New motor, trans and t-case (9/06), Custom 5" straight pipe (8/07) - Pics coming soon....odometer rolled for the second time...although I don't have the correct spedo gear and the spedo/odo didn't work for 15-20k miles
With a C6 tranny, (it has no OD) you don't have to shift out of OD, the tranny will shift down or up as needed. Of course on a long pull it's best to shift into the gear manually that keeps the RPM up for power.
Not familiar with a 88, thought all diesels had tachometer's. Google diesel tachometers. They are expensive about 115 bucs up , plus senders are seperate purchase, they should have installation instructions.
Doesn't your IP tower have a sensor or a plug on the top side, sensor has two wires coming out it if there is one.
Just got back yesterday from a 1300 mile trip mostly over mountains in N & S Carolina , Virginia, W. Virginia and the Smokies. Pulling a 7200 lb. load on GN trailer, total pulling load was 12500 , with a 7.3 IDI no turbo E4OD. Lots of long pulls up at 30 MPH 2900 RPM in1st gear just screaming engine. Temp didn't exceed over 220* at anytime, sender is mounted by #8 cyl. in the head. Ran most all the way in OD, just shifted down manually when the RPM's would go below 2000. Built Ford Tough
I BLACK SMOKED most all the way, truckers were really chatting about me, got a lot of friendly one finger waves.
k Pic
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo Radio SD & Tape 126,700 03/08 Build date 03/99
Rebuilding engine. 92 F350 7.3 IDI CC LB dually Banks turbo US Gear O/U ENGINE IS SHOT !
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
Reman IP - New Delphi Injectors Beru GP's New radiator & hoses New WP
Dual Exhaust 3"X18" resonators
Soup bowl gone, 4" intake W/AZ filter
Cobra CB W/Weather Interrupt - Dual Trucker Antenna's
Blk. Grill W/Brush Guards - Fog lights - Rally driving Lights. GN 20K & Reese 16K 5er hitch
