Old 03-23-2008, 02:37 PM   #1 (permalink)
A what's it worth thread-7.3 engine
Hi all,
I work at a junkyard, and an '88 f250 with a 7.3/c6 just came in. The guy selling it reported that it has some fuel leaks but runs. I put a couple of good batteries in it, and I only succeeded in getting it to run for a few seconds with ether. The injectors are leaking, it looks like between the upper part where the fuel return hose is and the lower part that's screwed into the cylinder heads.
When it did run, it seemed to run smoothly with no knocks, but it only ran for a few seconds and at a fairly high speed, which might disguise any misfires or dead cylinders.
I have no idea how many miles this truck has, as it has a 5 digit odometer. I'm considering buying the engine or engine/trans, but I need to know approximately what they might be worth.
1998 12v 5 spd 2wd dually, 271k on truck, bhaf, piers 370's, timing at 16.5 deg, 3k gsk, #0 plate full forward, afc arm on shelf in shop, htb2 64-14 turbo with wastegate set at 45 psi, southbend dual disk clutch, detroit locker, has broken 2 stock dana 80 limited slip units, has run 14.65 at 98 granny shifting the 5 spd, dynoed at 450 hp and 906 ft/lbs on REALLY STINGY dyno
v8440 is offline
Old 03-23-2008, 05:48 PM   #2 (permalink)
FrankenStroke's Avatar
I just paid $300 Canadian for an IDI 7.3 that has been sitting in a barn for 2 years. I could have added a tranny for $500 total, but it was a 2wd, I needed 4wd.
FrankenStroke is offline
Old 03-23-2008, 05:53 PM   #3 (permalink)
Eesh, maybe I ought to leave it alone then. Either that or you got a great deal-I was under the impression that they were worth more than you paid for a core, and more yet for a running engine.
v8440 is offline
Old 03-23-2008, 05:58 PM   #4 (permalink)
I think I did get a good deal running or not. I was told he could get 200 dollars for the core. I took a quick check on ebay at remanufactured short blocks, and all of them were over $1500. Now I'll have an even better deal on my hands if the thing will run with minimal repairs!
Old 03-23-2008, 09:44 PM   #5 (permalink)
I can get this for about $80 or so with tax, so I'll probably get it. The transmission will be about $30 more.
I work at the junkyard this truck is in, so I get half price.
v8440 is offline
Old 03-23-2008, 09:45 PM   #6 (permalink)
91diesel's Avatar
Send a message via AIM to 91diesel Send a message via MSN to 91diesel
Where you located? Get one for me and ill gladly pay you a commission and come pick it up
1997 F-350, XLT, dually, crew cab, 7.3 PSD, E4OD auto, B+W turnover goosneck hitch
http://community.webshots.com/user/91diesel
**91diesel AKA anthony2010**
http://www.youtube.com/watch?v=fe622W_yZcQ
16.66MPG
[IMG src=file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot-9.jpg][/IMG]
91diesel is offline
Old 03-23-2008, 09:49 PM   #7 (permalink)
There's only one, and it's at the pull-a-part in Montgomery, AL.
v8440 is offline
Old 03-23-2008, 10:57 PM   #8 (permalink)
91diesel's Avatar
lol a tad to far :P
16.66MPG
91diesel is offline
Old 03-24-2008, 10:58 AM   #9 (permalink)
88beast's Avatar
anthony do you have a use for it ??
i though you ditched the idi
well anyway its worth much more more like 800 longblock unknown condition
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
http://youtube.com/watch?v=ILAQuHNAGE0
i plan to add propane kit, stake body bed, gn hitch,western style mirrors, and a lot more
88beast is offline
Old 03-24-2008, 12:37 PM   #10 (permalink)
91diesel's Avatar
No use, I wouldnt mind having one around to play with though.
16.66MPG
91diesel is offline
Old 03-24-2008, 12:56 PM   #11 (permalink)
yeah, you had best buy it for that price!!!!!!!!
Old 03-24-2008, 01:23 PM   #12 (permalink)
Question reasonbly priced core/working 7.3idi & E40D
Guys,
I could use donor long block and tranny, since my wife has been in & out of the hospital since early January '06 my F350 with with 678K miles hasn't had as much daily driving, hospital parking lots cater mainly to windup/compact cars, with no room for full size crew cab pick ups. I figure with the nearly 2 year down time I may be needing to R&R the engine &/or the tranny, it would be nice to do the work myself ahead of time. Then I would know what I've got & be ready to go.
We have horses & livestock & have had to evacuate for both the SoCal '03 Cedar fires & the '07 Witch Creek fires, we've got 2 trucks & 2 trailers, now, after almost not being able to make a return trip for the rest of our horses.
But, I need my truck to be solid enough to 'get out of Dodge' when the fires or flash floods get out of hand.
thanks for any help/suggestions.
jerry
'91 F350 CC,7.3NA w/K&N,E40D(rebuilt--way too many times), 2WD,3.55 rear end,new IP,new u-joints & carrier bearing, new rotors, new calipers, new drums & hdware, added Auburn limited slip unit (2/8/05)w/valvoline synth 80-90w, new batt.cables,new window motors,new radiator & hoses, 500K, (new injectors)+ mi (now 678K miles)& still Truck'n. If I can fix it, it ain't broke, I'd rather do it myself.(yes, I add,stanadyne, lucas or power sytems fuel additive in every tank, w/maybe 1-2x year full big bottle dose split between both tanks). New tires & pretty wheels, front end rebuild 3/17/05. Bilsteins added 6/12/05. New motor mounts & valve cover gaskets (9/06.)Future hopes finally fixing my electric door locks & adding remote entry/alarm system.
http://community.webshots.com/user/jl_mendoza
jlmendoza is offline
Old 03-24-2008, 10:52 PM   #13 (permalink)
Well, I guess I better pull it. The sucky thing is, I'm off on Fridays and Saturdays. This Friday I'm scheduled to have a liver biopsy to find out why my liver is enlarged along with some very high levels of liver enzymes. I'll be recuperating the rest of Friday and Saturday (they say you can easily start bleeding from the liver if you overdo it after a biopsy).
I can get the truck held back in the processing area so that it won't get taken before I get a shot at it, but almost 2 weeks is kinda long to do that. I dunno...
v8440 is offline
Old 03-24-2008, 10:56 PM   #14 (permalink)
91diesel's Avatar
Hope your surgery goes well.
I think you could get that sucker out in a day if you really tried. Might have to get the cutting torch out :P
Good luck!
twon
16.66MPG
91diesel is offline
Old 03-24-2008, 11:05 PM   #15 (permalink)
Thanks, I just hope it's not cancer of the liver. Both of my parents died of cancer (not liver), so I'm somewhat at risk.
Anyway, I'd certainly expect to get it pulled in a day. I'll probably pull the c6 with it to simplify things. We have big rolling A frames with chain hoists to pull motors, so I won't be struggling with a cherry picker in the gravel.
By the way, does a c6 behind one of those engines have a different bellhousing, or did international make the ford 7.3's with big block ford bellhousing bolt patterns? Either way, the transmission will probably be worth grabbing.
v8440 is offline
