when is it time to replace glow plugs
This may seem like a dumb question but how would you know when to replace your glow plugs is it by mileage, time, time to start? Also how bad is the replacement and how does the end of the glow plug break off? I am curious about this as when you go to take these off are they prone to breakage when backing out etc etc. I searched the other forums and have not seen a great answer to this other than people warn about breakage and your screwed if itfalls into the block. Some insigt would be great as well. Lastly if you drop off at a mechanic (diesel) to do replacement do they usually warn against this or when it breaks off do they call you and say oh by the way the glow plugs were 72 and an hour of labor plus $1500 to remove he head when the plug broke off into the head.
Shane
Reason: spelling
