where can I get injector return kit in BC, Canada? - Diesel Forum - TheDieselStop.com
Old 10-23-2005, 08:21 PM   #1 (permalink)
I have one injector cap leaking like crazy and also sucking in air, so I got a bunch of o-rings and figured I can just replace the o-rings. The previous owner told me he replaced the return kit 1 year before he sold the truck to me, I bought the truck two years ago.
In the process of taking the leaky return cap off, the neighboring cap broke off from the hose clamp, with the broken part still clamped inside the hose. Oh well, turned out they became brittle after 3 years. After inspecting the offending o-rings, found out one has pretty bad torn mark on it.
Now I have no transportation, on a Sunday afternoon. Called local Lordco, for $150 a set, they don't have any in stock. Canadian Tire didn't even carry them. Other fuel injector service places mostly closed.
Now, my question is: Anyone on this board know any place I can get a return kit? I'd prefer they ship, but not from U.S. Eveytime I buy something from down south, I was charged around $20 for boarder clearance. And I need it fast, as I'd like to drive the truck to work as soon as it's done.
Thanks in advance.
1990 Ford F-250 Lariat XLT 7.3L diesel NA, two wheel drive, 5 speed manual, 450,000 km. 3.55, 6250 lb...
------ WB:155 TYPE-GVW:X259 BODY:FJM AXLE:39 TAPE:3 SPRING:K F --------
Dual tank, Master/Carter(P74017) electric pumps. OkieGringo idler pulley, K&N air filter, Cat fuel filter, Manual GP switch.
skipper416 is offline
Old 10-23-2005, 09:12 PM   #2 (permalink)
Re: where can I get injector return kit in BC, Canada?
Here is a website of a diesel shop in Canada. I hope it helps you. http://dieselautoservices.com/home.html Good luck, Tim
'94 F250, 4X4, 7.3, E40D, 4.10, 147K
tim94f250 is offline
Old 10-24-2005, 09:23 AM   #3 (permalink)
Hi Norm,
You could also try International truck service/dealers. There is one not too far from you Covan in Coquitlam. They will sell the parts needed.
Also DAS in Maple Ridge should have what you need.
HTH
John
1st Truck : It is used daily, 1986 F250 S/C, LB, 4x4, 6.9l diesel, after market turbo, C-6 auto, LS rear axles, 320,000km, original owner.
2nd Truck: used almost daily 2002 Dodge 3500 Turbocharged Cummins, auto, dually,
John Wood is offline
Old 10-25-2005, 08:08 PM   #4 (permalink)
Thanks for the info, I called around and ended up getting the return kit from Ford dealer which is within 20 minutes walking distance, not too bad for $50CDN. Put two caps on and also a small and skinny o-ring between the cap and the nut, hope it'll stay tight for a long time.
Old 10-25-2005, 10:33 PM   #5 (permalink)
cdnsarguy's Avatar
My Photos: (109)
When you change one cap and orings you should change all of them.... Any CDN Stanadyne dealer will also have the Return line Kits.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 10-26-2005, 02:56 PM   #6 (permalink)
I understand the logic of changing all caps and orings at the same time, makes perfect sense. In my situation, I believe I may need new IP and/or injectors soon. It's just in my nature to try put it off as much as I can. So far, other caps haven't leak on me yet...
