I have a 1979 f250 that i have converted from a 460 gas engine to a 1989 7.3 liter idi non turbo. after i put the motor in, it ran good for a couple days, then it started acting up. It takes forever to start, it looses its prime within a hour then i have to put the charger on it to jump it. Is there any check valves or places i should look at to see if it is sucking air in. When i did the swap, i put all new fuel lines on it and clamps. Thanks , Hunter
Did you do anything to the fuel lines from tank to engine?
Did you do anything to tank pickup? ie: tank fuel sender.
A 460 has the lift pump on the Drivers side, a 7.3 diesel has the lift pump on the Passengers side. You would of had to extend the fuel line to Pass side.
Do you have Dual fuel tanks?
Related Threads
The Diesel Stop
2.6M posts
210.8K members
Since 1999
