Will a '95 F350 7.3L DIT fit in a '93 F350? - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 12-25-2011, 02:33 PM Thread Starter
Post Will a '95 F350 7.3L DIT fit in a '93 F350?
I have a '95 F350 with a 7.3L DIT engine and 5 speed, and want to put it into a truck with a better body etc. Will this engine and transmission fit easily into a '93 F350 with a 7.3L engine? Will it fit easily into any other year than a '95?
berrymcm is offline
post #2 of 3 (permalink) Old 12-25-2011, 08:24 PM
Wrencher's Avatar
It will fit. Will just require the computer and other neccessary wiring to go with it. Should be good since you've got the whole donor truck.
2002 F-350 CC Shortbed, Rebuilt 7.3 Powerstroke, 200K, head studs, Adrenalin HPOP, DIY BHAF, EBV brake mod, New motor, New trans both @ 170K, 4" Lift, 35" BFG KM2, GEAR HEAD 6 Position, Banks Big Head Wastegate, 4" Duals, Superlift Air Bags, B&W Hide a ball W/ 5th Wheel Companion, Marinco mod, '15 steps,'12 tailgate,'15 mirrors,'12 seat belts and jump seat. no more lap belts
LOCAL 3 OPERATORS UNION UTAH
LOCAL 140 PIPE WELDERS/ FITTERS UNION UTAH
Wrencher is offline
post #3 of 3 (permalink) Old 12-26-2011, 11:33 AM
I have done that conversion and yes it does fit as the body is the same. just make sure you grab the motor mounts and the rear trans mount from the PSD as those are different from the idi.
1993 7.3 IDI, crew cab, long box, 4x4 and a half, XLT with ATS turbo.
Glowshift Boost, Trans, Pyrometer gauges with glow shift pod.
Devdg is offline
