THE BLUE BOMBER! Currently Toast !!!!
87 ford f-350 cab-chassis dually. 2wd, 6.9, 3 speed C-6. 3 leaf helper springs, 11,000 gvwr, pintle/ball hitch, 6 pin round trailer connector (unhooked currently). Rear generic truck stop lights. Twin I beam front end with coil springs. Plow lights and switch to go from headlights to plow lights. 8.5 foot meyer diamond plow with central hydrolics. 8 foot rugby dump bed. 167,000 miles and still strong. Solid State Glow Plug Controller.
I think MLCS has done the conversion too, but with a GM hydro boost.
Hopefully someone will chime in, the listing is ending soon. It looks identical to the F-450 hydro boost, but I'm not sure if it's the same or not.
You'll have to re-clock the mounting plate (turn it 90 degrees in any direction), as if you bolt it up as it is now your master cylinder will sit sideways. Also the pressure lines seem quite odd, I'm not sure how you can adapt the F450 hoses to these lines, or if you can use Mustang hoses instead... Also the bolt pattern of the mounting plate and the length of the pushrod may be of concern... I'd say too many unknowns in this, keep looking for an F-Superduty booster.
Ya you're probably right. I might check and see if I can find part numbers to verify they are different.
I've found a few super-duty boosters, but not as cheap as this one.
Thanks guys.
