Old 04-17-2007, 04:42 PM   #1 (permalink)
Will they interchange
The backs of my grill and headlights are all broken up from before i purchase my truck... Was wondering if anyone knew whether or not the front set up to the newer style '95ish will fit in place of my old '90 grill and lights? Visually it looks like it would...anybody know?
Thanks!
7.3 IDI F-350 4x4 1990
-Custom: '92 interior; Banks Y Pipe, Flowmaster muffler and Dual 4.25" Stacks
-Reman'd: Heavy Duty E4OD and Billet Converter; Transfer Case; Water pump; Power Steering pump; Denso Starter
-New: Brakes; Engine seals and oil pan; Oil pump; RUST-FREE Cab and Bed
-Pro Comp "Holley Red style" electric fuel pump
-3" Body Lift
-Fresh under coating on frame No more face full of rust under the truck!!
-16x10 Eagle Alloy 186 with 33's
-8ft snow plow
4.6l Mustang GT 1997
-Custom side exhaust (no mufflers, Ford Racing Exhaust tips
-Aftermarket stereo (Alpine headunit; JL Component Speakers; JL 300x2 Amp; JL 10" W7 Sub; JL 500x1 Amp)
GOTTA LOVE FORD MUSCLE
Cjhstang is offline
Old 04-17-2007, 08:31 PM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: Will they interchange
I don't belive so, your's is a flat nose 92+ went to a rounded nose.......
Proud Canadian BOOB man too!!
cdnsarguy is online now
Old 04-17-2007, 11:29 PM   #3 (permalink)
Bill1013's Avatar
Just got a 90 7.3IDI myself a month ago. The odometer only goes to 100,000 miles then starts all over again. The only way you might be able to tell how much milage is on there is get an AUTOCHECK on it. Mine had 80700 but it appears the odometer turned over 3 times, close as I can tell it's 280,000+. There is a charge to do that if you really want to know. autocheck.com [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
No you cain't have my grill & lites. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo Radio SD & Tape 126,700 03/08 Build date 03/99
Rebuilding engine. 92 F350 7.3 IDI CC LB dually Banks turbo US Gear O/U ENGINE IS SHOT !
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
Reman IP - New Delphi Injectors Beru GP's New radiator & hoses New WP
Dual Exhaust 3"X18" resonators
Soup bowl gone, 4" intake W/AZ filter
Cobra CB W/Weather Interrupt - Dual Trucker Antenna's
Blk. Grill W/Brush Guards - Fog lights - Rally driving Lights. GN 20K & Reese 16K 5er hitch
http://community.webshots.com/user/oldbull8?
Formally OLDBULL
Toys: 1984 Coachmen Leprechaun F350 Chassis 460CID 92K miles.
30 ft. Jayco Jay Designer 5th wheel.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One flash and it's gone.
Bill1013 is offline
Old 04-17-2007, 11:38 PM   #4 (permalink)
Don't think so. None of the panels are the same as an 87-91, so the grill and headlights probably won't fit right.
'91 F250 4x4 SC, ATS 093, ZF-5, GV OD, 4:10's, 3" in, 3" out, AEM Dryflow, 33"s
skimballc is offline
Old 04-18-2007, 12:40 AM   #5 (permalink)
arthurgoboom's Avatar
The only thing that's the same is the radiator core support. It appears that the core support is the same from 80-96.
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Beru ZD1A glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
arthurgoboom is offline
Old 04-18-2007, 01:38 PM   #6 (permalink)
The whole front clip changed each time they redesigned. The fenders, hood, lights, grille etc are all matched together.
IMO the 92+ front clip is a tremendous leap forward from the flat front and is a worthwhile swap.
If you do the swap, try to get the whole clip including the core support and inner fenders. My old wrecker had the newer clip on it, but there were a lot of "unattached" parts due to missing brackets and the inner fenders not being the same shape.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 04-18-2007, 07:19 PM   #7 (permalink)
Mr. Roboto, are you saying that if i would go about the front swap, I'd need the fends, hood lights grill etc in order to do it?
-3" Body Lift
-8ft snow plow
Cjhstang is offline
Old 04-18-2007, 09:21 PM   #8 (permalink)
That is correct. If you put the 2 trucks side by side you will see that all the parts are different.
Old 04-18-2007, 11:13 PM   #9 (permalink)
hmmm.... sounds like alot more than i expected. Thanks for the info!
-3" Body Lift
-8ft snow plow
Cjhstang is offline
