Old 03-20-2008, 07:30 PM   #1 (permalink)
wire harness - where to buy??
With my truck rebuilding project this summer i'm replacing all lines and figured i should include the wire harnesses too cause some are looking prity scary...
Anyone know where i can get replacement wire harness for the truck?....besides the dealership's rip off prices. Do regular parts stores carry em? napa...
7.3 IDI F-350 4x4 1990
-Custom: '92 interior; Banks Y Pipe, Flowmaster muffler and Dual 4.25" Stacks
-Reman'd: Heavy Duty E4OD and Billet Converter; Transfer Case; Water pump; Power Steering pump; Denso Starter
-New: Brakes; Engine seals and oil pan; Oil pump; RUST-FREE Cab and Bed
-Pro Comp "Holley Red style" electric fuel pump
-3" Body Lift
-Fresh under coating on frame No more face full of rust under the truck!!
-16x10 Eagle Alloy 186 with 33's
-8ft snow plow
4.6l Mustang GT 1997
-Custom side exhaust (no mufflers, Ford Racing Exhaust tips
-Aftermarket stereo (Alpine headunit; JL Component Speakers; JL 300x2 Amp; JL 10" W7 Sub; JL 500x1 Amp)
GOTTA LOVE FORD MUSCLE
Cjhstang is offline
Old 03-21-2008, 12:03 PM   #2 (permalink)
FraserScott's Avatar
My Photos: (17)
What do you mean by scary? I don't think you'll get a wiring harness for our trucks from a parts house, and Ford no longer carries them. I'm in the same boat as you at the moment though.... I just removed my main underhood harness to fix it up. The first thing I did was lay the harness on a 4X8 sheet of plywood and sprayed "superclean" all over it. I hosed it off with the garden hose, connected to a hot water tap. The super clean gets all the oil, dirt and grit off of the connectors and makes the electrical tape on the harness shine !! But don't go over board with the water because i'm sure if it soaks long enough, it'll do some sort of damage. When it's clean, blow out all of the connectors with compressed air and clean them with an electrical component cleaner. Then you can go ahead and fix what needs to be fixed. I was able to get new headlight sockets from the local parts house, that you can solder and heatshrink to your original harness. the locking tabs were broken on my original sockets. I got rid of the crimp on connectors the the previous owner had put on, I fixed that by solder and dual wall heatshrink. I basically fixed what looked ugly. My main harness to engine harness connector had melted sometime in its life and the PO had crimped all the wires together, which later on I soldered and heat shrinked the wires together. This time I fixed it by installing a 12 pin "Deutsch Connector". Then I wrapped the whole harness with 3M electrical tape (right over all the old tape), I found the 3M to be about the best match to the factory tape. Good luck with what you do!! BTW my truck is only 4 years younger than me LOL.
1990 F-350 XLT Lariat CrewCab 4X4, 7.3L NA IDI, E40D, 3.55, Rebuilt injection pump and injectors, Manually controlled TC, Fleetguard DC4A, 277,000 Kms, Two tone brown. Completely stock. 9200# GVWR. ***In the works of being converted to a ZF-5 with Luk Clutch/ Single mass flywheel conversion***
1986 F-250 supercab 4X2, 6.9l, T-19B 4spd, 3.55LS,8800# GVWR 200,000 kms.
1983 F-250 supercab 4X2, 4.9l, T-18 4spd, 4.10, dad bought it new, dark teal metalic, 317,000 Kms drivetrain all original. 8800# GVWR.
2005 E-150 XL, 7 passenger, 4.6l v8, 3.55 LS, Navy Blue. 44,000 kms.
FraserScott is offline
