Wont start cold in the mornings without small ether shot no matter what temp outside. I have been doing this for at lest a year. My mechanic said that is just how the old diesels are , but there has to be something to fix to this Thankx
If it is an 89 and up there should be no reason to ether it unless the GPs are not working. Do you get a wait to start light (WTSL) does it stay on or just flash..... is it hooked up at the firewall, center of the engine, black with pink strip from the controller.
Have you tested the GPs..... and do you know what brand they are. Only Motorcraft/Beru are reliable.....
Tell your mechanic to sit in the corner and be quiet. Then run away and get a new mechanic.
There are a few reasons for no start cold and they can all be fixed so that the ether can, can be used for the lawn mower...
First) what shape are the batteries in. Can you count the revs of the starter? If so then they need to be replaced. 850 CCA minimum and change them as a set.
Second) how long does the Wait To Start light stay on? Should be on for about 12-15 seconds cold. If not then you probably have 1 or more glow plugs bad. Use an OHM meter and put the (-) Negative lead on the engine and the (+) Positive lead on the tip of the GP and you should see 2-3 OHMS. If they are bad use BERU or Motorcraft ZD9. DO NOT use autolite.
This should give you a starting point.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
I just repaced the starter noticeing a high torque start up now . 2 brand new batt. new alt. don't know what a gp is .I have replaced 5 glow plugs and too need to do the last few .I assumend that every glow plug not working might cause this. So will do the other 3 and see what happens. I kind imagine that not every glow plug would not cause this. Thankx.
You have a very explosive situation using Ether. Yes explosive. If you use ether, you need to disable the GP system. Question, how much fun is it having to raise the hood each morning and give it a shot? Most of us climb in, turn the key on, fasten our seat belt and when buckled it's usually time to crank it over. Easy and we don't get dirty starting the truck.
Regards,
Paul - Pocono Mtns. USA
02 E350 15 Passenger, 52,000 Miles
'90 E350 7.3L Ex-Ambulance High Top 400K Miles, No Turbo, Stock Stock stock, No ELC! (Extended Life Coolant) & 10 Oz. Bars Stop Leak, Retired 11/8/2011 with blown trans.
3 GPs can make a difference. GP (Glow plugs) GPC (Glow Plug Controller) GPS (Glow plug soliniod) The GPC contains the GPS and the controller is what regulates how long the glow plugs will be active by activating the GPS. The GPC senses how cold th engine is and how long the GPs need to be activated by the resistance in the GP wire loom. so having 3 bad GPs will make it so the rest of the good GPs won't stay on as long because the GPC thinks the engine is hotter than it is. Even 2 bad glow plugs can make it harder to start in colder temps. If you have a Non turbo IDI then getting to the glow plugs is... lets face it... not hard at all.
'90 7.3 IDI F350 4x4 Custom, ext cab, E4OD w/ tow package, 4.10 Dana LSD rear, 94' ATS turbo kit w/ 99' PSD wastegated charger set at ~20psi max, copper firering head, studs, turbo IDI block, mild head work, Delta Cam, Moose pump, turbo injectors, 6.0 PSD intercooler, propane injection, 3in exhaust. Almost 300 and 500. (added 2 more flats than previously) 296hp, 487tq (6/4/11)
'03 7.3ltr Powerstroke F350 4x4 4dr. SCT Livewire, ATS exhaust, rebuilt HD trans, 6.0 trans cooler, fuel mods, AFE intake, Garrett gtp38r ball bearing turbo; glad its not a troublesome 6.0
my guess would be his glow plugs or glow plug relay are not working.if lunas jackel has been using ether for the last year and has not blown himself up yet his glow plugs are not coming on.
How long does the Wait To start Light stay on when you first turn the key on with a cold engine?
Regards,
It stays on about 5 seconds , but can tell the glow plugs are still heating up because of the amp. meter. And yes it is anyoing to pull the hood up every morning.
5 seconds isn't long enough, replace your remaining GP's and see how long the WTS light stays on.
Regards,
