wont start help - Diesel Forum - TheDieselStop.com
Old 11-07-2009, 01:12 AM   #1 (permalink)
wont start help
i just bought a 1991 f350 dually. when i first bought it from the guy it started fine but then it didnt want to start. so i checked batters they were a like 550 cca . i think they were to small so bought 2 1040 cca its turns over fine but doesnt start.check glowplugs 1 was bad replace it. i put electric fuel pump in thinking maybe does have pressure so know i got pressure all the time. still wont start.got newfuel filter air filter still wont start. it wont start in 60 degrees weather . it starts after the 3rd or four time cranking it for 20 to 25 seconds. if it does start after that than i put a spray of starting fluid and starts right up. my questions is could it be the relay and where is it located how do u test if bad or good thxs dually6690
dually6690 is offline
Old 11-07-2009, 08:09 AM   #2 (permalink)
Will it start after you plug it in for a couple hours?
2002 F550 7.3 4x4 Auto stock 215550
B Reeves is offline
Old 11-07-2009, 02:44 PM   #3 (permalink)
i need to put a new one in its broken
Old 11-07-2009, 03:38 PM   #4 (permalink)
chuckster57's Avatar
starting fluid is VERY bad for diesels if the GP system is working. You can have the fluid go BOOM and then you can look at the inside of your engine through the hole you made....
Are you getting any smoke when it does start? Once it starts the first time is it good for the rest of the day? If so then it sounds like air intrusion. The IDI is known for the return system leaking and allowing air into the system and making it hard to start.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is online now
Old 11-07-2009, 05:56 PM   #5 (permalink)
rsr911's Avatar
What Chuckster57 said, plus the starter. With those little batteries it might have been overworked. I cooked a new Azone starter on mine with batteries that were going bad, luckily it was lifetime guarantee. If you can count the revs when cranking it's too slow and the starter should be replaced, but do the simple stuff first. With my new starter and new 1000CCA batteries and cleaned up terminals mine starts at 50F with no glowplugs (I've got a controller issue). I went out this morning and realized I'd forgotten to plug it in, figured I'd give it a try and sure enough it fired right up but my starter really spins it.
1986 F350 Crew Cab 2wd SRW. 1991 7.3 IDI, T-19 4spd Sterling 10.25 3.55, 12" HD clutch. A Banks waste gated turbo. 5" cut down Peterbilt stack. Midwest rebuilt IP turned up. AC Delco 6.5 GM 12V GP's, working great. Running W85 high performance zero-gel diesel! D60 front conversion, 4wd conversion, dually conversion, and steel flatbed conversion now underway. Man those frame rivets are a pain!
1966 Porsche 911. 1983 911 SC engine with modified Zenith carbs, headers, 911S brakes, custom fuel rails, MSD 6al box with timing computer, 1974 IROC body kit. 1850lbs, 200rwhp, total blast to drive.
rsr911 is offline
Old 11-07-2009, 07:53 PM   #6 (permalink)
yes i am getting white smoke when first starts if i let it sit for couple hours then will not start.. iwill check the starter and where do u start to look for airleakes and how do u fix them. thxs dually6690
Old 11-07-2009, 07:57 PM   #7 (permalink)
Snotzalot's Avatar
Does if fire when you first crank, then die after a few seconds?
Regards,
Paul - Pocono Mtns. USA
02 E350 15 Passenger, 52,000 Miles
'90 E350 7.3L Ex-Ambulance High Top 400K Miles, No Turbo, Stock Stock stock, No ELC! (Extended Life Coolant) & 10 Oz. Bars Stop Leak, Retired 11/8/2011 with blown trans.
7.3L Alternator Belt Idler Photos
Snotzalot is offline
Old 11-07-2009, 08:00 PM   #8 (permalink)
You can search for the "clear line test" in the IDI forum, if you're so inclined. I would look into just replacing the stuff if it is factory original (still has the green paint on it). the things I am talking about are the plastic caps that fit on the tops of all the injectors and have a fuel line running between them and the IP.
There is an "O" ring at the top and bottom of each injector and excess fuel is returned to the IP for re-use and IP cooling. whats left over goes back to the fuel tank. This system is known to fail after time and it is a cheap fix. You will need an injector installation kit. It will have all the caps,"O" rings and fuel line with clamps needed. This kit can be purchased from E-bay, site sponsors or most major auto parts stores.
Old 11-07-2009, 08:02 PM   #9 (permalink)
it stays running after i get it going
Old 11-07-2009, 08:36 PM   #10 (permalink)
Snotzalot's Avatar
So when it hasn't run over night, it doesn't even fire when you first try to start?
How fast does the starter crank it over, can you count the revolutions?
How long does the WTS lamp stay on when first turned on when cold?
Regards,
Old 11-08-2009, 03:07 PM   #11 (permalink)
it turns over but doensnt try to start untill second or 3rd cycle of glow plugs the tack doenst work so can count revoultions . it takes 10 to 11 seconds for wts lamp stay on when cold
Old 11-08-2009, 03:13 PM   #12 (permalink)
also we only got 10 volts to glowplugs should there be more.
Old 11-08-2009, 06:08 PM   #13 (permalink)
Snotzalot's Avatar
9.6 V is correct.
Regards,
Old 11-08-2009, 06:11 PM   #14 (permalink)
Snotzalot's Avatar
How fast is the starter turning over the motor, can you actually count the revolutions? A slow turn over indicates a bad starter and would give you this hard start.
Regards,
Old 11-18-2009, 05:40 PM   #15 (permalink)
Sounds more to me like you need to check the glow plugs. I don't see on here where anyone has said that. The way to test them is to pull the plug off the top of each glow plug individually. Use your tester and set it on continuity test. The top of the glow plug should have continuity to ground on the engine. If it doesn't, it's not any good. I'd be willing to bet you have a few out.
Always replace all the glow plugs at one time. If you don't, you'll soon replace the rest. Be careful not to snap them off in the block. Use some anti-sieze lubricant when putting the new ones in.
00 F-250 Super Duty 7.3L psd, stock, 300k miles
00 Excursoin 7.3L psd, stock, 190k miles
97 F-250 SD 7.3L psd, stock, 335k miles
89 F-350 flatbed 7.3L + turbo, 217k miles
06 F-750 Cat C7 - 300hp, 158k miles
wunderbrad is offline
