My neighbor has a '90 250 and is having a problem with the starting system. She is a single mom who's strapped for cash and the truck is a heap. To have the truck taken to a shop could cost more than what the trucks worth. She recently had new batteries and cables put in, but now the truck will hardly crank. I think it might be the solenoid. What should be the voltage reading at the starter.
Try Jumpering the fender mounted relay first.. if it is old it will not close and pass full power to the solenoid on the starter. If the starter is suspect.. use a mallet/hammer to hit it as you attempt to start it......... if it spins a little faster the starter brushes/armature is fubar........
Azone has the Mitsubishi gear reduction starter part #16561 for about $120.... Starter uses about 200amps....12 volts.
Good point Mr R....... what size are those new batteries.
2 850 CCA minimum are required...... anything lower will not start our trucks as there is a huge power requirement at startup.
im having the same problem it was cranking fine then it started to crank slow for like 3 starts,if you kept cranking it would kind of free off as though to speak then the next time i tryed to start then it just clicked repeatedly and then died.
now when i turn the key it just clicks onces, the fuel in water light apears and the abs light comes on but no cranks??? the batterys are fully charged, i took off the starter and checked the brushes and armatage and they seem to be fine, is there anything else i can do?.
second to this i have also been having a problem with my battery earth connector melting, is there some sort of open circuit passing power right back to earth? the glow plugs are old but the glow plug solenoid is brand new so is there a chance that the fender mounted relay would be the problem here?
please help if you can?.
Remove the starter and have it tested. Look at the Bendix end of the starter and check how the bushing looks. If it's "mushed" out, you need to replace the starter.
Regards,
Paul - Pocono Mtns. USA '90 E350 7.3L Ex-Ambulance High Top 400K Miles, No Turbo, Stock Stock stock, 10 oz. Bars Stop Leak and No ELC!
Specifically which earth connection is melting? There are the two main ones to the engine block (one from each battery) and others as well. In general melting obviously = heat and heat is usually resistance, as in a poor connection.
1988 F350 CC 4x4 SRW, 7.3 Banks non-wastegated turbo, C6 w/ HD torque converter, Tru-Cool 4590 trans cooler, Highjacker 'softride' 4" lift, pre/post luber, coolant filter, Racor fuel filter/separator, pyro and boost gauges, Progressive 16x8 wheels, 285-75x16 rubber, 3" downpipe into 4" straight pipe over the rear axle and into 5" SS tip. 1994 Alpenlite 33' 5th wheel trailer
Dont overlook the negative battery cables. I had the same problem w/my new to me 93. I replaced the positive cables and had good batteries and it would barely turn over. It turned out to be the negative cables.
hey thanks to every one for help, i replaced the terminals that connect to the batterys ive also cleaned up the contacts to the engine block.
the melting has stopped but im still not cranking up, it just clunks once and all the lights come on the dash abs,water in fuel ect???.
ill give it another once over before i take the batterys and starter to autozone for tests.
