I have a 92 F-350 IDI non-turbo and was wondering if the engine would be able to handle a factory turbo setup without a rebuild. The silly thing runs great and uses very little oil (less than 2 quarts) between 5K oil changes. Any thoughts????
That changes things just a little, thanks for leaving that detail out, mine has 314k and i'm gonna wait until after a rebuild.
Allen
93 F250, regular cab, 4x4, 7.3 NA, ZF5, 3.55, 209k miles, came home 2/28/06, soon to be turbo.
92 250, regular cab, 4x4, 7.3 NA, E4OD, 3.55, 316k miles, came home 8/28/04, aluminium 16x7 wheels, 285/75/16 Sport King AT.
89 250, extended cab, 4x4, 7.3, ATS wastegated, 5" straight pipe, hand shaker, 4.10, slightly toasted, waiting for a new cab and front end, came home 12/24/04
Definately changes things alot. I would say them rings wouldn't last long under a turbo with that many miles already on them. But look on the bright side, you could rebuild it and build it for running a turbo and get full benefit from it. The 7.3L IDI is a great engine, I personally think it has proven itself better than alot of powerstrokes. I f you build it up right you could have alot of go under your foot in the end.
I thought about it on mine, however I never really cared enough to do it and somehow I got to where I was going anyway [img]/ubbthreads/images/graemlins/wink.gif[/img]
I don't think it is the miles on the engine that you should worry about, but rather the miles on the fuel system. When did you have the IP and injectors replaced? Driving habit has a lot to do with the decision also.
I always swore my truck was fine in NA form. Then I got a 5'r and started towing and found the weak link (so to speak). The word went out that I was looking for a turbo and one day the call came in. I picked up a tight factory ATS turbo complete off a '94. Did the 3 upgrades and with the assistance of other members here strapped that puppy on. I will say that at 125k miles I still have the original (tested at 90k) injectors and return lines! [img]/ubbthreads/images/graemlins/shocked.gif[/img] My only regret is not getting a turbo a year ago. My "to do" list includes a Holley red fuel pump, DPS stage 1 injectors and eventually a DPS "turbo tuned" IP.
Joe
Hanover, PA
1993 Ford F350 XLT CC DRW 4X2.
"Factory Tech" modified E40D, 4R100 trans pan
Dual B&M plate style coolers, 4.10 rear,
Factory ATS turbo, Upgraded down pipe,
housing and elbow, DPS Stage 1 Injectors
Banks exhaust, Isspro and Autometer gauges.
That's like saying " I used to have this great engine in my car when I was a kid, but I never stuck a 4 barrel carb on it cause it got me where I was going anyway"
Birken, do you need a vacation? Maybe you've been in that dark, cold shop for too long. Get out and enjoy the Sierra's.. And, if you're towing anything above 4000', I'd suggest you borrow a buddy's rig with a turbo.. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
1991 F-350 XLT Lariat 4x4. Metallic Midnight Blue over Silver Gray.. Canadian Made. Now has 82000 miles. Std Cab SRW-7.3 With a Banks Stinger Kit. ZF-5 speed- 4:10. Five rear overload springs rated at 3000 lbs, Smitty Built side step tubes, mounted to frame with 1/2 " steel plate.. SteelHead sliding rear bumper. SteelHorse overhead panel with a Cobra 25. Dash mounted compass and altimeter, pillar mounted Banks pyrometer. 11.5 FT camper in the bed 99% of the time. Camper has been restored all the way out from it's frame. Camper has two #30 batteries, good for a week dry camping in the woods..
--- Two 1978 Bronco's- One stock 400 cu" and one Bombed 406 cu"--- 1972 E-200 van. 302 cu"--- 1975 F-600 with 361 cu" Industrial engine.
I see no reason to wait if the engine is performing well. Considering your oil consumption level and happiness with the over all condition, a turbo is not going to do anything to hurry that engine to it's next rebuild. The only danger is headgaskets, which is true with any engine in any condition. If it is weak, you will find out. If the engine cooling system has not been maintained, cavitation may be brought about sooner, but here again, it's all relative. I say put it on and enjoy it.
I got you one better, I went out and bought a 97 F250 which is what I drive now. When I did take the old truck on vacation heavily loaded with trailer and crap I would sometimes be down to 35 mph over Donner trying to keep the black smoke to a minimum. Nevertheless it was such a small portion of my trip that it did not make any kind of sense to add a turbo. With proper planning I could maintain 55 for 97% of the drive. Steep hills are not really that big a percent of total distance travelled. Besides the only time it was an issue was when I was on vacation and when I was on vacation I was not in a hurry anyway.
One of the guys at work bought himself a new Dodge, with diesel at my urging, to pull his new 5er. He was commenting on how it definitely does not go as fast with the trailer on and he said the same thing. Screw it I am on vacation. I just like to mellow out
Yeah, I here you.. Makes sense to me when you put it like that.
Donner Pass.. I really miss the Sierra's. Best mountains I've ever lived and played in. I'd love to live in Downieville or Sierra City.. Just can't afford it at this time. Might move to GV if they open up the mines again...
Al
I replaced the IP about 2 months ago but have never looked at the injectors themselves. My biggest concern is the head gaskets. You alwasy run the risk of hurting something if your boost numbers are to high.
