Old 08-02-2006, 08:47 AM   #1 (permalink)
My Photos: (9)
yool to cut open oil filter
I remember seeing it somewhere but could not find it. Works like a big tubing cutter. Can you post a link? Much appreciated.
88 E350 7.3 C6 154k
done: Remanufactured Inj pump, New Stanadyne injectors, Michelin M/S tires, ShellZone AF & Fleetrite SCA, replaced and relocated fuel filter assembly, elec fuel pump, no flying saucer, return lines/ o-ring kit, new heater core, 8 Beru glow plugs, oil & filter, stabilator on sliding door (plastic slider cracked in half)
Hot compression readings:
2. 500 1. 500
4. 460 3. 420
6. 540 5. 465
8. 480 7. 540
to do: transmission fluid, fix rust spots, WVO conversion.........
nubiecanobie is offline
Old 08-02-2006, 08:48 AM   #2 (permalink)
Re: yool to cut open oil filter
I've never seen such a yool. [img]/ubbthreads/images/graemlins/tongue.gif[/img]
Why do we want to cut open the oil filter now?
Eric
Ford 1992 E-350, 6,900 lbs.
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 08-02-2006, 11:10 AM   #3 (permalink)
SRR
Yack saw should work [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
'88 F-350 XLT Lariat, crewcab, DRW, reman 7.3 - 185 HP, ZF S5-42
SRR is offline
Old 08-02-2006, 11:56 AM   #4 (permalink)
Hack saw will put metal shavings into the filter, negating the point of cutting it open.
Ask a few local mechanics if they have one. Or if you REALLY need one of your own, do a Yahoo! search of "oil filter cutter" you will get dozens of different options. You're looking at anywhere from $50 - $100 plus shipping.
On edit, the diesle filter is much larger than most automotive filters, so you will need to make sure the one you get can handle our large filters. They actually have pipe cutters that big, maybe bug your local plumber.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 08-02-2006, 12:04 PM   #5 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Check out the forum below for tips tricks etc...BOBISTHEOILGUY
http://theoildrop.server101.com/cgi/ultimatebb.cgi
Proud Canadian BOOB man too!!
cdnsarguy is online now
Old 08-02-2006, 07:32 PM   #6 (permalink)
caterpiller has a filter cutter i can not remenber the tool number. you can check the site for the local dealer.
WOT91 is offline
Old 08-02-2006, 09:51 PM   #7 (permalink)
Baldwin has em, Ive got one. If you go to your local Baldwin dist, not a little auto parts they may cut it open for ya to show you how well it does or doesn't work.
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
Old 08-02-2006, 11:50 PM   #8 (permalink)
My Photos: (9)
Yool guys are A-OK! Never heard of a Yak saw before but it sounds cool where can I get one?
Good idea going to a Baldwin dealer. There's a Fleetpride near me I'll give them a try.
88 E350 7.3 C6 154k
2. 500 1. 500
4. 460 3. 420
6. 540 5. 465
8. 480 7. 540
Old 08-03-2006, 07:43 AM   #9 (permalink)
wouldent one of these work
http://www.autozone.com/in_our_store...ipe_cutter.htm
you should be able to get one at any parts store and they shouldent put any extra shavings in.
94 F350 4-door Behemoth with 5 speed 4X4
N/A All stock for now
79 CJ-7 with a pulled 360 waiting for a 6.9
Jred is offline
Old 08-03-2006, 10:38 AM   #10 (permalink)
My Photos: (9)
I use an air chisel...not perfect, it does get a few chips in the filter but not many and I can tell what it did vs what might have come from the engine.
Birken
Birken Vogt is offline
Old 08-04-2006, 03:35 AM   #11 (permalink)
My Photos: (33)
I use something similar, an automotive body panel cutter. It looks like a little 3 fingered fork you put in the air chisle and cuts by removing about 3/16" worth of sheet metal in a nice little ever growing curl as you go. Just get it started near the threaded base and zip it on around, like a can opener. http://www.autotoolmart.com/cgi-bin/...&p_catid=0 second from left
95" Extd Cab F250HD 4x4 DRW, /86"6.9 T19 GV o/d 3.73 axles, Hypermax Pulse turbo, intercooled / Modified Hypermax ram air induction, PowerShot 2000 LPG system "first design". Ride rites @ all 4 corners, Dana 50 mono Beam up front, Ford 10.5" in rear with 4 wheel disk brakes. Other Truck, 1983 IHC "S" with 14ton NoMar wrecker body, 30,000 GVW, 229"wb with a 6.9L IDI, Clark 5sp, 5.57 rinp&pinion, turbo charged and intercooled (with LPG soon).
Huff is offline
Old 08-04-2006, 07:50 AM   #12 (permalink)
SRR
Well, you find a yack saw at a yool store. Where else? LOL
Don
SRR is offline
Old 08-05-2006, 08:49 AM   #13 (permalink)
The one I have is made by Champion that I used on aircraft filters. I have not tried it on my truck yet, so I'm asuming it will fit.
89 F250, 7.3 IDI n/a, overhauled E4OD with upgrades & billet torque converter 12/05, 3.55, all sensors replaced, 15k High volume low resistance tranny cooler. Alternator mod. Headlight mod.
datkinsonsr is offline
Old 08-07-2006, 03:02 AM   #14 (permalink)
Just about anyplace that sells aircraft parts will carry them ( filter inspection is part of normal service ). there's a number of places online.
----------Robert
'92 F-350 7.3 5 spd, Crew Cab dually,ATS turbo, 4" Exhaust, Air seat, Western Hauler bed. My Gallery
RLDSL is offline
