You need the rear axle from a zf-6 speed truck. You can use a zf-6, but you wont have a speedo, because it reads from a pick-up in the axle housing, not the rear of the trans.
1985 F-350 6.9 IDI w/101k miles, RC, 4x2, DRW, 4.10 gears, ZF-5speed, 5" stack, manual glow plugs, flatbed, buckets and center console off a bronco and no soup bowl!
Pics.: My Truck
Up next: Turbo, full instrumentation, hydroboost brakes
You also have to use the SD transfer case due to a difference in the splines connecting trans to tc. There is a member on here that did it,he had the truck up for sale lately....
Diesel Mechanic 28 yrs
No you cannot just swap them out. They're too different. "jaybee" is a member here and did fab up a ZF6 swap to his 7.3 IDI. He also has pictures in the photo gallery here. He's the only one I've seen do this swap.
Heath
__________________ 1986 F250HD 4x4 7.3L IDI '95 PSD front clip, '97 bed, T19, D60/10.25 with 3.55's. Rebuilt from the frame up. Banks Turbo, DPS IP & Stage 1's, Isspro TTM, Banks Exhaust, Boost gauge, Pyrometer, Precharged Coolant Filter, Holley Red Pump. 16.5 x 37 x 12.5 Goodyear Wrangler's, Air Horns. 6in lift, Fresh Paint, On-board Air. Revamped Interior. Rhino Liner.
thanks for the info kida thought its was gonna be like that but when i do the cummins swap mabe just buy the adapter plate for a zf6 and it not be so bad to do..
