zf won't go in reverse - Diesel Forum - TheDieselStop.com
Old 09-25-2008, 07:35 PM   #1 (permalink)
Smile zf won't go in reverse
Hello ya'll 1st time on site I have a '93 f250 4x4 7.3 zf-5 4.10's If rolling forward , or stopped aimed downhill will not go in rev. if it aims up or bump against curb etc. goes right in no grind temp/drive time not differance ,only had about a mo. 300,000+mi. I was told. Any help would be appreciated Thanx!
wolfer565 is offline   Reply With Quote Quick reply to this message
Old 09-25-2008, 09:20 PM   #2 (permalink)
chuckster57's Avatar
Welcome To Tds
If the clutch has 300k+ miles, it may be worn out...
Train Horns: Pictures here
PM please not visitor message
chuckster57 is online now   Reply With Quote Quick reply to this message
Old 09-25-2008, 11:43 PM   #3 (permalink)
have thought about that , no issues in forward gears though , I do have cl/brk bushing set just not installed yet lot of slack in linkage ,crossing fingers on that ,just did'nt know if this is a common problem (rev.)or not Thank You.
Old 09-25-2008, 11:54 PM   #4 (permalink)
cdnsarguy's Avatar
My Photos: (109)
Check the firewall for cracks and flexing around the booster etc. If the pedal bushings/linkages are worn that will cause some problems.
Visit....... http://www.zf-group.com/pdf/S5-42.pdf
Proud Canadian BOOB man too!!
cdnsarguy is offline   Reply With Quote Quick reply to this message
Old 09-26-2008, 02:39 AM   #5 (permalink)
tak'n a guess probably need extra set of eyes to check flex?Thanks.
Old 09-26-2008, 05:28 PM   #6 (permalink)
You may have air in the hydraulic system due to a faulty slave or master cylinder, and if the clutch is worn it aggravates the problem even further.
srt0353 is offline   Reply With Quote Quick reply to this message
Old 09-29-2008, 05:23 PM   #7 (permalink)
Sorry about reply time, no external fluid, hauled aload of green wood no problem,but will look closer thanx.
Old 10-03-2008, 08:21 PM   #8 (permalink)
Can't be air 'cuz theres no problem in the forward gears. Mine was really hard to get into rev. it would always pop out and grind. put a new clutch, flywheel and throwout bearing works great!
1990 F250 rag cab 7.3 340,000 ZF5, 4x4, stright pipe, flatbed,Meyer 7'5" snowplow.
1997 F350 XL, 7.3, 112,000, auto, 4x4, CC. all ways pulls 4,000 work trailer.
Andy7.3 is offline   Reply With Quote Quick reply to this message
Old 10-03-2008, 11:00 PM   #9 (permalink)
I trick I just learned about ZF5s is to ditch the ATF from their case and fill 'em up with motor oil, 30W for time being, they can tolerate up to 50W. You need straight oil too, not 10W30 or something of that sort, just SAE 30 and if that don't elp SAE 50. Don't know why that works, but sometimes it does, so give it a shot.
M.L.S.C. is offline   Reply With Quote Quick reply to this message
Old 10-04-2008, 08:50 AM   #10 (permalink)
cdnsarguy's Avatar
My Photos: (109)
Try sliding the shifter to 5th but not in and then to reverse........ ford mech showed me this one the other day on a truck in the shop with same problem.
Old 10-07-2008, 10:53 AM   #11 (permalink)
ColLonewolf's Avatar
I have found at times that if you let the clutch out just a bit as you try to put it into reverse it will slide right in.
2004 Ford Excursion 4X4, 5.4L V8, Forest Green/Grey, Automatic, 285/75R16 BFG AT KO
1983 Mercedes Benz 300SD Turbo Diesel, 3.0L Inline 5, 4 Speed Auto, White/Parchment, VDO Boost Gauge, 215/60R15 Bridgestone Potenza RE960AS Pole Positions on 15X7 15 Hole Wheels, Straight Piped, 298K?
ColLonewolf is offline   Reply With Quote Quick reply to this message
Old 10-07-2008, 11:17 AM   #12 (permalink)
chris u's Avatar
My manual for the 97 says you have to go to move the left of third and fourth before going into reverse.
97 F 250 4 inch lift with toyo LT 285/75/16 tires on ultra 16/ 10 wheels. Five speed manual transmission. Edge evolution programmer set on level 2 race. MBRP 4 inch turboback exhaust DYI 6637 intake and s&b cold air intake still trying to
decide what to use, ISSPRO pillar mounted gauges and a nice stereo system not going to list all that.
2007 chevy cobalt K&N cold air intake,Eibach prokit springs and 205 50 ZR 17 BFG g force sport tires on Konig wheels. With a sound system that will make you deaf.
2004 polaris sportsman 700 twin EFI with ITP 589 tires.
2001 honda cr 500 last year of the big 2 stroke.
98 polaris rmk 700 with big bore and way to much to list.
97 rmk trail 500 a little clutch work.
2005 ford focus ZX4 wifes car. Totaled 10/08
07 Mazda 6 wifes new car.
2000 F150 5.4 auto wifes truck
chris u is offline   Reply With Quote Quick reply to this message
Old 10-10-2008, 07:55 PM   #13 (permalink)
Well , I changed the clt/brk pedal bushings ,helped ALOT but will still grind & not go to rev. sometimes pumping clutch will help(after changing bushings) may have to plan on total clutch &assy. replace . Does it matter 30w. is detergent or non-detergent? Clutch will have to wait abit wonderful ex-wife can't wait to cost more money LOL!Thanx for info.
Old 10-10-2008, 08:44 PM   #14 (permalink)
Originally Posted by wolfer565 View Post
sometimes pumping clutch will help....may have to plan on total clutch & assy. replace .
Sounds like you need a new master cyl and slave cyl assembly....about $215 at NAPA....pull the throwout arm and clean and grease it at the same time....
1993 F350 XLT Crew Cab 4x4 factory turbo diesel, 5-spd, 4.10s w/towing package, bench seats (fits family), white paint, sprayed bedliner, "Rackit" lumber rack.
This was exactly the truck I was looking for...
now 327,000 miles & 8 yrs (bought with factory remanufactured engine @ 119K miles)
14.5 mpg @ 65 mph cruise control & AC
Casually looking for a good used (secondary) overdrive....
Real trucks don't have spark plugs!
-Guy-
Escondido, CA
GuyW is offline   Reply With Quote Quick reply to this message
Old 10-11-2008, 10:16 PM   #15 (permalink)
Thanx for the info have to wait on payday to do anything else rite now but have a good plan to start on Thanx again everybody! let cha know asap.
Wheel & Tire Center
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
