15" rims wont fit - Diesel Forum - TheDieselStop.com
Old 11-11-2009, 03:18 PM   #1 (permalink)
Unhappy 15" rims wont fit
hi, i just bought a set of 15" 8 lug rims for my truck, since tires are harder and harder to find for 16.5. the guy i bought them off of said they were on a 77 f250. anyhow i went to put them on and they wouldnt fit. they hit my brakes. what should i do now? please, help would be much apppreciated
1984 Ford f250, recent 7.3 swap, 4x4, 4 speed, 35"s, 5" stack , turned up fuel and advanced timing
1994 Ford f350, 7.3, 4x4, auto, crew cab long bed, strait piped.
CSRadel is offline
Old 11-11-2009, 03:28 PM   #2 (permalink)
I have an 84 van, and you're right, it's @#$% hard to find the 16.5 tires.
I've been told I should go to 16 inch wheels.
I have another post, going now, that asks which vehicles have rims that will work.
wheel Swap
longwolf is offline
Old 11-11-2009, 03:51 PM   #3 (permalink)
whats the bolt pattern?
early 1999, 7/98, F-250 7.3L, 250,000+ miles, 4x4, triple disk torque convertor, AFE dryflo home made cold air intake, straight pipe exhaust, superchips tuner (stuck on high performance tune,because someone stole the tuner out of my truck), 4.7K mod, Glow shift gauges (pyro, boost, egt), CCV mod, 3in of lift in front, 1in in back w/ 2009 SD rims w/ 2in wheel spacers wrapped in 325/65/18 Fierce Attitude MT, aftermarket headlamps w/ LED's, ranchhand grill guard, 03' front bumper w/ fog lights, gooseneck hitch
browningbuck225 is offline
Old 11-11-2009, 04:07 PM   #4 (permalink)
My 1 ton hase an 8 lug pattern.
I'm pretty sure CSRadel's 3/4 ton would have the same pattern.
longwolf is offline
Old 11-11-2009, 04:22 PM   #5 (permalink)
well you said it was an 8 lug, i have that. but is it a 8x6.5 like a chevy or dodge or an 8x170 like a newer model ford? yours may have an 8x6.5, id go out and measure it though. if it is an 8x6.5 and rim from late model chevy and dodge will fit being it in the 16" to 17" range
Old 11-11-2009, 04:42 PM   #6 (permalink)
bugman's Avatar
My Photos: (18)
Most of the Chevy and Dodge rims won't fit over the Ford's hub unless they are aftermarket or you grind the centers out. Any Ford rim that is 8x6.5 should fit as long as it is a 16" or larger. The Superduty trucks changed their bolt pattern in 99 but the vans kept the 8x6.5 for quite a while. I am not sure if they have changed them yet. I have a set of rims with tires on them for an OBS truck or van depending on where you are at since shipping would kill your idea of cheap.
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is offline
Old 11-11-2009, 06:18 PM   #7 (permalink)
hougie's Avatar
My Photos: (11)
your rotors and drums are to big for a 15" rim
2004 CREW CAB PSD, no mods, 305/70/16R wrangler MTR.
1985 ford f-250 4x4 6.9l sc "the beast"
4" lift, 35" toyo mud terrain's, Ip turned up, stacks
http://photos.thedieselstop.com/show...hp?photo=18913
hougie is offline
Old 11-11-2009, 11:08 PM   #8 (permalink)
okay, its an 8x6.5 bolt pattern. they fit on the studs.. but they only go on about 1/4 inch before the rotor and caliper hit the rim. they came off a ford, i know that much, and it was a 77 f250. they fit on the back fine, they just hit on the front. what should i do? wheel spacers? do they make a smaller aftermarket rotor?
CSRadel is offline
Old 11-11-2009, 11:10 PM   #9 (permalink)
or you could do what bugman said and grind a little off the center of the rim
Old 11-11-2009, 11:47 PM   #10 (permalink)
they are white spoke steel wheels, how much could be ground off safely?
CSRadel is offline
Old 11-12-2009, 12:49 AM   #11 (permalink)
Joe Mc's Avatar
My Photos: (39)
Go with the 16 inch like the stock 86 f-250 uses, they are a lot easier to find than the 16.5 inch. When I first bought my truck and needed a spare the local used tire shop had a whole pallet on brand new 16 inch rims for my truck.
Red 86 F250 Supercab XLT: Longbed, 6.9l, 4 speed with DNE-2 Overdrive, 2WD, 10.25 Sterling 4:11, Reclining Highback Captains chairs with arm-rest, Holly Red pump, push-button glowplugs, Racor 645 water separator with fuel heater, K&N Air Filter, Headlight Relay Upgrade, Fog Lights, lots of extra lights, Isspro EV series: Pyro, Oil Pressure, and Voltage in a Autometer 3 pod A-pillar. Bulldog Security System with remote entry. Offset Mirror Upgrade, Remote lube TOB. Road Watch System coming soon. PB PS PW PDL CC AC IW
BOOB man - Brotherhood of Oil Burners
1995 Toyota Camry DX: 2.2L, Bolt-action 5-speed, AC, PS, PB, CC.
Triple A-pillar pod: Isspro EV voltage and oil-pressure gauges.
Road-Watch System (Air and road-surface temperature gauge).
Chicken Lights Gone.
Joe Mc is offline
Old 11-12-2009, 10:48 AM   #12 (permalink)
so you guys say my best bet would be to sell my 15" rims and tires i just bought and get a set of 16"?
CSRadel is offline
Old 11-12-2009, 01:37 PM   #13 (permalink)
yea thats the only thing you can do, because the 15's will NOT fit
Old 11-13-2009, 11:00 AM   #14 (permalink)
so theres no way to make 15" fit?
CSRadel is offline
Old 11-13-2009, 11:41 AM   #15 (permalink)
6.9Laska's Avatar
nope the trucks are not made for a 15 inch rim the brakes are to big for the rim to slide over it. no way around it. get some 16 inch rims the a dime a dozen
04 F250 XLT SD CC 4X4 auto 6.0 powerstroke, red ELC, coolant filter, welded EGR cooler, scangaugeII
84 F250 XLT 6.9L 4X4 4 Speed T-19
6.9Laska is offline
