1983 6.9 diesel - Diesel Forum - TheDieselStop.com
post #1 of 35 (permalink) Old 02-21-2006, 08:47 PM Thread Starter
1983 6.9 diesel
Ok, I replaced my starter and my I.P. I BLED THE FUEL LINES!
And my truck STILL will not start. I DON'T KNOW WHY?!??!?!?!
before you ask question read this.
-BOTH BATTS ARE BRAND NEW AND CHARGED FULLY
-TERMINALS ARE BRAND NEW
-THE COMPLETE GLOWPLUG SYSTEM IS NEW AND IS WORKING
-ALL THE ELECTRICAL SYSTEM IS WORKING
My Rig:
1995 F350 Crew Cab, Dually, 4.10 gears.
-ATS Auto Tranny
-3.5" Downpipe
-Straight pipe'd
-TS 6-pos Chip
-FPR Mod
-IDM Mod
-DIY Intake
1983 Ford F350
-6.9idi
-Straight piped
-K&N Air filter
MercuryLs is offline
post #2 of 35 (permalink) Old 02-21-2006, 09:08 PM
Re: 1983 6.9 diesel
Are you getting clear fuel out of each and every injector line?
Will the engine start if warmed with the block heater?
Are you holding the accelerator to the floor when trying to start? (to bleed out any remaining air)
Will the engine start on propane? (just stick a torch in the intake, it works!)
What were the original circumstances of the truck not starting? Did it die while running, or did it just not start one morning?
1997 Ford F350 SRW 7.3L PSD
1985 Ford Ranger 2.3L 5 speed
1966 Mustang 200 I6, auto, 4 wheel disk, power brake retrofit, Corvette master.
Former vehicles, 1994 E350 7.3L IDI, 1985 International 1654 rollback, 6.9L IDI, (2) 1994 Ford E350 7.3L IDI, 1985 Ford F350 DRW 6.9L IDI, 1985 Ford F350 wrecker 6.9L IDI.
*dual ASE Master Certified, Automotive, Medium & Heavy trucks*
Owner / operator, Patriot Automotive, N Ridgeville OH
Mr_Roboto is offline
post #3 of 35 (permalink) Old 02-21-2006, 09:19 PM Thread Starter
Re: 1983 6.9 diesel
1)yes
2)no
3)yes
4)no
5)long-story-short.... Replaced Alternator, then voltage regulator went out causing everything in the electrical system to be fried. Replaced everything in the electrical system (EVERY THING WORKS NOW).-still no start-found out the shut-off solenoid went out. So I replaced the IP. Stater went out when bleedinf fuel lines, so I replaced the stater.
Don't tell me it a fuse, relay, or fusable link. ALL of them have been replaced. AND TESTED!!!!!!!!!
It also WILL NOT start on starting fluid or WD40.
I was driving down the highway AT NIGHT when the voltage regulator went out- causing every light to go out. I took the next exit, 800 feet away, and the engine died on the off ramp. NEVER TO START AGAIN.
My Rig:
-ATS Auto Tranny
-3.5" Downpipe
-Straight pipe'd
-TS 6-pos Chip
-FPR Mod
-IDM Mod
-DIY Intake
1983 Ford F350
-6.9idi
-Straight piped
-K&N Air filter
post #4 of 35 (permalink) Old 02-21-2006, 09:27 PM
Re: 1983 6.9 diesel
on these trucks you can run a single wire from the battery to the Ip for power if your worried bout the wiring on the truck..i myself use WD40 or silicon spray spray it in intake while turning it over should fire right up..
cb239 is offline
post #5 of 35 (permalink) Old 02-21-2006, 09:38 PM Thread Starter
Re: 1983 6.9 diesel
1)yes
2)no
3)yes
4)no
not to be be rude,but please read the bold print.
I GET A LOT OF THE SAME QUESTIONS OVER AND OVER AGAIN!!!!!!!!!!!
My Rig:
-ATS Auto Tranny
-3.5" Downpipe
-Straight pipe'd
-TS 6-pos Chip
-FPR Mod
-IDM Mod
-DIY Intake
1983 Ford F350
-6.9idi
-Straight piped
-K&N Air filter
post #6 of 35 (permalink) Old 02-21-2006, 09:52 PM
cdnsarguy's Avatar
My Photos: (109)
Re: 1983 6.9 diesel
OK MercuryLs
Explain to us how you replaced the IP........hope you did not follow the instructions in the Haynes Diesel engine repair manual IE remove the timing gear tower and IP together.............please say no. [img]/ubbthreads/images/graemlins/eek.gif[/img]
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #7 of 35 (permalink) Old 02-22-2006, 08:25 AM
Re: 1983 6.9 diesel
Man oh man, if it won't start on ether I think you have to start looking at mechanical problems. I think a compression test is in order.
Yea, I know an electrical meltdown started it all.... But we need to isolate the 3 elements of engine combustion, i.e. Compression, Ignition and Fuel.
Another thought, I think that if the injectors are firing, but firing at the wrong time, that might keep the engine from starting on ether. Maybe disconnect the FSS so the injectors don't fire, then try an "alternate fuel" again....
post #8 of 35 (permalink) Old 02-22-2006, 01:43 PM
My Photos: (23)
Re: 1983 6.9 diesel
I'm with Pete. Back up and tell us the whole story. Also, consider jacking the back end of the truck up, high enough that the engine is actually tilted forward. This will really help get the air out of the lines.
- Mel
1983 F-250HD 4X4
55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW
1987 Bronco
1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
agnem is offline
post #9 of 35 (permalink) Old 02-22-2006, 07:47 PM Thread Starter
Re: 1983 6.9 diesel
OK MercuryLs
In answer to that, no.
Ok, I was playing w/ the truck again today and this is what it sounds like when it trying to start....
It sounds like a 6.9 trying to start w/ no starting fluid or glowplugs. Like it wants to start, but never does.
My Rig:
-ATS Auto Tranny
-3.5" Downpipe
-Straight pipe'd
-TS 6-pos Chip
-FPR Mod
-IDM Mod
-DIY Intake
1983 Ford F350
-6.9idi
-Straight piped
-K&N Air filter
post #10 of 35 (permalink) Old 02-23-2006, 07:03 AM
Re: 1983 6.9 diesel
from what your stating,this thing should run like a raped ape,maybe its time to backtrack on a few items,Not saying you did,but are you sure you put the lines on right on the back of the pump,and are you for sure getting power to the pump,<it wil not start on no fluids if the pump isnt powered up,if all this checks out ok,maybe you need to get that new pump checked out from where you bought it,you did all that can be done<asuming it ran great before the electircal problems>i would revert back to that new pump and get it checked out..
cb239 is offline
post #11 of 35 (permalink) Old 02-23-2006, 10:38 AM
My Photos: (23)
Re: 1983 6.9 diesel
If your not getting any smoke out of the tailpipe while cranking, you are missing compression, or fuel, or both.
- Mel
1983 F-250HD 4X4
1993 F-350 CC DRW
1987 Bronco
agnem is offline
post #12 of 35 (permalink) Old 02-23-2006, 02:55 PM
Re: 1983 6.9 diesel
Well...I'm wondering if there's any way you made it jump timing on the gear. If you even loosened the timing gear tower the gear timing could be off. If you did not line up the timing marks the static timing MAY be far enough off to cause no start. What I don't understand is if it won't start on starting fluids. Good luck,
J.D.
J.D.'s Fords: 1986 F-250 6.9 diesel Solid State Glow Plug System 3.55 gears C-6 2WD 178,960 miles.... it still runs pretty good!
Wishlist H-max turbo, T19 tranny,
1989 Ford Ranger ga$$er, non runner, soon to be donated or scrapped!
jdkline is offline
post #13 of 35 (permalink) Old 02-23-2006, 08:03 PM
Re: 1983 6.9 diesel
J.D.
What if the timing was severely advanced? I think the fuel might cool down the combustion chamber enough that ether wouldn't ignite. Maybe.
post #14 of 35 (permalink) Old 02-23-2006, 09:45 PM
Re: 1983 6.9 diesel
Hey i'be been reading your post and it interested me. Have you checked the eletrical wire going to the IP. If you disconect that wire the engine will cut off and will not run. So if your not getting any power to it then you can try to start it all you want. Its not goin to run.
Just my 2cents
2001 F350 Lariet CC dually 4x4 7.3L Powerstroke w/4:10's Two tone black and gold. Mods so far
AFE STGE2 Intake/ITP KCM S.S. HPX Line/Foil delete/ 6 inch bull hauler stacks/dipricol guages(trans temp,boost,EGT)/ Ported turbo shroud NON-ATS/
DP-tuner F5 (No-start,Stock,1500 high idle,40 tow,60 tow, 80E,120 race, 140)
"SOLD" 1985 F350 Crewcab dually with banks
wastegated turbo and gearvendors under/overdrive. 3.54 gears
TRUCK PICS
daveb198 is offline
post #15 of 35 (permalink) Old 02-25-2006, 11:06 PM
Re: 1983 6.9 diesel
I could be mistaken, but I think that ether or other starting aids will ignite even without the FSS being connected. But as soon as it burns, it will die in a hurry. The FSS only controls a nopramlly operating IPs fuel supply. From hard personal experience, if you get into a runaway condition, even removing the wire will not stop the engine. Think about it...for a diesel to run you need
1) combustible fuel 2) air 3) compression.... you have all of tehse with starting fluid and the FSS wire disconnected, if only momentarily until teh fuel runs out. I still suspect the timing myself...it is so darn easy to mess up teh timing when that pump is off. Ithas to be either that or a mechanical problem(low compression) or some sort of air obstruction, but I can't think of something obstructive enough to stop that monster from at least running somewhat.
jdkline is offline
