It sounds like to me it is sucking air in the fuel system somewhere. Check the hard metal lines going to the filter housing and the injector pump, the brass fittings have rubber gaskets in them that after time will get hard and crack. There is also a possibility the filter housing could be cracked and sucking air. After you address the sucking air problem and the truck still seems slow with no power, change the fuel filter, if that does not help change the injection pump and injectors. Good luck!
1989 F-250 4x4 7.3 C-6 315000 miles and counting-sold
2001 Excursion Limited 4x4 7.3 165000 miles-new transmission-12-24-12
2008 F450 XLT CC 4X4 4.88 gears 11' Reading Service Body 168000 miles-too nice to be a work truck-new engine, 5th radiator
2001 F250 4X4 Lariat CC bought April 2011 185000 miles
