1986 F-250 6.9 L injectors - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 09-07-2005, 03:11 PM Thread Starter
Hi all, new to trucking with the 6.9L, I was hoping if anybody would know if it important to use the same injectors with the pump, like A's or B's etc. injectors are they just about the same, and how do you fine out if you are useing the right ones, with your pump?
thanks
Phil
1986 F250 6.9L 4 spd vin 1FTHX2619GKA52915 build date 11/85
claywake is offline
post #2 of 10 (permalink) Old 09-08-2005, 01:05 AM
Re: 1986 F-250 6.9 L injectors
You can't (not a good idea, even if they physically will bolt up) interchange the '83 'A' parts and later parts. If you want the details, go here and download "69lupdatepart4.pdf" and look at page 3 ("A4"). There were major changes in '84 (higher compression ratio, different pistons, different heads, different precups, different injector internals and popoff pressure, etc.). Note esp. the paraphraph that reads,
"DO NOT INTERCHANGE 1983 ("A" model) with 1984 and later ("B" model) nozzles. Engine performanc will be adversely affected."
That's straight from Ford.
Al S.
SOLD1984 F-250 4x4 C6, BW1345, 3.54 D70, XLT extra cab, box-stock so far.
asavage is offline
post #3 of 10 (permalink) Old 09-08-2005, 10:11 AM
My Photos: (23)
It might be streight from Ford, but don't believe it for a minute. I have both A and B engines, and you can pretty much do what you want as far as injectors are concerned. None of us worry much about running factory calibrations anyway. As long as you have a pyro, you can put whatever injectors you want in there. Ford is more worried about emissions and EGT's for the uneducated with that particular statement. Looks like somebody needs to take better care of "the diesel files" since it's obviously been comprimised.
- Mel
1983 F-250HD 4X4
55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW
1987 Bronco
1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
agnem is offline
post #4 of 10 (permalink) Old 09-09-2005, 01:09 AM Thread Starter
So the pump does not have to match up with the injectors, A's or B's etc.My year is 1986 F250 6.9 L It has A's now, but on ebay someone has D's he say's they add a little bit more fuel, I want less smoke, I do know you are to have some smoke though, and D's will smoke a little more? Do you all think this is right way of thinking. [img]/ubbthreads/images/graemlins/confused.gif[/img]
claywake is offline
post #5 of 10 (permalink) Old 09-09-2005, 03:47 PM
My Photos: (9)
The letters indicate pressure changes, but likely all the injectors move about the same amount of fuel. Maybe not [img]/ubbthreads/images/graemlins/tongue.gif[/img] What color smoke do you have? New injectors may help if the smoke is due to improper combustion, but if you are over-fueling, have bad timing (inj pump settings both) or have maybe something else (how's your air filter/intake system?) new injectors may not help.
James
<font color="green">
4x4 Extended Cab XLT Lariat, 3.54 LS, Pioneer radio, C6, Straightpiped</font> (Listen:
)<font color="green">
200k+ miles
</font> Down since 1/03
<font color="red">Work in progress
</font>
<font color="cc3300">
Deluxe 'The BOMB' 318 V8.
350 diesel, loaded.</font>
1995 Toyota Camry
'The Battle Wagon' Unfortunate DD. 242k
Member of FOKISD
<font color="orange">"Fighting for religion, something I don't understand."</font> - Dave Mustaine
highest_vision is offline
post #6 of 10 (permalink) Old 09-10-2005, 02:25 AM
Injection quantity in a diesel is controlled by the IP, not the injector. This is in contrast to a gasser, which uses a fixed pressure and injector ON time + orifice diameter to control fuel quantity.
However, the different injectors used on our engines are rated for different fuel volume. This means that if you use a lower-volume injector at a high IP volume setting, the pressure on it will be proportionally higher -- or something will break. That's the nature of hydraulics.
The 'B' injectors are supposed to have longer spring travel, a larger orifice, and lower (1425 PSI) opening pressure. These were offered in conjunction with a higher compression ratio (pistons .003" higher, whoopee!; larger swirl cavity in the pistons' crowns; smaller precup chamber in the head -- making the heads non-interchangeable from '83 to later engines; smaller volume precups), and recalibrated fuel curve in the IP to work with lower opening pressure injectors.
I don't know the 6.9l very well, but based on this (published) information, I personally wouldn't mix 'A' model parts (IP, injectors, pistons, heads) with later lettered parts, with the possible exception of a later IP &amp; injectors -- as a set.
Al S.
asavage is offline
post #7 of 10 (permalink) Old 09-14-2005, 01:41 AM Thread Starter
I have black smoke under load, I thinks more than the norm, new air filter, and fuel filter, the engine has 800 K,s on it now, just rebuilt it, but not the pump or injectors.
claywake is offline
post #8 of 10 (permalink) Old 09-14-2005, 02:31 AM
Whoa! 800K? Kilometers or miles? or did you mean 80K miles? If 800K either which way you can bet that pump and injectors are toast if original or probably even older than 200-300K miles. Avg lifespan on the ones from the factor way &lt;100K on the early pumps and maybe 150-200K on later units and remans... I think if you ahve a rebuilt engine you owe it to yourself to spring for the pump and injectors as a set. I ahve heard it both ways on the 83 injectors....but Mel usually knows what he's talking about. Personally, I would just make sure the timing is good and get a set of injectors which are compatible. In other words don't mix "A" and "D" injectors or "G" and "BB" and so on.
J.D.'s Fords: 1986 F-250 6.9 diesel Solid State Glow Plug System 3.55 gears C-6 2WD 178,960 miles.... it still runs pretty good!
Wishlist H-max turbo, T19 tranny,
1989 Ford Ranger ga$$er, non runner, soon to be donated or scrapped!
jdkline is offline
post #9 of 10 (permalink) Old 09-14-2005, 10:17 AM
Put you year make model VIn # and any other details about your truck in your Signature so we can accurately assess problems with your truck. [img]/ubbthreads/images/graemlins/grin.gif[/img]
85 Ford F-250 4X4 6.9 diesel - R134 New AC/New rear-end/New Transfer Case & Clutch/New ignition (yes all of it)/New block heater (works great)/New injectors/bypassed water seperator on firewall - Owned this since 1989 :-) T-19 4spd-No Ovedrive 15MPG ave @ 67MPH - 2nd owner
jmjames is offline
post #10 of 10 (permalink) Old 09-14-2005, 10:17 PM Thread Starter
The total kilometres is 475, I did the rings about 800 kilometres ago.
Over all the truck runs great, just black smoke under load, I would say more than normal.On the injector pump, there are some no.s 5708,and on the injectors, The first letter is an A .
claywake is offline
