Re: 1987 F250 Automatic 4wd tranny
The bolt bellhousing bolt pattern for the diesel C-6 is different then the gasser versions. The bellhousing looks similar to a big block C-6 but slightly different. You could possibly get a 2wd one and convert it to a 4x4 using some parts from your current tranny but that would involve quite a bit of work. Basically need to remove everything in the case to swap the output shafts on the end of the tranny (look at pics in my gallery) But sadly to say I believe you will need to find a C-6 that was nestled behind a diesel. Hope this helps, and maybe some more knowledgable about the bellhousings will come along and comment.
86 Ford F250 4x4 with 4in Rough Country lift and poly bushings all around converted from 351W to 6.9L Diesel (rolling chassis at the moment)
05 F350
