Originally Posted by B-rad
Prerunner diesel????? Are you going for look or function? You may have a problem with front end weight and that you have leaf springs. MOST all prerunner setups are coil or coil over setups.
The 86 2-wheel drive has coil springs in the front, the 4-wheel drives have the leaf-springs in the front.
Red 86 F250 Supercab XLT, Longbed, 6.9l, 4 speed with DNE-2 Overdrive, 2WD, Reclining Highback Captains chairs with arm-rest, Holly Red pump, push-button glowplugs, Racor 645 water separator with fuel heater, K&N Air Filter, Headlight Relay Upgrade, lots of extra lights, Isspro EV series: Pyro, Oil Pressure, and Voltage in a Autometer 3 pod A-pillar. Bulldog Security System with remote entry. Remote lube TOB.
BOOB man - Brotherhood of Oil Burners
