4 speed cruising RPMs - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 01-13-2007, 10:28 PM Thread Starter
Send a message via AIM to VD350
Ok out 7.3 had a cracked block so we went out and bought a 6.9. My question is will this thing be revving quite a bit more at 55mph than the 5 speed? What RPMs are you guys usually running?
1986 F-250: 6.9L XL 4x4, 4.10 rear, 4 speed, Wellman GPs, 127,000 and chuggin along like new
1985 Mercedes 300SD: Daily Driver, straight piped
VD350 is offline
post #2 of 7 (permalink) Old 01-14-2007, 08:59 AM
My Photos: (14)
Re: 4 speed cruising RPMs
Final drive gear (rear differential) will determnine your cruising RPM. The 5 speed in OD drops RPM's like 20%, so if you were turning 1800 at 55 in 5 spd od, then you will be turning 2100 to 2200 (1800 x 1.2 = 2160) with the 4 spd. If you have the 5 speed, why not use it with the 6.9 as well?
1987 F250 6.9 4X4 - T19 Trans, 4.10 Dana 60 Front/Ford 10.25 rear, Dual Rear Wheels, Carter P4594 electric fuel pump, Restrictive air filter opened up, Firewall repair kit installed, new clutch m/cyl and pedal bracket, bushings etc.,7.3 fuel filter conversion, Solid state controller OEM (new controller and Motorcraft GP's), Headlights converted to relay system with 65/100 Watt Cold Ice bulbs, Class V Hitch (10,000lb WC/15,000lb WD), Air Horns, Cadet 7' X 9' flat dump bed, 5 ton grainmaster dump hoist.
sle2115 is offline
post #3 of 7 (permalink) Old 01-14-2007, 09:33 AM Thread Starter
7.3 is going back to the owner and were getting our money back, otherwise YES I would definatly swap it over. thanks
VD350 is offline
post #4 of 7 (permalink) Old 01-14-2007, 12:26 PM
????? What difference does it make whether you have a 6.9 or a 7.3 when it comes to the transmission?
If you go to www.ringpinion.com there is a chart that will tell you all you want to know about different gear and transmission combinations.
Jim
1986 E350 6.9 based 27' MH. Weights 15,000# ready to travel. Hypermax conventional turbo. All exhaust to turbo pipes wrapped with 2" Thermotec pipe insulation. Turbo hot side wrapped with " thick 2000 pipe wrap blanket material. Cold side wrapped with Foam sound deadening material. Turbo is silent! Hypermax hood inlet cool air intake system. Down pipe oulet to 3" then split to 3" dual exhaust exit behind rear tires. 3" in-out X 36"long round Walker mufflers. Ziggster40 design based propane injection. Gear Vendors Overdrive. 235/85X16 tires. Isspro EV pyrometer. Isspro 0-15 psi manifold pressure gauge. TCI C-6 deep finned aluminum trans pan. EV trans temp gauge. 10 3/4" brake booster from '93 E-350. Towing a '87 Suzuki Samurai Tintop
jauguston is offline
post #5 of 7 (permalink) Old 01-14-2007, 05:34 PM
My Photos: (14)
Is the tranny going with it? 5 speed that is? If not, you can make it work, you just need the correct flywheel etc which you would already have on the 7.3 or you could buy a dual mass flywheel conversion unit and there are other potential ways of doing it, but I would not give up the 5 speed if you can keep from it.
sle2115 is offline
post #6 of 7 (permalink) Old 01-15-2007, 06:09 AM Thread Starter
yeah the whole thing is going back thats my point, I cant just rob what I want and return it
VD350 is offline
post #7 of 7 (permalink) Old 01-15-2007, 09:42 AM
My Photos: (14)
I guess I am/was a little confused, just thought the motor was going back, bummer, that 5 speed would be cool.
sle2115 is offline
