6.9 Diesel Questions - Diesel Forum - TheDieselStop.com
Old 10-25-2009, 06:42 PM   #1 (permalink)
Hello, I have a 85 6.9 Diesel. It was running fine, then all of a sudden I am getting diesel in my oil the motor sometimes runs away after I turn the key off (I believe it is firing on the mixture of diesel in the motor oil). Could this be a leaking injector pump or something along those lines. Any help would be appreciated. I am a bit diesel stupid so any help with this would be appreciated. This is my cattle feed truck so I do not drive it every day.
tkulak is offline
Old 10-25-2009, 06:51 PM   #2 (permalink)
First check the supply pump on the side of the block- if it's wet replace it. If not, it's most likesly the driveshaft seals in the injection pump. IP has to come apart, all seals replaced and a new drive bearing pressed in.(In other words an injector pump rebuild)
Evel486 is offline
Old 10-25-2009, 07:13 PM   #3 (permalink)
Thanks, injection pump is what I was thinking as well. I appreciate the input.
tkulak is offline
Old 10-25-2009, 09:47 PM   #4 (permalink)
Joe Mc's Avatar
My Photos: (39)
Evel486 suggested 2 different pumps, the IP, and the supply or lift pump.
Most of the Injection Pumps in use on these enginges have a weep-hole and will usually start leaking fuel on the ground long before it starts getting to the crankcase. The lift pump is the much more likely suspect than the IP, and it is cheaper to replace the lift pump.
Red 86 F250 Supercab XLT: Longbed, 6.9l, 4 speed with DNE-2 Overdrive, 2WD, 10.25 Sterling 4:11, Reclining Highback Captains chairs with arm-rest, Holly Red pump, push-button glowplugs, Racor 645 water separator with fuel heater, K&N Air Filter, Headlight Relay Upgrade, Fog Lights, lots of extra lights, Isspro EV series: Pyro, Oil Pressure, and Voltage in a Autometer 3 pod A-pillar. Bulldog Security System with remote entry. Offset Mirror Upgrade, Remote lube TOB. Road Watch System coming soon. PB PS PW PDL CC AC IW
BOOB man - Brotherhood of Oil Burners
1995 Toyota Camry DX: 2.2L, Bolt-action 5-speed, AC, PS, PB, CC.
Triple A-pillar pod: Isspro EV voltage and oil-pressure gauges.
Road-Watch System (Air and road-surface temperature gauge).
Chicken Lights Gone.
Joe Mc is offline
Old 10-25-2009, 10:02 PM   #5 (permalink)
Yes, cheaper to replace the lift pump. You can remove it and check for fuel leaking internally, but it is not common. The weep hole in the IP was introduced in the IH/Ford application in the 1986 model year. 1983-85 models had a brass bearing & no weep hole so seal failure resulted in fuel in the crankcase. These model IPs can be updated to the weep hole style but it involves replacing the pump housing & the driveshaft- both items a bit pricey.
Evel486 is offline
