6.9 injector pump timing - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 08-22-2010, 06:45 PM Thread Starter
mikeproeder's Avatar
hey so i took my injector pump off do do headgaskets and i was carefull taking it off to not spin the gear but im not sure if its right i didnt mark it or anything it is my first time i didnt know. so im wondering how i will know how to get it on right and set the timing right. thank you
mikeproeder is offline
post #2 of 9 (permalink) Old 08-22-2010, 07:14 PM
chuckster57's Avatar
If the gear cover was not removed, chances are the gears are still "timed" right. Since the IP is held on with 3 bolts and a locating dowel, it will be in the right spot. Once the engine is running, you'll know if the timing is out by the way it runs. You can make timing changes to the IP with the ENGINE OFF and loosening the bolts on the back of the housing.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #3 of 9 (permalink) Old 08-23-2010, 12:38 AM Thread Starter
o ok yeah i pulld the whole cover off the 4 bolts going to the block where it has the oil fill tube... so should i just get it as close as i can with the gears and the time it once on ?
post #4 of 9 (permalink) Old 08-28-2010, 06:27 PM
Joe Mc's Avatar
My Photos: (39)
You have to get the IP gear back in the one and only right spot. One tooth off won't do it.
Take a look at this article:
Talk About Timing. Be sure to click the under-lined links to view the pictures.
Scratch a line on the IP and the IP gear-cover to allow you to set the dynamic timing back to where it was. Then you need to get the gear back in the right spot. Because of the cut of the gear teeth, these rarely drop back in the right spot.
Red 86 F250 Supercab XLT: Longbed, 6.9l, 4 speed with DNE-2 Overdrive, 2WD, 10.25 Sterling 4:11, Reclining Highback Captains chairs with arm-rest, Holly Red pump, push-button glowplugs, Racor 645 water separator with fuel heater, K&N Air Filter, Headlight Relay Upgrade, Fog Lights, lots of extra lights, Isspro EV series: Pyro, Oil Pressure, and Voltage in a Autometer 3 pod A-pillar. Bulldog Security System with remote entry. Offset Mirror Upgrade, Remote lube TOB. Road Watch System coming soon. PB PS PW PDL CC AC IW
BOOB man - Brotherhood of Oil Burners
1995 Toyota Camry DX: 2.2L, Bolt-action 5-speed, AC, PS, PB, CC.
135,016 miles: Rear-ended and totaled by an uninsured kid having a temper-tantrum
1999 Rav4 AWD 5-speed, AC, PS, PB, CC, Sunroof.
Joe Mc is offline
post #5 of 9 (permalink) Old 09-02-2010, 03:12 PM
hesutton's Avatar
My Photos: (30)
That's not good. I'm afraid you are going to have to pull the water pump, and front cover off the motor. Otherwise, you will never be able to see the timing marks on the crank, cam, and IP gears. Please read the above article that shows how the timing marks are to be positioned. You will not be able to do this without removing the front cover. You should get a new front main seal and a front cover gasket set (will include a water pump gasket as well).
Once you have the gears in correct time, install the front cover and then install the IP gear cover. Once the IP gear cover is installed, there isn't room for the gear to jump time. Install the water pump and then the IP.
Heath
1986 F250HD 4x4 7.3L IDI '95 PSD front clip, '97 bed, T19, D60/10.25 with 3.55's. Rebuilt from the frame up. Banks Turbo, DPS IP & Stage 1's, Isspro TTM, Banks Exhaust, Boost gauge, Pyrometer, Precharged Coolant Filter,
. 16.5 x 37 x 12.5 Goodyear Wrangler's, Air Horns. 6in lift, Fresh Paint, On-board Air. Revamped Interior. Rhino Liner.
1983 F250 4x4 5.0L with C6. 340,000+ miles.
hesutton is offline
post #6 of 9 (permalink) Old 09-02-2010, 03:57 PM
My Photos: (27)
You certainly CAN get it in proper time without removing the front cover. That would be a heck of a lot of unecessary work.
LMJD is offline
post #7 of 9 (permalink) Old 09-03-2010, 12:14 AM
Joe Mc's Avatar
My Photos: (39)
In the talk about timing article if you look at the pictures zigg links to, he is showing how to get the gear back in time without removing the front cover.
Just a note not mentioned in the article: It is possible to get the gear 180 degrees out and these engines will run, just smoky and no power.
Joe Mc is offline
post #8 of 9 (permalink) Old 09-03-2010, 02:25 AM Thread Starter
i got it i uses a mirrior wit a piece of tape on it to get it down in the crack to see the y but i got it its all together thanks
post #9 of 9 (permalink) Old 05-04-2012, 11:37 PM
Definitely going to try re-timing my injector pump now. the guy before me told me he lined it up with the dot, and I thought that sounded wrong for some reason. It does run, but smoky, and with little power, as stated. How badly will the motor run if it is 180 out? The guy I bought it from said he couldn't find a y so he timed it to a dot. After reading all of this, I feel like it might be off, but I think it might run just a little too well for that. Is it possible for these to flood? It seems to run okay, but with a LOT of smoke, because I think the previous owner turned the IP up a lot, maybe too much.
'86 f-250 6.9L 4X4 4-speed
'94 Ranger 4.0L 4X4 Automatic
easterracing is offline
