Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > 6.9L Diesels
Old 07-27-2008, 11:44 AM   #1 (permalink)
83 250 teardown
my head gasket was blown, steering was bad, radiator no good and a bunch of other small problems. i decided to scrap it. I bought an 86 for 1100.00. figure i can get about 500 in scrap for the 83. but before i take it down to the yard what should i take off. so far i have the alternator, IP, tank switch, starter and batteries. what else? thanks
83 F250 6.9
wellsstyle is offline
Old 07-27-2008, 01:44 PM   #2 (permalink)
Joe Mc's Avatar
My Photos: (27)
Vacuum pump
fuel line heater
Vacuum reservoir, they sometimes rust out.
Look for upgrades to the new one, maybe intermittent wipers if the old one has it and the new one doesn't, cruise control.
If the old rear-end is a 3:55 and the new one is 4:10, I would swap them.
Red 86 F250 Supercab XLT, Longbed, 6.9l, 4 speed with DNE-2 Overdrive, 2WD, Reclining Highback Captains chairs with arm-rest, Holly Red pump, push-button glowplugs, Racor 645 water separator with fuel heater, K&N Air Filter, Headlight Relay Upgrade, lots of extra lights, Isspro EV series: Pyro, Oil Pressure, and Voltage in a Autometer 3 pod A-pillar. Bulldog Security System with remote entry. Remote lube TOB.
BOOB man - Brotherhood of Oil Burners
Joe Mc is offline
Old 07-29-2008, 01:45 PM   #3 (permalink)
The fuel tank switching valve under the truck is expensive. Get it now... If its the auto trans get the vacuum switch off the injection pump. It will cost you plenty later if you need one.
icanfixall is offline
