had some crazy mold smell and lack of blowing power so i took the blower under the hood out for a clean and dug about a 5 gallon bucket full of moldy wet leaves/pine needles/dirt out from the vents under the windshield wipers and down in front of the door panel. Lysoled everything out and buttoned everything all back up. Then i noticed the blower on the floor right above the passengers feet. i took that one out and noticed that there are 4 wires (3 or 4, i think it was 4) and only 1 was connected. after cleaning it all up and procrastinating for about a month i finally decided to put it back in today. red wire plugged back into what it was plugged into when i found it and i made a ground to the frame for the black one. when i turn the ignition on the blower blows like crazy and does not change no matter what position i have the climate settings at. took most of the dash apart trying to find where the other wires were suppose to go put cant for the life of me figure out how to get that climate box extracted from the dash. having that dash apart brought to my attention that someone has gotten creative with wiring back there. what a mess...
im sure i will have more questions but first things first. what is that blower on the floors purpose/how should it react in accordance with the climate control settings? Whats the trick to getting the climate control box out of the dash? My Chilton manual is letting me down on this one.
like i said, 1985 f350 crew cab 4x4 with ac (came with it but sadly it has been gutted from under the hood)
Sounds like the blower is only blowing on high, if it is factory A/C there is a blower motor resitor that maybe bad, the fan speed is seperate from the mode selector such as defrost, floor, dash.
If you have the fan speed on low does it work?
The mode selector work off of the vacuum system.
1985 F250 XL XC LB 2WD with a 6.9 L IDI, C6 auto transmission, 4.10 rear diff, Goose neck, 5th wheel Kobalt Bed Tool Box Fel-Pro Gaskets, Hastings Rings, Clevite Bearings
The mode selector (ac, air, hot) seems to work because if i have it on hot it gets hot and if i have it on ac or air it is room temp. with the passenger floor fan not connected i can hear and feel the blowing speed increase and decrease as i change the speed. if i plug the passenger floor fan into that red wire it was plugged into and ground the black one then it blows on high (super high actually) no matter what mode or fan speed is selected. the only thing that stops it turning off the ignish.
the blower under the hood varies its speed by voltage (im assuming bc there is only one wire connected to it). the blower on the floor by the passengers side has 3 wires and a ground so im thinking it is hooked up to a different system... its not very consistent and it is confusing. maybe the 3 wires were for some option i dont have and so ford used the same blower and just varied its speed by varying the voltage through only one wire?
