99-03 super duty rear end - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 03-04-2005, 10:44 AM Thread Starter
can 99-03 super duty rear end 8 lug 4;10 gears with disk be thrown into the 80-86 f series
1986 F250 4X4 6.9 Extended cab with ATS turbo 4 speed manual 220,000, 120,000 on rebuild by previous owner figuring it all out new IP pump etc.
Alemeg is offline
post #2 of 6 (permalink) Old 03-04-2005, 10:49 AM
beretzs's Avatar
My Photos: (13)
Re: 99-03 super duty rear end
I am pretty sure they will bolt up fine, but the lug pattern in a metric type of 8x170mm where as what you have on the front is 8x6.5. So you would have to run different wheel on the front than on the rear, but other than that, you would be good to go. Scotty
Semper Fi
Scott Beretz
2006 Dodge Megacab 4x4, Cummins, 6 Speed, Airbags, Quadzilla Commander, XZillaraider 2, 285/75R17 Toyo OC AT's
Pulls a: 3814SS Keystone Raptor Toyhauler w/Quads
beretzs is offline
post #3 of 6 (permalink) Old 03-04-2005, 01:48 PM
Guest
Posts: n/a
From what I have been told, it is a direct bolt in swap, including changing the yoke out. You will, however, need the wheels with the metric bolt pattern. A couple of guys on here have done this swap, hopefully they'll be along to help out.
post #4 of 6 (permalink) Old 03-04-2005, 01:53 PM Thread Starter
This is good for my wife I bought it before I found out it would work there was a line of people to get it I was 2 and 1 did not show 400 was asking He helped me load it he did not know if it would work either and I will be working an extra day this week
Alemeg is offline
post #5 of 6 (permalink) Old 03-04-2005, 10:11 PM
Don't forget the emergency brake cables. I think they are different.
Rick
86 F250 N/A 4WD w/HomeGrown Propane, Poly Spring/Body Bushings, PushButton GP Controller, 3.55L rear, Goodyear WorkHorse II XTRA Boots, 248k miles, Rotella 5-40W Synthetic
Rick_Hipp is offline
post #6 of 6 (permalink) Old 03-05-2005, 12:56 PM
Guest
Posts: n/a
Also, here's a good place to look. This was the explanation I got when I asked about putting the 99+ axle in.
