after market block heater - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 12-06-2007, 02:14 PM Thread Starter
Hi it has been a really long time since I have been on this site.
I am eager to get my 86 going regularly again. I have been having an issue with glow plugs recently. I have fitted a 'manual' system for heating the glow plugs using a wiring diagram I got from here years ago. But I think in this latest bout of cold weather I have managed to burn the GPs out (I only use the IH dealer GPs).
I need to replace at least 4 plugs and I am now thinking about fitting a block heater. (I thought the truck was supposed to have one but it doesn't seem to).
Any advice on an after market block heater?
Thanks,
Rod
rodredgate95 is offline
post #2 of 8 (permalink) Old 12-06-2007, 02:20 PM
Re: after market block heater
The block heater is right behind the starter. Someone may have removed the cord, you can get replacement cords at NAPA.
Sometimes the cords are removed because the EARLY 6.9's were prone to cracking at the block heater. But as long as your motor is an 86 motor you are OK. 85 was the last year they used the early block.
1997 Ford F350 SRW 7.3L PSD
1985 Ford Ranger 2.3L 5 speed
1966 Mustang 200 I6, auto, 4 wheel disk, power brake retrofit, Corvette master.
Former vehicles, 1994 E350 7.3L IDI, 1985 International 1654 rollback, 6.9L IDI, (2) 1994 Ford E350 7.3L IDI, 1985 Ford F350 DRW 6.9L IDI, 1985 Ford F350 wrecker 6.9L IDI.
*dual ASE Master Certified, Automotive, Medium & Heavy trucks*
Owner / operator, Patriot Automotive, N Ridgeville OH
Mr_Roboto is offline
post #3 of 8 (permalink) Old 12-06-2007, 05:46 PM
skunk's Avatar
in line heater. works great! like 30$
Northern Woodland & Tree Care work trucks:
old smokey
- 86 Ford F250 6.9 IH navistar non-turbo idi diesel 4x4 dana 60 rear w/ limited slip, dana 44 front wishbone style, w/ 3.55 gears, C-6 w/ oil coolers, manual walbro frb-13 fuel pump, manual wellman glow plugs, K&N air filter no soup bowl and a homemade cold air intake, 3 inch pipe, class 31 heavy duty tractor truck batterys, lots of real gauges.
big drippy - 86 Ford F350 4 door crew cab, long box, 7.3 Navistar IDI non-turbo diesel, 2wd Dana 70 dually rear with 4.88, c-6 w/coolers.
The Swan - 87 chipmore wood chipper chuck and duck old school style. vm motori sun 4505 3.9 air cooled non-turbo DI 4 cyl diesel, rockford pto.
skunk is offline
post #4 of 8 (permalink) Old 12-06-2007, 07:02 PM
Inline heater you have to take out a block drain plug to install the heater.
post #5 of 8 (permalink) Old 12-06-2007, 09:45 PM
cdnsarguy's Avatar
My Photos: (109)
NAPA...Engine heater info......86 6.9
Engine Heater - Freeze Plug Type
Core Location = CR: Rear Right Hand Side, Element Orientation = 11 O'Clock BK 6053137 $40.29
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #6 of 8 (permalink) Old 12-08-2007, 03:44 AM
I like ZeroStart's better than Kats's, the ZeroStarts have replaceable cords and the Kats's don't (or didn't, anyhow). I think the NAPA ones are like a ZeroStart.
If you've got an older motor, though, you're probably better off with an inline heater, like the above mentioned. I'm still running the block heater in my '83, even though I shouldn't, but will probably switch when it finally dies (still on the OEM).
Copper is offline
post #7 of 8 (permalink) Old 12-09-2007, 12:15 PM
CowKiller's Avatar
My Photos: (12)
i have a katz in the bottom radhose. works great.
PLAY TRUCK
1986 F250 6.9,ATS turbo, np435, BW1356, hp 60,welded up sterling 10.25.
converted from 2wd to 4x4
sittin on 36x12.5 goodyears
GETTING CONVERTED TO SHORTBED AS WE SPEAK!
TOW RIG
2002 gmc 2500hd 6.6 duramax 5 speed allison
4x4 extened cab.
2000 F550 Lube Truck (Work Truck)
Certified PA Inspection Mechanic
i'd rather be 6.9'n than cummin or strokin'!
CowKiller is offline
post #8 of 8 (permalink) Old 12-10-2007, 05:24 AM
I went through two of the Kats Frost plug type, before I bought a good one at NAPA...
2005 Black Clearcoat F-350 SC Lariat DRW 6.0 TS 4x4 3.73's....AIRAID, SCT From Innovative, Recovering from Bed Plate Surgery and ARP implants... Came back from shop with some un-needed parts in the bed. Coolant filter
85 F-250 XLT 4x4 6.9 T-19 Plenty of fuel
1998 379 Ext. 3406E 18 speed Rockwell 46,000 rears/3.42's 6.2 M.P.G. @86,000 lbs.
2004 Black Clearcoat F-250 Lariat CCSB 4x4 5.4} yeah I know but it hasn't been in the shop...
modifiedoneton21 is offline
