aftermarket overdrives - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 04-20-2006, 10:59 PM Thread Starter
Does anybody know about an aftermarket overdrive unit. How much are they? Do they work well? Where can I get one?
87 Ford 350 6.9 Dually Work Truck. No upgrades yet
Mark
Herriman, UT
erasurefanatic is offline
post #2 of 11 (permalink) Old 04-21-2006, 05:49 AM
Re: aftermarket overdrives
Gear Vendors, I mounts after your trans, so the driveshaft must be shortened. Look up gear vendors on ebay and their web site for prices.
1987 F250 4wd Lt235/85/16, Dana 50, 6.9 Diesel, 65,000 miles, 4spd man. T 19 Trans, 4.10 rear gears
wjbehof is offline
post #3 of 11 (permalink) Old 04-21-2006, 04:02 PM
Joe Mc's Avatar
My Photos: (39)
US Gear is another type, www.usgear.com
Red 86 F250 Supercab XLT: Longbed, 6.9l, 4 speed with DNE-2 Overdrive, 2WD, 10.25 Sterling 4:11, Reclining Highback Captains chairs with arm-rest, Holly Red pump, push-button glowplugs, Racor 645 water separator with fuel heater, K&N Air Filter, Headlight Relay Upgrade, Fog Lights, lots of extra lights, Isspro EV series: Pyro, Oil Pressure, and Voltage in a Autometer 3 pod A-pillar. Bulldog Security System with remote entry. Offset Mirror Upgrade, Remote lube TOB. Road Watch System coming soon. PB PS PW PDL CC AC IW
BOOB man - Brotherhood of Oil Burners
1995 Toyota Camry DX: 2.2L, Bolt-action 5-speed, AC, PS, PB, CC.
135,016 miles: Rear-ended and totaled by an uninsured kid having a temper-tantrum
1999 Rav4 AWD 5-speed, AC, PS, PB, CC, Sunroof.
Joe Mc is offline
post #4 of 11 (permalink) Old 04-22-2006, 10:48 PM
greetings
i have a gearvendors in my 88 and all i can say is it is much better than an e40d no problems at all
HERS 95,f350,cc,4x4,7.3 psd,e40d,3" dp,4" exhaust with donaldson muffler,k&n in factory cleaner,tymar hpx,fpr shimmed,fuel heater removed,flapper removed from turbo and modified pedesta, tony wildman 4 pos chip,175,000
glassbed is offline
post #5 of 11 (permalink) Old 04-23-2006, 12:00 PM
I've got a "Ranger" overdrive in my unit. Made by "advance adapters" and works much like a us gear unit. It's a manual shift though(2 sticks) I really like it...their website here...
It's not about the money you save in fuel, it's about the driveability of the truck...makes a huge difference, and worth every penny.
Zigg [img]/ubbthreads/images/graemlins/smile.gif[/img]
'86, 7.0L, 4x4, 4sp, 3.54 gears,Dana 50 monobeam, Ranger overdrive, Banks/Hypermax-Hybrid 3 1/2 exhaust, Ram air, Propane,CD Glowplugs, Air bags, everything rebuilt, 300,000+,still tickin',
Now: '93 F350TurboCrewcab 4x4 E4OD with dead 7.3, soon to be replaced with new 7.0LTurbo(bored 6.9)
Wife's car: '86 mercedes 300 T.D.
ziggster40 is offline
post #6 of 11 (permalink) Old 04-23-2006, 08:18 PM
Don't get too wound up, until you check your bank book, they vary in price when found used, but from my point of view, new is exceedingly expensive.
You would drive many miles before payback is achieved.
'93 F-250 IDI, 4x4, K&N, no soup bowl, stock, with 265,XXX miles 5 speed, 3.55, kind of new LUK clutch, runs great, starts great, it is great. The truck is getting old.
BuilderBob is offline
post #7 of 11 (permalink) Old 05-08-2006, 09:44 AM
It depends on your purpose. I have 2 trucks, one with a Gear Vendors and one with a US Gear overdrive. I like the GV for its smooth, automatic shifting with my C6 tranny. I like the US Gear for its heavy duty 30,000 lb towing capacity. The US Gear is definately a more robust unit.
If you don't have anything to do, get a used diesel and a camper!
Truck 1: 1985 F350 dually 4WD 6.9 diesel crew cab auto with 83k original miles. C6 trans, 4.10 rear end. Mods are Banks Turbo, US Gear overdrive, 45gal rear tank, hydroboost brakes, additional leaf springs all around, Hellwig airbags, rear sway bar, GM glowplug controller, fuel Koalescer. 235/85 R16 Michelin XB Rib radials. 11ft.6in Vacationeer cabover camper, TorkLift tiedowns.
Truck 2: 1988 F250 7.3, C6 auto, 2WD w/3.55 limited slip rear axle, Banks Sidewinder Turbo, Gear Vendors overdrive, Utility box, hydraulic lift gate, lumber rack.
Auto: 1987 MBZ 300D Turbo 3.0 Liter 6 cylinder engine. 205K miles. Working on all the "little things" that previous owner neglected. Putting in wvo tank.
Monte1 is offline
post #8 of 11 (permalink) Old 05-08-2006, 10:47 PM
If you break the US Gear it will stop you right there in your tracks. If you break the Gearvenders you loose the over or underdrive and still have your oem trans to get you home. Gearvenders are about $2700.00 new but well worth it on driveability.
icanfixall is offline
post #9 of 11 (permalink) Old 05-09-2006, 07:01 AM
ldw
I bought a new GV unit 52,000 miles ago. I figure at current fuel prices and the mileage boost I get, I need to drive it about 80,000 miles to pay for it.
I bought new because I plan on keeping it for the next truck I buy. If this truck dies, whatever I get it will go on so I planned on having it for a long time.
When I was debating buying one I talked to a guy who had 300,000 on his and it had been on 3 different trucks. He told me it cost about $500 to get the new computer, adapters and move it over to the new truck each time.
If I can keep mine the same amount of miles it will be well worth the original cost. I also count in the fact that by running at lower RPM's I am saving other costs. My truck has the 4 Speed and runs at high RPM's. By running lower I am saving water pump, fuel pump, and engine parts from running so hard.
Northern Va area
86. F-250, 4x4, Extended Cab, T-19 Trans, 4:10 rears, K&N Air Filter, Flowmaster 2 1/2 single in double out, Ziggster Type Ram Air, Gear Vendor.
2006 GMC Duramax/Alison CrewCab No Mods
ldw is offline
post #10 of 11 (permalink) Old 05-10-2006, 11:06 PM
My Photos: (25)
Not true. I typed up a big long examination of failure modes the other night, then the &*%^*% computer erased it when I tried to post. Oops. Point is, the GV unit is much more complicated and more likly to fail castrophically. US gear unit is proven hevvy duty technology (basically a small 2 speed version of the roadranger trannies in semis) whereas the GV is a beefed up version of the norman deville (unuser on spelling) overdrive box used in many 60's european cars. Fundemental design differnce. The GV is simpler to use, but not as heavy duty. I'd say both are equally likely to strand you, and the liklyhood of it actually happening is very small for both, assuming they are correctly used.
85 F250 4x4 w/ 6.9 diesel, ZF5 trans, custom wastegated turbo, rebuilt engine (twice) exhaust brake and lots of other stuff. Noisy, ugly and most of the time it even all works.
jaluhn is offline
post #11 of 11 (permalink) Old 05-18-2006, 10:50 PM
I have a US Gear on a 2wd C6 and love it.
I'm not sure if your truck is 2wd or 4wd but here's one point of interest:
The GV OD installs behind the front wheel gear box so OD can only be used when the truck is in 2wd mode. The good news is that on 4wd trucks, only the rear driveshaft length needs to be modified.
The US Gear OD installs in front of the front wheel gear box so both front and rear driveshaft lengths have to be modified on 4wd trucks. I found mine on eBay and installed it myself. Now to get my 4.10 gears down to 3.56's.
Aubrey-Chinook, WA
87 F-350 XLT Lariat standard cab 2wd DRW, 6.9L and C6 w/cooler, 4.10 LS. Hypermax Turbo with 3-1/2 exhaust, US Gear OD, Powershot 2000 LPG. Cupholders and accumulated rust.
Aubrey is offline
