Air in the fuel - Diesel Forum - TheDieselStop.com
Old 11-15-2009, 03:01 PM   #1 (permalink)
Air in the fuel
I have a 87 f-250 that keeps getting air in the line. I have riplaiced the mechanical pump and the line to the filter. The truck wont start, i have bled the air out of the fuel system, checked and rechecked the glow plugs replaced the starter, and had the batteries tested, and it still wont start. Can anyone help?
1992 idi exended cab long bed zf-5. Banks sidewinder turbo, muffler delete.
1994 powerstroke with hypermax intercooler, turbo, 600hp pcm, f-350 conversion zf-5 speed 4x4 with a 5 inch exhaust. Soon to have 2nd gen cummins
oklahoma diesel is offline
Old 11-15-2009, 04:25 PM   #2 (permalink)
CDX825's Avatar
My Photos: (11)
Send a message via AIM to CDX825 Send a message via Yahoo to CDX825
Sounds like air on the suction side of the pump.
Could be the water separator drain or the pickup in the fuel tank.
-Justin
1984 F250 6.9 C6 2WD Push Button Wellman GPs, No Soup bowl. Wix 33439 Water Separator, Carter P4594 fuel pump, Custom 3" Exhaust, NTZ Oil Bypass Filter, VDO Vision water temp gauge, ISSPRO EV Pyro
http://photobucket.com/CDX825
CDX825 is offline
Old 11-16-2009, 03:27 PM   #3 (permalink)
What Justin said for the air and then some. These seperators are notorious for leaking air when under suction but are not the only cause of air leaks. Some others are: poor fuel line connections, leaky injector return caps, poor design of sucking fuel instead of pushing fuel to the IP. Several ways to skin this cat.
Upgrade to a more modern filter/water seperator (similar to mid 90 7.3's) and bypass the old one.
Replace your injector return line caps if they are more than 2 years old with the return cap kit for about $30.
Ditch the old mechanical suction lift pump in exchange for an electric pump mounted pre-selector switch on your frame rail. If you do this one it is nice to have a manual cut-off switch installed just in case.
Have you checked you glow plug relay? I ended up installing a manual button (switch) for my glow plugs and it works like a champ. Some use the newer Relay out of the 7.3 (not sure what year) but I like the positive control of the button.
Work rig - 2000 F250 7.3 4x4 3.73 auto, 285/75 Michelin ATX, hpx, zoodad, hutch mod, 4" mbrp, 6637, isspro 3 pod, Trucool, ATS ported shroud (someday).
Farm rig - 85 6.9 xl t18 4x4 3.73ls, 88k orig miles, zig-style ram air, electric fuel pump, soup bowl delete, manual 12v glow plugs, Battery isolators, KISS principle generously applied.
Njellison is offline
