automatic transmission sluggish to engage in cold weather - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 03-03-2007, 10:14 AM Thread Starter
I have an 84 6.9 f250 4wd with automatic transmission. It gives no problems in warm weather or when truck is warmed up well after a drive. On cold mornings however it takes anywhere from 20 seconds to 1 minute for the transmission to engage in drive after I shift it from reverse(reverse works fine even in cold). Transmission fluid shows no more than 1/2 a quart low. I have to give it some not insignificant pedal beyond idle to make it engage in drive on these cold mornings. Any ideas?
Central Arkansas- Just bought my first diesel- an 84 F250 4X4 with 6.9L automatic trans. 355 gears-225,000 mi. Gets 16.6 mpg
New starter,radiator,steering parts,rear-end,ATS turbo,just put in a ring gear on flywheel..
Cogburn is offline
post #2 of 5 (permalink) Old 03-03-2007, 10:44 AM
cdnsarguy's Avatar
My Photos: (109)
Re: automatic transmission sluggish to engage in cold weather
Have you ever had any band, shift cable, PNP or VRV adjustments carried out......1/2 qt low won't help either.
PNP...park nuetral position switch,
VRV..Vacuum regulating valve
How about a trans filter service.......
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #3 of 5 (permalink) Old 03-05-2007, 04:44 AM
My Photos: (16)
It's the seals. Either rebuild it, or let it warm up a little before driving.
Check fluid when up to operating temp. Add fluid only if nessesary
'93 F250 SCab XLT, 4X2- 7.3/ZF5/4.10 Banks Wastegated Turbo, Enviro-assult tube
'85 F250 Reg Cab XL, 4X2-6.9/C6/3.54 Racor, Holley Red, Auto Jet 3" out, Air Ride Rear
'93 F150 Reg Cab XLT, 4X4-5.0/AOD/3.55 Pacesetter dual out, Timbren Rear
Zrob is offline
post #4 of 5 (permalink) Old 03-05-2007, 04:56 PM
I had a similar problem in my 90 150. Same as you described but mine also had problems downshifting when it came into highway grades...i usually just hit the OD off button. Anyway...i serviced it and it helped. But i sold it soon after so no long term results to report. Hope that helps...at least servicing is a cheap place to start...
---Don't run your fingers over my truck and I won't run my truck over your fingers---
97 Reg Cab Long Bed 5 spd, testing out some diy injectors, tymar, 3-4 DP, Cobalt Gauges, South Bend clutch, my own custom electric fuel system (pics soon), 305/70 ProComp A/T's on 16" MT Classics with Air Lift Bags and B+W Turnover out back...driven daily about to click over 200k...working at international gives me access to some fun goodies
05 Arctic Cat 400
95 Honda 750 Magna
97 Toyota 4runner
04 Kubota BX22 with a front loader, backhoe and mower deck - looks mean cutting grass with all the attachments!
"I'm not driving fast...I'm flying low!"
Wreckingball_psd is offline
post #5 of 5 (permalink) Old 03-09-2007, 10:07 PM
as zrob said--go get some trans-x from a auto supply place--put in amount per instructions--its works--but i dont know for how long--its been in mine three years--- [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
94_turbo is offline
