Bad Knock - Diesel Forum - TheDieselStop.com
Old 11-23-2005, 12:39 AM   #1 (permalink)
Bad Knock
I was trailering my donar truck home, and got it hung up offloading and needed to start it, but the GP system doesn't work so I gave it a shot of ether to start it. I know, I hate the stuff too. I crank it and it sputtered and began to knock badly. I didn't let it start, it was just cranking with the starter. Tonight, I pulled the heads (engine on stand) and there is no sign of anything in the cylinder. One piston looks like it had something bashing the top of it (GP tip perhaps) at one time, but the marks looked very old. What else should I look for? Could an injector have been damaged? Also, what does the "20" stamped in the pistons indicate? Thanks. Ty.
2003 f350 4x4 6.0L auto
k828 is offline
Old 11-23-2005, 12:43 AM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (109)
Re: Bad Knock
The knocking is the ether igniting ahead of the correct time trying to force the engine backwards. The 20 is probably the oversize of the pistons on last rebuild.........is it sleeved.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 11-23-2005, 06:34 AM   #3 (permalink)
Re: Bad Knock
You used too much either. Although I only had to use either in my truck only once, if you spray it correctly, the engine will speed up slowly to fire, rather that knock, spit, lockup, and then fire. If that made any sense. What you experianced is perfectly normal when you use to much.
My Rigs:
86' F-250 XLT Lariat,6.9 Diesel, Extended Cab, 4x4, 4.10's, 8'bed, Push Button Glowplugs, etc...My Truck,My Truck At Christmas,My Album
99' Crown Vic Police Interceptor (P71) w/Steet apperance package, 4.6L, 4R70W, 3.55 Trac-Loc Differential (DK), Total Cloth Interior, New Honeycomb Grill, Black PI Trunk Bezel, Silverstars, 110K,My 99' CVPI Photos
04' F-150 XL Heritage, 4.6L V8, 4x4, Ext Cab.
Fordiesel69 is offline
