bent clutch rod? - Diesel Forum - TheDieselStop.com
Old 11-25-2005, 08:57 AM   #1 (permalink)
bent clutch rod?
How in the world did I bend the threaded rod that inserts into the clutch master cylinder. I mean its a "z" now. I had problems grinding into reverse and the clutch wouldnt release all the way but could i have adjusted it to far out and bent it. On average how much thread past the locking nut should show about a 1/4 inch or so. Please help need my truck. everything about it is in my sig.
-'01 f250 reg cab long bed 4x4 auto 7.3, harvest gold, isspro ev guages, ats/ts 6 pos. chip, limo glass.
-1979 CJ-7 304 auto green and bed liner
-1966 Pontiac Tempest custom gto clone project car
mvmudslinger is offline
Old 11-25-2005, 01:13 PM   #2 (permalink)
Joe Mc's Avatar
My Photos: (39)
Re: bent clutch rod?
The "grinding into reverse and the clutch wouldn't release all the way" is a classic symptom of a cracked firewall. Most of the time it will shift OK while it is cold and shifting will get harder as the truck get warmer. That statement will make sense to you if you have had the crack for a while. [img]/ubbthreads/images/graemlins/smile.gif[/img]
I does sound like you tried to fix the symptoms by adjusting the rod too far.
I didn't think that my truck had a stiff clutch, until I had mine working right, now it almost falls to the floor.
Red 86 F250 Supercab XLT: Longbed, 6.9l, 4 speed with DNE-2 Overdrive, 2WD, 10.25 Sterling 4:11, Reclining Highback Captains chairs with arm-rest, Holly Red pump, push-button glowplugs, Racor 645 water separator with fuel heater, K&N Air Filter, Headlight Relay Upgrade, Fog Lights, lots of extra lights, Isspro EV series: Pyro, Oil Pressure, and Voltage in a Autometer 3 pod A-pillar. Bulldog Security System with remote entry. Offset Mirror Upgrade, Remote lube TOB. Road Watch System coming soon. PB PS PW PDL CC AC IW
BOOB man - Brotherhood of Oil Burners
1995 Toyota Camry DX: 2.2L, Bolt-action 5-speed, AC, PS, PB, CC.
Triple A-pillar pod: Isspro EV voltage and oil-pressure gauges.
Road-Watch System (Air and road-surface temperature gauge).
Chicken Lights Gone.
Joe Mc is offline
Old 11-25-2005, 01:47 PM   #3 (permalink)
this thing has a 1/4 inch plate that looks like a repair kit. I think it was the master cylinder because the carpet under my floor mat was soaked in break fluid.
Old 11-25-2005, 07:32 PM   #4 (permalink)
This is off subject; but I noticed in your sig it says >> restrictor plate removed. <<
Where and what is this restrictor plate??
1985 F-350, 6.9 4spd, Hypermax, 3.55 rears
BullHauler is offline
Old 11-25-2005, 07:55 PM   #5 (permalink)
there is two, one on the bottom of the breather where the intake tube comes in. the second is behind the head light on the driver side where the intake tube draws air in from the outside. they say they're there to keep bugs and water out but a filter will stop bugs and I haven't seen a hard enough rain to get up there, And I live in the ohio river valley, it rain sideways here.
Old 11-25-2005, 07:57 PM   #6 (permalink)
to get back to my truck, new master has grenaded the old slave cylinder.got a new one and now my clutch fork is cracked in half
Old 11-26-2005, 11:49 AM   #7 (permalink)
Joe Mc's Avatar
My Photos: (39)
On the bright side; you are about to have a new clutch linkage system. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
While you have the fork out will be a great time to lube the throw out bearing.
Joe Mc is offline
