Brake problems
Well, the brakes in my 3/4T don't seem to want to work as well anymore. I have to pump them 2 times to get good brakes. Pulled the drums off last night. I'm not leaking any fluid. I thought it was possible that they just needed adjusting, but that didn't help. I have vaccum when I pull the hose off the booster. I'm thinking it's the master cylinder, but it holds pressure after the second pump. Any suggestions? I hate throwing parts at a problem.
87 F250 6.9L C6 4WD, sorta running right.
'00 CC, LB, auto, 4WD, Lariat, ISSPRO EV gauges on the pillar, 295's, dp econo tune, napa 6637, boost regulator, aih delete, 4" turbo back exhaust.
