burning oil - Diesel Forum - TheDieselStop.com
Old 11-10-2009, 07:29 PM   #1 (permalink)
6.9Laska's Avatar
burning oil
i have a 6.9 1985 uses about 4 quarts of oil every 100 miles no leaks burns it.
idk whats causing it i checked CDR valve and it ok there is no oil in the intake this problem just popped up outta nowear
anyone ever run across this before?
thanks
04 F250 XLT SD CC 4X4 auto 6.0 powerstroke, red ELC, coolant filter, welded EGR cooler, scangaugeII
84 F250 XLT 6.9L 4X4 4 Speed T-19
6.9Laska is offline
Old 11-11-2009, 10:13 AM   #2 (permalink)
There are several things it could be.
I have an 84 that's been smoking badly.
A few days ago it sprang a fuel leak between the pump and fuel filter.
I changed the line and filter and most of the smoking has stopped.
It might be a cheap fix for you.
longwolf is offline
Old 11-11-2009, 10:38 AM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (109)
Are you filling it back up to the line on the dipstick.......
Post from a pro......
DieselDon
Oil consumption, and the proper checking of the oil levels in Ford diesels comes up periodically. Ford dipsticks are calibrated for hot oil. The 10 quarts in the IDI engines expand about 1/2 to 3/4 of a quart as the oil heats up, and contracts the same amout after cooling. If you check the oil first thing in the morning ( which I grew up doing ) the engines will all indicate oils level below full, but when checked hot, will ( after a 10 minute drain time ) the oil level is usually at full. If you are checking the oil cold, and keeping the level at full, you are actually over filling the engine which will burn of the extra rapidly.
Suggestion: Check oil hot after 10 minute drain time.
Don't add until level reaches add line ( 2 quarts ).
In my days at Ford this often cured, or at least improved, the apparent oil consumption complaints.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 11-11-2009, 11:05 AM   #4 (permalink)
Joe Mc's Avatar
My Photos: (39)
From the Ford TSB on oil burning:
OIL DIPSTICK (6.9L) - ENGINE OIL LEVEL CHECKING PROCEDURE
LIGHT TRUCK 1983-86 E AND F SERIES
In order to measure engine oil levels consistently and accurately, it is useful to employ the following recommendations:
 Park vehicle on level surface. Low oil level readings will be obtained if the vehicle is sloped away from the dipstick.
 Have engine at normal operating temperature as oil expands at the rate of one percent per 25~F (14~C) change and the dipstick is calibrated to the engine at normal operating temperature. In addition, allow at least a fifteen (15) minute engine shutdown period to assure that oil contained in the upper parts of the engine has returned to the oil pan.
 Have dipstick loop directed inboard as this eases installation and minimizes wiping action on oil level gauge.
 Read oil level on both sides of gauge and use highest level (reading) for the actual engine oil level.
Correct oil dipstick calibration can be verified by draining the engine oil and filling the engine oil pan with nine (9) quarts (8.5 liters) of oil. When the oil dipstick is properly seated, correct dipstick calibration is indicated if the oil level is within 1/16 inch of the "Full" mark.
NOTE: The area between the "Add" and "Full" marks represents two (2) quarts. As long as the oil level is between the "Add" and "Full" marks, no oil should be added. When the oil level does reach the "Add" mark, only one quart of oil should be added. If the oil level exceeds the "Full" mark, oil consumption could result.
Red 86 F250 Supercab XLT: Longbed, 6.9l, 4 speed with DNE-2 Overdrive, 2WD, 10.25 Sterling 4:11, Reclining Highback Captains chairs with arm-rest, Holly Red pump, push-button glowplugs, Racor 645 water separator with fuel heater, K&N Air Filter, Headlight Relay Upgrade, Fog Lights, lots of extra lights, Isspro EV series: Pyro, Oil Pressure, and Voltage in a Autometer 3 pod A-pillar. Bulldog Security System with remote entry. Offset Mirror Upgrade, Remote lube TOB. Road Watch System coming soon. PB PS PW PDL CC AC IW
BOOB man - Brotherhood of Oil Burners
1995 Toyota Camry DX: 2.2L, Bolt-action 5-speed, AC, PS, PB, CC.
Triple A-pillar pod: Isspro EV voltage and oil-pressure gauges.
Road-Watch System (Air and road-surface temperature gauge).
Chicken Lights Gone.
Joe Mc is offline
Old 11-12-2009, 08:48 PM   #5 (permalink)
6.9Laska's Avatar
yes i always check oil level with hot oil. the truck just burns that much oil im guessing its the rings because its hard to start even with glow plugs at 60 degrees only way to start it is ether
6.9Laska is offline
Old 11-12-2009, 09:49 PM   #6 (permalink)
Matt0987's Avatar
Did I miss this? How many miles on the engine? Mine "used" oil until it seated at about 50k miles. Then at around 125k miles it started using it again.
'03 Excursion, 7.3L, 4X4, Auto tranny of course (they all did), 4" MBRP exhaust, TS performance chip, K&N FIPK w/ an Amsoil EA filter, Hellwig anti-sway bar, drilled/slotted front & rear rotors. Rancho XL shocks, Rancho steering damper, Airlift 5000, S&S Diversified headlight mod. This baby surprises a lot of, so called, performance cars.
'04 F 350, extended cab, 6.0L, FX4, manual tranny, 4" MBRP exhaust, Bully Dog Triple Dog downloader w/ Outlook moniter (Very disappointed in the Bully Dog), 2m-70cm Yaesu ft-8500, S&S Diversified headlight mod.
'11 Harley-Davidson Road King Classic 103 ci PowerPak w/ anti lock brakes & Smart Security system. It even has cruise control!!! Candy Dark Root Beer over Candy Light Root Beer Yaesu FTM-10R & a Comet CSB 790A
Matt0987 is offline
Old 11-13-2009, 10:12 AM   #7 (permalink)
Joe Mc's Avatar
My Photos: (39)
Mine got harder to start without using the glowplugs even warm, when the IP was worn-out.
Have you changed your brand of oil?
Done anything to the engine?
Joe Mc is offline
Old 11-13-2009, 11:26 AM   #8 (permalink)
6.9Laska's Avatar
hi the engine has 140000 miles on it. i havnt done anything to the engine everything is stock i use rotella 15w-40. ip could be weak that truck doesnt have near the power as my 84 truck sat for 12 years before i bought it didnt take much to get it running and when i first started driving it it barly used any oil then it just started all the sudden. maybe a bad injector or 2 is washing down walls idk. my 85 is just a beat around truck that i burn waste oil in but the oil consumption started before i started burning waste oil so i dont think that has anything todo with it
6.9Laska is offline
Old 11-16-2009, 03:11 PM   #9 (permalink)
thanks
OK.... not good. I agree that overfill can cause excess oil to be burned but cannot imagine this much. Are you topping it off every 25 miles or did you check it at 100 miles and have to add 4 qts?
CDR valve is also likely oil siphon culprit but you indicate not bad.
Let's assume you are blue smoke all the time with this much oil being burned, if not then you are leaking it. Have someone drive behind you , or better yet have someone drive your truck and you drive behind them and get an idea about how much is burning.
How much puffing do you get from the oil fill cap when removed? If major locomotive pulling a hill type of puffing then rings or head gasket are probably to blame.
I go through about a quart every month or so (500 to 1000 miles), some leaks (rear main) and some burns as is evident by the light blue smoke at start up and minor smoke blow out the oil filler when cap is removed. This is typical for the rigs I have seen. What you have is not typical. Good luck and let us know what you find.
Work rig - 2000 F250 7.3 4x4 3.73 auto, 285/75 Michelin ATX, hpx, zoodad, hutch mod, 4" mbrp, 6637, isspro 3 pod, Trucool, ATS ported shroud (someday).
Farm rig - 85 6.9 xl t18 4x4 3.73ls, 88k orig miles, zig-style ram air, electric fuel pump, soup bowl delete, manual 12v glow plugs, Battery isolators, KISS principle generously applied.
Njellison is offline
Old 11-18-2009, 03:04 AM   #10 (permalink)
6.9Laska's Avatar
hi the smoke is mostly grey. on startup it smokes heavy for a few minutes then fades out to barely any just a small amount of grey doesnt seem to smoke much wile driving under hard acceleration it blows black
6.9Laska is offline
Old 11-21-2009, 02:00 AM   #11 (permalink)
CDX825's Avatar
My Photos: (11)
Send a message via AIM to CDX825 Send a message via Yahoo to CDX825
Id run a compression check on all cylinders and see what you come up with.
-Justin
1984 F250 6.9 C6 2WD Push Button Wellman GPs, No Soup bowl. Wix 33439 Water Separator, Carter P4594 fuel pump, Custom 3" Exhaust, NTZ Oil Bypass Filter, VDO Vision water temp gauge, ISSPRO EV Pyro
http://photobucket.com/CDX825
CDX825 is offline
Old 11-21-2009, 03:44 AM   #12 (permalink)
rsr911's Avatar
An IDI will not smoke burning 4 quarts in 100 miles. For reference I run up to and sometimes past 50% waste motor oil in mine, I get average 14mpg of mostly city driving. That's about 3.5 gallons (16 quarts) in 100 miles with no smoke other than typical diesel under heavy load or acceleration.
A compression check is a good test but it is possible that the compression rings are good while the oil rings are bad, I've had it happen on a gasser.
If an injector was bad you'd have a misfire, if it was washing down the walls the oil level would rise. Besides you're running waste oil so even if it was washing down the walls it would be lubricating them.
As for starting hard at 60F, how thick is your blend? Does it start hard both warm and cold? One more than the other?
1986 F350 Crew Cab 2wd SRW. 1991 7.3 IDI, T-19 4spd Sterling 10.25 3.55, 12" HD clutch. A Banks waste gated turbo. 5" cut down Peterbilt stack. Midwest rebuilt IP turned up. AC Delco 6.5 GM 12V GP's, working great. Running W85 high performance zero-gel diesel! D60 front conversion, 4wd conversion, dually conversion, and steel flatbed conversion now underway. Man those frame rivets are a pain!
1966 Porsche 911. 1983 911 SC engine with modified Zenith carbs, headers, 911S brakes, custom fuel rails, MSD 6al box with timing computer, 1974 IROC body kit. 1850lbs, 200rwhp, total blast to drive.
rsr911 is offline
Old 11-23-2009, 01:08 PM   #13 (permalink)
Joe Mc's Avatar
My Photos: (39)
Does anyone know if Shell has reformulated their oil recently?
CJ-4/SM is the last ratings on the jugs I have here.
With the amount of oil your losing, try changing to Delo and see if it makes any difference. In past post on this site others have seen high oil consumption with one brand over the other and they noticed immediate improvement when they made the change. This is not to claim that one brand is better than the other, it just seems that some engines have a preference for one brand or the other. I use the Rotella T in my truck.
Joe Mc is offline
